Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2020
Old 05-17-2020, 06:22 PM   #1
streetlight1080
Member#: 511105
Default 2011 wrx struts koni yellow or feal? any advice or first hand experience?
I have been looking to upgrade the suspension on my 2011 wrx for some time, I am only interested in some fun daily driving, improving handling a little and keeping a comfortable ride as well. I am sure the koni yellow struts are great however the only ones available are meant for 08-10 models which have a lower perch and therefore will lower the car in addition to the springs I combine with them and I feel it could be to low. Not to mention you have to drill out the rear upper strut mount holes a little. To install the feal fixed perch struts I would need to remove the spring seats from the oe shocks and put them on the rear feal struts. I have never used Feal suspension nor do I know anyone personally who has. Is there not a good strut that just simply fits as it should? Does anyone have any experience or advice on either set up or even a better solution maybe?
streetlight1080 is offline   Reply With Quote
Old 05-22-2020, 01:27 PM   #2
kingsalami
Member#: 206257
2009 WRX 5-door
If you're interested in fun DD, try a set of Konis with your stock springs. I've used a bunch of different spring combinations with Konis on my DD '09 WRX, and finally settled on 2010 STI SE springs (250# front & rear). Installing the Konis wasn't that tough, and I've got about 100K trouble-free miles on 'em so far.
Post #7: https://forums.nasioc.com/forums/sho....php?t=2809125
kingsalami is offline   Reply With Quote
