01-30-2006, 04:19 PM | #26 | |
Member#: 45790
Vehicle:2006 Corvette C6 Z51 SUPERCHARGED |
"ok, i started my jdm sti on 110 and it deffenetly made a difference in power as well as no knocking, but the only way of course to get it is in a can. but, 110 is so much hevier than 93octane, wouldnt it just sink to the bottem of the tank if you mixed it??? " Does the alcohol in your beer rise to the top too? Alcohol is much less dense than water... "You gotta pay tax on race gas? In OH. we don't pay tax cuz' the fuel is not "legal for highway use"." Nope, no taxes at all... Citgo gas stations carry 110 on pump here because boats, snowmobiles, go karts and some off road vehicles run it, and it is "for off road use only". I wonder what the fine would be for getting caught pumping that into your car...
01-30-2006, 04:27 PM | #27 | |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
01-30-2006, 04:41 PM | #28 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
01-30-2006, 07:10 PM | #29 | |
Member#: 45790
The 100 octane is non leaded, right? That's the only downside of running 110... I don't have any cats but I know the lead is going to cost me a $70 O2 sensor some time down the road... Oh well... The power is worth it! |
01-30-2006, 08:08 PM | #30 |
Member#: 1185
Vehicle:I flap my gums and now I'm a specialist |
JDM rating is 280PS . That works out to something like 276 hp !
01-30-2006, 08:37 PM | #31 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
there are a few pumps local to where I live that sells 100 octane unleaded at the pump...then several places to buy higher race gas...
01-30-2006, 08:47 PM | #32 |
Member#: 41049
South East
Vehicle:2010 Impreza WRX KTM 250sx |
Actually we have 99 OCTANE in the UK being sold at Tesco. I believe we may get Shell's Vpower soon to compete with it.
01-30-2006, 11:56 PM | #33 |
Member#: 45790
99RON most likely... Probably 95RON+MON/2 equivalent here in the US?
Some states get 94... I know we did in Vermont at Sunoco... |
01-31-2006, 12:40 AM | #34 |
Member#: 70256
RMIC
Vehicle:2000 STI V2 Swapped Silver |
I have been doing my research and am wanting to do a jdm swap (V1-5, whatever I can get my hands on) and am concerned about the tuning issues. I plan to use this car as a daily driver and Colorado has 91 at the pumps. Would it be possible to run say something like a cobb accessport so I can have a 91 map, then revert back to something possibly higher when I wanted to splurge on 100+ octane or is this not possible with the jdm ecu?
This is the only issue I truly am confused about. |
01-31-2006, 02:33 AM | #35 |
Member#: 45790
Starting at V5 there is exactly one place in all of this continent (south central and north America) that can reprogram your ECU; Lachute Subaru in Quebec Canada. They use ECUTEK99 and appearently there is a 20% chance that your ECU will be ruined in the (expensive) reflash process. I hear Yoshio from Japanese Automotive in Toronto can do it too, but a lot of people don't like him for some reason.
Accessport won't work. Your options are either standalone (Link EMS and Apexi Power FC are direct ECU replacements, otherwise there is Hydra and the like) or piggyback (Unichip). Another option could be a boost controller; run reduced boost when on low octane? That said, Miles from FinelineImports tells me that they run all their JDM Swaps on california 91 Octane gas... He knows a LOT more about JDM than I ever will, so I won't argue with it, but you will be losing power. |
01-31-2006, 02:38 AM | #36 |
Member#: 43916
RMIC
its not too bad, but you will lose power, which is a mute issue at the moment.
you can also take into account that out air is thinner, meaning the need for slightly less fuel, not a huge difference. side note: i myself am in FoCo for the time being.... |
01-31-2006, 02:40 AM | #37 |
Member#: 45790
Doesn't running an engine at higher altitudes require more octane?
01-31-2006, 03:41 AM | #38 |
Member#: 43916
RMIC
dont think so.
reason being less air. same as dropping boost, dont need as much fuel support. because there is less air, the knock index (octane) wouldnt need to be as high. |
01-31-2006, 04:15 AM | #39 |
Member#: 45790
01-31-2006, 10:06 AM | #40 |
Member#: 70256
RMIC
I love the altitude for running my Camaro (well other than the huge power loss), I can get away with a 40+ degrees of timing @ wot plus the bottle and no problems. I know how to tune GM stuff, but Subaru is all new to me.
So I suppose I can just let the computer adapt to the 91 and if I don't like the peroformance save up for a link. Thanks for the replies! ps, if you see a silverthorne coupe with for sale tags and a v5 wing that would be me. |
01-31-2006, 11:07 AM | #41 |
Member#: 832
RMIC
kbahus,
As Tyler mentioned, we can get away with lower octane up here in Colorado. This is why we get 87 instead of 89. 91 octane will be fine for a JDM swap. If you want to go the reflash route, the way to do it is get a JDM longblock and wire the car as a USDM WRX. Then you can have Harvey at Super Rupair do an ECUtek flash for you on their dyno down here in Boulder. I think the only reason more people don't do this is because of added cost. Personally, I think it is the best approach to get both maximum power on our local gas AND have a car that is OBD-II compliant. I know many don't care about it, but I am all about OBD-II compliance. It is spreading and more and more places are testing these days. when I build a car, I want to be able to have it for 5+ years or easily sell it. If it clears OBD-II emissions, you have a lot more leeway and don't risk waking up one morning and having your car illegal. Here in Boulder, they plugged my RS in last time I had to emissions test... |
01-31-2006, 11:24 AM | #42 |
Member#: 45790
I agree with you 100%, but unfortunately we are talking about a very significant additional cost here... You would need everything for a JDM swap, plus a USDM wiring harness, ECU and a completely custom reflash involving a fair amount of dyno time...
The wiring would also be quite a bit harder and if you were swapping, say, a V5, it would be Check Engine Light Codes galore (no EGT, no second O2 sensor, different recirc, no tumbler valves, etc). |
01-31-2006, 11:32 AM | #43 |
Member#: 832
RMIC
You wouldn't need a complete JDM swap, you would just need a JDM lonblock. Guys like Gruppe-S have longblocks without all the rest quite frequently. Then you buy a WRX front cut/complete swap, and sell off everything you don't use, like the Ej205 longblock. EGT and O2 sensor are in the plumbing, and can easily be added And reflashes can delete TGV's(or you could use the EJ205 intake). Not sure what you mean about the recirc...
As for the reflash, it wouldn't take any more time than any other reflash. And you could absolutely run the engine on the stock ECU programming for the Ej205 if you needed to save up the $400 for the ECUtek. It would proably run you about $1000-2000 more to take this approach. It's really a personal decision if that is worth it to you or not. I am not going to sit here and argue with you about it. I am just making people who are interested that it absolutely can be done and it won't break the bank to do it unless you are one of those people who is trying to pull off a swap for $3000 or less... |
01-31-2006, 12:05 PM | #44 | |
Member#: 45790
And, for the record, unless you are swapping a really old engine (V1/V2?), it can't be done |
01-31-2006, 12:45 PM | #45 | |
Member#: 41049
South East
What part of we have 99 OCTANE didnt you understand? You think I dont know the difference between RON and OCTANE? Sure we have Shell's Optimax that is 98RON but we now have Tesco's 99 OCTANE. There is no error on my part. |
01-31-2006, 01:08 PM | #46 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
we can get 100 or 102 at the pump in ohio, and 117 in 5-50 gal. off road use drums. would it be better to just run the no lead pump gas because of the sensor failures? it's on the way to the strip too, which helps! and how long should it take to reset your computer? do you have to step on the brakes(to discharge capacitors) like some cars to drain the system fully? thanks! -keith
01-31-2006, 03:25 PM | #47 | |
Member#: 45790
I fail to see the need for this attitude of yours, and you are still wrong. If you are not in the US, where it is assumed that "Octane" means (Ron+Mon)/2 as per government standarts, you have to say "99 RON", as I clarified. |
01-31-2006, 04:06 PM | #48 | |
Member#: 33782
the lower octane sufficing is mearly a side effect of less actual compression happening...less friction etc... |
01-31-2006, 05:10 PM | #49 | ||
Member#: 43916
RMIC
01-31-2006, 05:43 PM | #50 |
Member#: 33782
wow, time to bring that to my IC engine's prof...cause he just about flipped during a discussion when a kid said that...
Is Low Octane Gas Bad? | bmw5002 | Newbies & FAQs | 55 | 07-19-2006 12:20 AM |
Low Octane gas = CEL? | chrisdeaner | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-05-2006 08:56 PM |
What's up with 92 Octane gas? | REXMASS | New England Impreza Club Forum -- NESIC | 28 | 12-03-2004 07:45 PM |
stock 02 WRX with low octane fuel | BrettS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 11-19-2004 08:09 AM |
lose power with Turbo back silencer? | Electronsmurf | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-13-2003 07:26 PM |
