02-03-2019, 12:18 PM | #1 |
Member#: 488312
Car Throttle hesitation help
If you see the video below it explains the issue I’m having anyone got any ideas, thank you so much. https://youtu.be/OwEkaNa_aBY
I’m not doing that with the throttle if I blip the throttle it’s as if it had a delay (goes from 1000 to 3000 jumps back down to 1500 then back up to 3000 all at once in a second)
02-03-2019, 10:08 PM | #2 |
Member#: 488312
Help bump this is killing me
02-03-2019, 10:21 PM | #3 |
Member#: 488312
Update it’s almost as if I’m blipping the throttle twice which makes smooth throttle impossible and heel toe also impossible this learning curve sucks plz help
02-04-2019, 10:51 AM | #4 |
Member#: 111755
what rom and whats your map?
decel fuel cut disabled? |
02-04-2019, 11:41 AM | #5 |
Member#: 488312
02-04-2019, 07:48 PM | #6 |
Member#: 488312
02-05-2019, 08:19 AM | #7 |
Member#: 111755
Have you gone over the entire intake section including the intercooler and checked for vacuum leaks?
Usually these type of issues are not caused by ecu programming.. Check for leaks. |
02-05-2019, 09:20 AM | #8 |
Member#: 488312
I have the original map saved and when I use that the issue is gone so that’s why I figured it had todo with that, you still might think it’s leaks?
07-24-2019, 10:42 PM | #9 |
Member#: 488312
Bump from dead I have now tried almost everything and still get the issue I made a log to help visualize what’s happening, I couldn’t have been the only one with this problem. Here’s the linkhttps://drive.google.com/file/d/1vnw...w?usp=drivesdk
07-24-2019, 11:34 PM | #10 |
Member#: 488312
If anyone can get me this problem a solution I will PayPal you a lunch win win
07-26-2019, 08:58 PM | #11 |
Member#: 488312
Bump for help
07-27-2019, 01:36 PM | #12 |
Member#: 435611
International
Vehicle:2002 SG5-2.0-XT-JDM 45A, originally 18L |
clean your maf with maf cleaner. have you done that? or get a pal to exchange it and see if their works. reset the ecu and come back.
07-27-2019, 07:00 PM | #13 |
Member#: 488312
09-17-2019, 04:50 PM | #14 |
Member#: 363007
Vehicle:2008 STI Black |
09-24-2019, 02:36 AM | #15 |
Member#: 506471
your MAF is all over the place. can you upload the ROM? your A/F is jumping around at idle which it should be pretty steady since its not under much load. Also, what does your target A/F tables look like cause your also pulling ALOT of fuel under idle. MAF scaling could fix this and your problem. But you're still pulling a lot of fuel out at idle which may need to adjust your target A/F. Scale the MAF and then move to next step.
