05-15-2001, 08:23 PM | #1 |
Member#: 169
Vehicle:98 black OBS move bi*ch get out da way |
Interesting hesitation problem - Troubleshooters UNITE!
Here's my current set-up
MY98 2.2L OBS Minnam Intake w/ GReedy Airnix Stromung Single tip removed intake silencer. OK, so if im crusing around and the car drops below 2K RPMs and i step on the gas, the car hesitates/shudders as if it is out of gas. It is real annoying and I cant figure it out. I just had the 60K mile tune-up yesterday (replace plugs, fuel filter, fluids etc etc) and it stil happened, although not as bad. Could this be a clogged fuel line? If so how do i unclog it? The dealer said it could be the MAS failing because of the intake but they would need more time for trouble shooting. Any ideas would be greatlly appreciated. Thanks! //
05-15-2001, 09:30 PM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
<FONT face="Comic Sans MS">Well, I would hope the fuel lines wouldn't be clogged per se, as the fuel filter is the biggest restriction in the equation and is designed to stop the crud. Perhaps, especially because it's a low RPM issue, the O2 sensors are suspect. A failing O2 sensor would give you lots of bog at low rpm that would start to diappear the more the throttle opened up for you and the rev's climbed...
Brian AIM: captaindamorgan ICQ: 84483950 http://ravensblade.cjb.net Conjunction Junction, what's your function? </FONT f> |
05-16-2001, 12:19 AM | #3 |
Member#: 3069
Fuel pump
o2 Plug wires but being a 98 most likly what the dealer said run some fuel cleaner to |
05-16-2001, 05:16 AM | #4 |
Member#: 6110
Vehicle:98 Impreza L Red |
How long has it done this? I'd say it's not the fuel system if it runs ok at higher rpms.
05-16-2001, 06:08 AM | #5 |
Member#: 169
It has been hapening for about 3 weeks now. I guess i'll have them check the o2 sensor. next time in in......it has decreased since i got the new plugs/fuel filter...maybe it is just working itself out.
thanks guys // |
05-16-2001, 06:30 AM | #6 |
Member#: 2575
South East
Vehicle:2008 Forester 2.5X Dark Gray Metallic |
Wasn't there a recall on some of those O2 sensors?
05-16-2001, 10:53 AM | #7 |
Miss You Mom
NESIC
<FONT face="Comic Sans MS">Yes, but only on the 00 model Impreza's and Foresters (maybe some 01's too).
Brian AIM: captaindamorgan ICQ: 84483950 http://ravensblade.cjb.net Error 666: Connection reset by Satan</FONT f> |
05-16-2001, 11:35 AM | #8 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
do a search back a ways and you;ll find a guy up in Canada had/has the same problem....I dont know if or how he resolved it. Have you changed your plugs yet? Try a few tanks of fuel system cleaner and a new fuel filter after that. Also check your ignition coil pack, wires and plug connections to make sure there is no rust or anything suspect there....
05-16-2001, 03:42 PM | #9 |
Member#: 766
Vehicle:MY00 2.5RS 4EAT BRP |
Same problem for me...
I did replace my O2 sensor under recall(also change to NGK Platinum plugs) but the problem is still there. |
05-16-2001, 03:50 PM | #10 |
Member#: 46
Vehicle:2001 Jetta 1.8T White |
mine did it too last week.. but i reset the ecu and it seems better now. not sure for how long though...
Eric |
05-17-2001, 01:35 PM | #11 |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
I just had the same EXACT problem this week. I changed my spark plugs and it helped but the problem was still there. It was very noticable between 1800-2500rpm. Light throttle and the engine would bog then pick up once it got past 2600rpm or so. It was really annoying.
I had a brand new O2 sensor that I put in a week ago. I didn't think it had anything to do with my car bogging but it did. The dealer found out that something was wrong with my O2 sensor harness and something needed to be 'extended'. I do not know the details but that was definitely the problem. Riding around town before the fix, my O2 sensor would read lean until I was above 3k rpmsa and then it would go back and forth to lean and rich. After the O2 sensor fix, all of my low end torque is back and my O2 sensor fluctuates back and forth at idle and low speed driving. So have your O2 sensor checked. I'm almost positive it's the source of your problems since what you described is exactly the same problem I had up until this Tuesday. Good luck! [This message has been edited by Kevin Thomas (edited May 17, 2001).] |
05-17-2001, 01:54 PM | #12 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
You have a MAS/MAF and nothing correcting the air/fuel ratio because of the intake. Sounds almost like a WOT map you're running really rich (cauing bog) or lean (causing detontation/ECU retarding ignition).
Let me guess, it doesn't happen when you gradually put your foot to the floor, just when you romp on it? |
05-17-2001, 03:25 PM | #13 |
Member#: 169
8 - you nailed it! thats exactlly what happens..although i think the new spark plugs/fuel filter helped out because it didnt happen at all yesterday or today. I have an S-AFC but i havent put it in yet and that should help i assume?
01-08-2002, 10:22 AM | #14 |
Celebrity Guest Star
Member#: 10648
NESIC
Vehicle:2008 Acura TL Wicked Black |
sorry to bring this back from the dead, but my GF is having a problem with her car that sounds exactly like this. My suspects are MAF & O2. I'm pretty sure its running rich, so fuel filter wouldn't do it. its been a while since this was posted. What finally fixed teh problem?
-IggDawg |
01-08-2002, 11:48 AM | #15 |
Member#: 4531
Vehicle:2001 2.5 RS Sedan Silverthorne Metallic |
Is there such a thing as too much air flow? I noticed that after I put on my ganzflow that if I stomped it, the engine sounded/felt like it took a big gulp of air.. missed a beat .. then revved like mad. It would last a millisecond (not really a stutter just a little air popping noise) but I don't remember it being there before the new intake. Doesn't happen when slowly giving it throttle.
Maybe I just couldn't 'hear' it before.. |
01-08-2002, 11:56 AM | #16 |
Member#: 10648
NESIC
Did you reset the ECU after you installed it? you might be running an obsolete air map.
-IggDawg |
06-28-2005, 09:20 AM | #17 |
Member#: 43357
Vehicle:2004 Smug 46MPG 2016 Clown Car also zoom3 |
This is a very old thread to bump, but I would like to see the resolution/outcome of O2 sensor replacement suggestion on this problem, as I am experiencing the same thing now. When I accelarate swiftly (not WOT) in lower rpms, I get the bogging. My car behaves exactly like Mike's car...
If this problem is resolved by replacing the O2 sensor, is this an easy replacement, or do I have to have the dealer do it? Where is it located? Bunch of n00b questions I have today....Oh, and my car is a completely stock 2000 OBS with 48K on the odo. I appreciate your help in advance. tbert |
06-28-2005, 09:23 AM | #18 | |
Member#: 43357
tbert |
06-29-2005, 09:41 AM | #19 |
Member#: 43357
bump for an answer!!!
Come on guys, don't make me ask teh OT. They scare me. aranoid: - |
06-29-2005, 11:51 AM | #20 |
Member#: 1140
SCIC
Vehicle:2000 S201 #78, '95 L '13 F150 Ecoboost |
Me too!
I've been experiencing a slight hesitation similar and I was leaning to my O2 sensors or MAP sensor.
06-29-2005, 12:07 PM | #21 |
Member#: 1140
SCIC
Me too!
06-29-2005, 04:10 PM | #22 |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
Use an ohmeter to check your coil. I have had 2 fail and found a failed one on my buddies '99RS
http://home.comcast.net/~r.files/sube_manuals/coil.jpg |
06-29-2005, 07:12 PM | #23 |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
Hmm, interesting to see this thread pop up. I'm experiencing similar problems as well!
LaterZ! Darren!! |
07-02-2005, 02:42 AM | #24 |
VIC
Well, I just reset my ECU while I was checking my plugs, wires and coils. It doesn't hesitate anymore!
I'll keep you informed on how long it stays away for. LaterZ! Darren!! |
07-02-2005, 07:06 PM | #25 |
Member#: 70155
Vehicle:1999 Legacy 2.5 GT Brilliant Silver Metallic |
This seems like a common problem for people who have modified their intakes. I've been having the same problem ever since I took the intake silencer out. I'll go reset my ecu and see if that clears things up.
Brake Problems - troubleshooting, help, tips, etc needed | elgorey | Brakes, Steering & Suspension | 9 | 08-22-2002 07:43 AM |
Hesitation problem... | gimpless | Normally Aspirated Powertrain | 1 | 09-18-2001 06:56 AM |
Hesitation problems......please help! | Italiano | Technical Forum Archive | 6 | 08-22-2000 09:00 AM |
Low RPM hesitation problems.. please help! (cont. ) | Orbiter | Technical Forum Archive | 0 | 08-18-2000 03:47 AM |
Help! is this the "hesitation problem"? | fuzzbox | Technical Forum Archive | 5 | 05-16-2000 12:44 AM |
