Welcome to the North American Subaru Impreza Owners Club Tuesday January 19, 2021
Old 12-17-2020, 12:59 PM   #426
Kostamojen
Member#: 2272
1999 2019 Macan 4cyl
93 FWD Base Imp WRX swap
Could just be the body kit they are testing. You can tell in the video its the same engine. Doesn't even have the better brakes.
Old 12-18-2020, 03:59 PM   #427
kayen
Member#: 57287
2002 Bugeye STi
MY07 WRB FXT
Yeah you can see a lip, side sill skirt and rear bumper skirt from that pic.
kayen is offline   Reply With Quote
Old 12-18-2020, 04:02 PM   #428
dwf137
Member#: 161333
18 Highlander
Yami XSR
Agreed, that looks like all it is. But why they need to "test" those components on the track is a little confusing? Are they really expecting a lip kit to make any measurable difference in track times?
dwf137 is online now   Reply With Quote
Old 12-18-2020, 04:04 PM   #429
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
That kit would look good on a black BRZ. It did on mine.
Overall I like this BRZ, but I think the refresh will look better. Just my gut feeling.
chanomatik is online now   Reply With Quote
Old 12-18-2020, 06:11 PM   #430
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
It could be a start to tuning for a tS or STI Sport trim. Or even some accessories parts testing. In addition to the body pieces, there could be some suspension, brake pads, braces upgrades.
subyski is offline   Reply With Quote
Old 12-19-2020, 01:43 AM   #431
chanomatik
Member#: 159474
2017 Impreza Sport
More pics of the GT300, this time driving on the track.
https://car.watch.impress.co.jp/docs/news/1296026.html
Old 12-19-2020, 04:39 AM   #432
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
It's probably just a high speed NVH test. You don't want to release a factory body kit that hums or whistles (or starts flapping) at 100mph.
Old 12-19-2020, 07:28 PM   #433
kayen
Member#: 57287
2002 Bugeye STi
MY07 WRB FXT
Yeah, you wouldn't want that happening. Looks at Toyota Supra mirrors... Damnit. Lol
Old 01-05-2021, 09:51 AM   #434
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
https://car.watch.impress.co.jp/img/car/docs/1296/026/100_o.jpg
it's a good thing there aren't any homeless people on race tracks trying to clean windows, that side exit would be pretty dangerous, and piss off the homeless guy enough to where he'd probably try and break off your side mirror.
Old 01-13-2021, 11:05 AM   #435
Skylab
n00b Moderator
Member#: 4263
Skylab is offline   Reply With Quote
Old 01-13-2021, 02:01 PM   #436
BeepBoop
Member#: 496462
I suppose this might not be as true any more with how "perfectly" built (meaning not over-built like a 2jz, and not underbuilt like some of the weaker engines) engines are, but the reason I've always wanted a turbo'd motor in the car is because turbo engines are historically much easier to crank up the power over stock.
All the "good" turbo motors are just a tune away from being 25% over stock. Usually only like $3k in bolt-ons away from a 50% power increase. To get those types of gains on NA motors, you usually have to ADD a forced induction system of some kind (like $5k baseline) and the motor usually has to have internal work done if you want to push anything more than pleb levels of boost to get to that 50%+ power improvement.
BeepBoop is offline   Reply With Quote
Old 01-13-2021, 02:37 PM   #437
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
For me it depends on the manufacturer, engine & platform I'm dealing with; but in general in todays world, NA-4<FI-4<NA-6<FI-6<NA-V8<FI-V8, but I honestly prefer a winder of an NA engine over a FI counterpart (Eg. GT350 Voodoo over a blown V8), but there are platform considerations there as well; I'd rather a GT350 over a hellcat/demon/redeye challenger, and over a GT500, but if the GT500 came with a manual, and in higher production numbers, I might prefer that.
For Subaru though, it had better have a turbo; their engines & tunes suck, at least with a turbo the aftermarket will swoop in to fix the garbage tune. IF the FA24 in the BRZ is a winder that's fine, but I don't think it's going to like to be wound out.
I think the ND2 Miata is an example of a good NA I4 that fits the platform, I didn't think the ND1 NA I4 was enough for it.
Sid03SVT is offline   Reply With Quote
Old 01-13-2021, 03:36 PM   #438
4S-TURBO
Member#: 67807
V^V justrememberall
capswhenuspellyomansname
It's just disappointing that a Subaru/Toyota partnership could not produce an engine that exceeds the specs of the Honda F22c. After deciding no boost and upping the compression with nearly a half liter more displacement compared to the FA20, why not target the Honda motor? They have better fueling enabling super high compression along with higher displacement to work with. They don't need to shoot above an 8k redline with that long stroke to still have a wide power band.
We will drive them and compare to the FA20, but we should be comparing to the great NA 4 bangers that came before. Power output isn't end all be all, but c'mon.
Old 01-13-2021, 03:43 PM   #439
JP Chestnut
Member#: 504432
It's highly predictable. Subaru isn't a best in class engine manufacturer like Honda was. Combine that with ever more stringent emissions requirements and a lower MSRP (relative to the S2000) and you get the BRZ's engine. At least it's running direct and port injection. Every modern engine should, but few actually do.
JP Chestnut is offline   Reply With Quote
Old 01-14-2021, 09:17 AM   #440
DougNuts
Member#: 192568
2015 Outback 3.6R
2018 F150 3.5TT
Emissions is the most likely reason.
DougNuts is offline   Reply With Quote
Old 01-14-2021, 12:00 PM   #441
Pre
Member#: 139693
The F22c was absolutely gutless until VTEC. This produces more torque and much earlier in the powerband. Should be a better motor for actual driving.
Old 01-14-2021, 01:06 PM   #442
subyski
Member#: 202642
08 Impreza,80Vette
But you knew when VTEC kicked in....yo!
Old 01-14-2021, 01:55 PM   #443
BeepBoop
Member#: 496462
"Actual driving" only happens in the upper 1/3 of car's power-band IMO. What people engage in 99% of the time is "people moving" and completely unrelated to one of the most enjoyable activities on the planet.
Old 01-14-2021, 06:17 PM   #444
4S-TURBO
Member#: 67807
V^V justrememberall
"Hold its own" kicked in...y0
If there is any ANY hint an Ascent is quicker to x y z metric, engineering explained guy gone have more splainin to do.
Old 01-15-2021, 01:05 AM   #445
Pre
Member#: 139693
Nah, there is the thing called “midrange” maybe you have heard of it. I owned an AP2 and it didn’t have it.
Most hyped motor ever made in automobiles.
Old 01-16-2021, 08:15 AM   #446
Blktrax
Member#: 220971
2004 Impreza
Every Car Reviewers test drive segment;
“....the manuals are dying ... save the manuals....””....best dynamic feeling car ever....”
30 seconds later
“.....ugh not enough power to climb a small hill and pass at 60 in 6th gear, have to press petal and down shift 2 gears to pass......”
Blktrax is offline   Reply With Quote
Old 01-17-2021, 01:30 PM   #447
DeeezNuuuts83
Member#: 34406
2006 Evolution IX
graphite gray
30 seconds later
They always do that, with everything. The first thing that came to mind was when AMG replaced the supercharged 5.5 with the 6.2, I clearly remember a few publications commenting on how they liked it but missed the instant mountain of torque of the outgoing motor. But then when the 6.2 got replaced with the twin-turbo 4.0, publications then said that they missed the seemingly endless top-end of the 6.2.
DeeezNuuuts83 is offline   Reply With Quote
Old Yesterday, 10:20 AM   #448
Robert.Mauro
Member#: 521779
Smile I got to take a bunch of pics of the new 2022 BRZ... enjoy!
Hi everyone!
This past Friday, we started the 20th Annual 48hrs of Tristate Subaru Enthusiast Charity Drive for Make-A-Wish at Subaru of America HQ, where they allowed me the opportunity for an exclusive photo shoot of the new 2022 Subaru BRZ!!! I wish I had my CPLs with me - but I wasn't about to say no, because I didn't, lol! ***128514;
Anyway, I think it's a great refinement!!! I personally think they took the original design, made it a little sleeker, while maintaining some of the aggressive looks. And, I can't wait until they give me some time behind the wheel!!! I'd love to see what the FA24 can do!
Here's the picture gallery!!! Enjoy!!!
Click link for full gallery:
Facebook Posts
Robert.Mauro is offline   Reply With Quote
Old Yesterday, 12:30 PM   #449
deanstevenson
Member#: 388613
That looks great. Nice photos.
Thanks for sharing!
deanstevenson is offline   Reply With Quote
Old Yesterday, 12:41 PM   #450
4S-TURBO
Member#: 67807
V^V justrememberall
step 1: become ambassador
step 2: join NASIOC
