Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 09-23-2007, 10:11 PM   #1
tedstriker
Member#: 156039
Default normal driving then CEL and Limp mode
Hi Guys,
I have a 2004 sti that is stock. I bought if from a guy who had a big turbo on it plus all the supporting mods. I drove it 1000 miles to take it home, and it ran fine, no problem.
I was driving today, normal, spirited driving, nothing crazy, when the car suddenly goes into limp mode, with the CEL and cruise light flashing as well.
I parked and went inside for a while. WHen I got back into drive the CEL was gone, but withing 30sec of driving, it came back on.
Any idea what this could be? the owner had 06 wrx fuel rails and injectors on it, instead of the stock sti. as well, I just had day time running lights installed. could either of these be the culprit? Any help would be appreciated, as I'm pretty stressed about my car having problems now. Thanks.
tedstriker is offline   Reply With Quote
Old 09-23-2007, 10:15 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
no one can help you until you
(a) get the code scanned and
(b) list your mods in detail
UkNuck is offline   Reply With Quote
Old 09-23-2007, 10:28 PM   #3
tedstriker
Member#: 156039
I'ts at the dealer now, I'll know more about the specific code tomorrow. the mods are:
forged wiseco pistons 100mm
balanced crank
supertec springs
WRX fuel rails and injectors, walpro 255
that's about it. I was driving normally, with a few faster accels.
what codes can trigger limp mode? lean, over boost, or could it be something different?
It was just serviced, where they hacked into the wires to add the day time running lights...... any ideas would be greatly appreciated.
Old 09-23-2007, 11:30 PM   #4
tedstriker
Member#: 156039
anyone...?
Old 09-24-2007, 12:22 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
doesn't even bother to speculate... anywhere from loose gas cap to engine about to blow. go to bed, get the code read in the morning!
Old 09-24-2007, 10:39 PM   #6
tedstriker
Member#: 156039
Never got the exact code from the dealer, but their are 2:
1. for the TGV valves
2. for the TGV valve sensor?
any ideas?
Normal driving then CEL and Limp Mode tedstriker Warranty Issues & SOA Problems 8 09-29-2007 11:59 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 12:29 PM
AVCS and limp mode mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-21-2004 07:14 PM
How to: Drive your car in Limp Mode DeusExMachina Normally Aspirated Powertrain 9 02-03-2003 07:52 PM
EGT's and Limp Mode at Track Event TBreu007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-16-2002 02:09 PM
