Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Mid Atlantic Impreza Club
Old 04-30-2018, 11:09 PM   #1
PERU WRX
Member#: 387555
Default 2007 Legacy Gt Help!
Hey Nasioc i need your help iím having problems with my 07 legacy gt and i know this isnít the right forum but because they have the same engine as the wrx and maybe iíll try some advice and help so the problem is the car starts for like a second and then dies and i use the scan and no engine codes and i replace the spark plugs and coils but still the same the last owner says the car overheat and throw multiple missfire but now starts and dies i check the coolant reservoir and it looks fine any comments or suggestions would be greatly appreciated THANKS.!
PERU WRX is offline   Reply With Quote
Old 05-02-2018, 11:52 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I suggest punctuation. I also suggest telling us the full history. Did the car run fine when you bought it? When did the problem start? Had you changed anything on the car prior to the problem starting? Had you done anything to investigate and/or correct the problems the previous owner had reported?
Finally, I suggest posting in the appropriate technical forum (https://forums.nasioc.com/forums/forumdisplay.php?f=91) for assistance.
Old 05-02-2018, 07:55 PM   #3
PERU WRX
Member#: 387555
Thanks for the advice
