#426 |
Member#: 2272
BAIC
Vehicle:1999 2019 Macan 4cyl 93 FWD Base Imp WRX swap |
![]() Could just be the body kit they are testing. You can tell in the video its the same engine. Doesn't even have the better brakes.
#427 |
Member#: 57287
Vehicle:2002 Bugeye STi MY07 WRB FXT |
![]() Yeah you can see a lip, side sill skirt and rear bumper skirt from that pic.
#428 |
Member#: 161333
NWIC
Vehicle:18 Highlander Yami XSR |
![]() Agreed, that looks like all it is. But why they need to "test" those components on the track is a little confusing? Are they really expecting a lip kit to make any measurable difference in track times?
#429 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
![]() That kit would look good on a black BRZ. It did on mine.
Overall I like this BRZ, but I think the refresh will look better. Just my gut feeling. |
#430 |
Member#: 202642
RMIC
Vehicle:08 Impreza,80Vette 68 Impala, 15 SantaFe |
![]() It could be a start to tuning for a tS or STI Sport trim. Or even some accessories parts testing. In addition to the body pieces, there could be some suspension, brake pads, braces upgrades.
#431 |
Member#: 159474
NESIC
![]() More pics of the GT300, this time driving on the track.
https://car.watch.impress.co.jp/docs/news/1296026.html ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by chanomatik; 12-19-2020 at 07:46 AM. |
#432 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
![]() It's probably just a high speed NVH test. You don't want to release a factory body kit that hums or whistles (or starts flapping) at 100mph.
#433 |
Member#: 57287
#434 |
Member#: 26859
TXIC
Vehicle:of TXIC I also like (oYo)!!!! |
![]() it's a good thing there aren't any homeless people on race tracks trying to clean windows, that side exit would be pretty dangerous, and piss off the homeless guy enough to where he'd probably try and break off your side mirror.
#435 |
n00b Moderator
Moderator Member#: 4263
SCIC
#436 |
Member#: 496462
![]() I suppose this might not be as true any more with how "perfectly" built (meaning not over-built like a 2jz, and not underbuilt like some of the weaker engines) engines are, but the reason I've always wanted a turbo'd motor in the car is because turbo engines are historically much easier to crank up the power over stock.
All the "good" turbo motors are just a tune away from being 25% over stock. Usually only like $3k in bolt-ons away from a 50% power increase. To get those types of gains on NA motors, you usually have to ADD a forced induction system of some kind (like $5k baseline) and the motor usually has to have internal work done if you want to push anything more than pleb levels of boost to get to that 50%+ power improvement. |
#437 | |
Member#: 183032
NESIC
Vehicle:RWD Camry Pull me over red |
![]() Quote:
For Subaru though, it had better have a turbo; their engines & tunes suck, at least with a turbo the aftermarket will swoop in to fix the garbage tune. IF the FA24 in the BRZ is a winder that's fine, but I don't think it's going to like to be wound out. I think the ND2 Miata is an example of a good NA I4 that fits the platform, I didn't think the ND1 NA I4 was enough for it. |
#438 |
Member#: 67807
NWIC
Vehicle:V^V justrememberall capswhenuspellyomansname |
![]() It's just disappointing that a Subaru/Toyota partnership could not produce an engine that exceeds the specs of the Honda F22c. After deciding no boost and upping the compression with nearly a half liter more displacement compared to the FA20, why not target the Honda motor? They have better fueling enabling super high compression along with higher displacement to work with. They don't need to shoot above an 8k redline with that long stroke to still have a wide power band.
We will drive them and compare to the FA20, but we should be comparing to the great NA 4 bangers that came before. Power output isn't end all be all, but c'mon. |
#439 | |
Member#: 504432
![]() Quote:
#440 | |
Member#: 192568
Vehicle:2015 Outback 3.6R 2018 F150 3.5TT |
![]() Quote:
#441 | |
Member#: 139693
![]() Quote:
The F22c was absolutely gutless until VTEC. This produces more torque and much earlier in the powerband. Should be a better motor for actual driving. |
#442 |
Member#: 202642
RMIC
#443 |
Member#: 496462
![]() "Actual driving" only happens in the upper 1/3 of car's power-band IMO. What people engage in 99% of the time is "people moving" and completely unrelated to one of the most enjoyable activities on the planet.
#444 |
Member#: 67807
NWIC
![]() "Hold its own" kicked in...y0
If there is any ANY hint an Ascent is quicker to x y z metric, engineering explained guy gone have more splainin to do. |
#445 | |
Member#: 139693
![]() Quote:
![]() Most hyped motor ever made in automobiles. |
#446 | |
Member#: 220971
South East
Vehicle:2004 Impreza |
![]() Quote:
“....the manuals are dying ... save the manuals....””....best dynamic feeling car ever....” 30 seconds later “.....ugh not enough power to climb a small hill and pass at 60 in 6th gear, have to press petal and down shift 2 gears to pass......” |
#447 | |
Member#: 34406
Vehicle:2006 Evolution IX graphite gray |
![]() Quote:
#448 |
Member#: 521779
![]() Hi everyone!
This past Friday, we started the 20th Annual 48hrs of Tristate Subaru Enthusiast Charity Drive for Make-A-Wish at Subaru of America HQ, where they allowed me the opportunity for an exclusive photo shoot of the new 2022 Subaru BRZ!!! I wish I had my CPLs with me - but I wasn't about to say no, because I didn't, lol! ***128514; Anyway, I think it's a great refinement!!! I personally think they took the original design, made it a little sleeker, while maintaining some of the aggressive looks. And, I can't wait until they give me some time behind the wheel!!! I'd love to see what the FA24 can do! Here's the picture gallery!!! Enjoy!!! Click link for full gallery: |
#449 |
Member#: 388613
#450 |
Member#: 67807
NWIC
![]() step 1: become ambassador
step 2: join NASIOC |
