Welcome to the North American Subaru Impreza Owners Club Tuesday April 24, 2018
Old 04-08-2008, 08:34 AM   #1
Lazyxturb0
Member#: 107682
03 WRX Catless
Default 04 sti wheel bearings into 03 wrx
does anyone know if you can swap an 04 sti's front and rear wheel bearings in an 03 wrx? and if so, would it be considered an upgrade? im planning to do the brembo conversion soon, and was thinking about swapping out the bearings with the 04 sti ones at the same time. i tried searching and didnt find much. any help/comments are welcome!
Lazyxturb0 is offline   Reply With Quote
Old 04-08-2008, 08:37 AM   #2
Crawdads
Member#: 30907
SWP GDB-G
The upgrade would be 05+ STi knuckles/hubs. (aka 5x114.3 hubs)
THe 5x100 stuff is all the same.
Crawdads is offline   Reply With Quote
Old 04-08-2008, 12:04 PM   #3
XmanSTi
Member#: 65206
1986 Brat
Red
same, but swapping wheelbearings is not really going to work. They typically don't survive the pressing out process and doing all that work for already worn bearings doesn't make a lot of sense. IMO
XmanSTi is offline   Reply With Quote
Old 04-08-2008, 08:38 PM   #4
Lazyxturb0
Member#: 107682
03 WRX Catless
ah icic. the knucles and hubs are gonna cost too much.. so im better off just replacing them with 03 wrx ones?
Old 04-08-2008, 10:56 PM   #5
Web Foot STi
Member#: 39086
2004 STi
Yup, new stock parts are your best bang for the buck. $900 bill for the 6gun front hubs. Only worth wild if you track your car.
Web Foot STi is offline   Reply With Quote
Old 04-09-2008, 01:03 AM   #6
bon1210
Member#: 113657
2002 subaru wrx
white
you can use 06 wrx parking plate
bon1210 is offline   Reply With Quote
Old 04-09-2008, 01:27 AM   #7
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Swapping to STi rear hubs (which are better) requires many changes including axles, knuckles, brakes.
Not sure how much larger the 04 STi front bearing is vs the WRX.
javid is offline   Reply With Quote
Old 04-09-2008, 09:50 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
No, it's not - wrong.
The rear wheel bearings on the STi are NOT THE SAME As other Impreza
Yes even the 2004 STi
Rear STi wheel bearing and.... rear bearing seals are NOT THE SAME as any other Impreza
to the OP
As suggested - just replace them with Stock OE parts
Have someone with experience repack the new bearings and do the install
these suckers can blow again if not installed correctly.
Jamie
Old 04-09-2008, 10:33 AM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
Thanks Subiegal, how about the fronts, are they identical tho?
strohausii is offline   Reply With Quote
Old 04-09-2008, 10:47 AM   #10
SubaruGenuineParts
Member#: 82767
2002-2003 use different wheel bearings vs 2004
so no, they are not the same
front SEALS are the same but the BEARINGS are specific
Jamie Thomas
email---> Jamie at chaplins dot com
www.subarugenuineparts.com
Be sure to check our iTrader feedback!
Yes....We Take Subaru Bucks!
SubaruGenuineParts is offline   Reply With Quote
04 sti drivetrain swap into 03 wrx please help!!!! mike739wrx Transmission (AT/MT) & Driveline 6 03-15-2010 03:36 PM
04 STI 6 speed into 03 WRX and vice versa I'm Slow Transmission (AT/MT) & Driveline 14 08-10-2009 07:52 PM
04 STI hubs work with 03 WRX struts, 5X100 wheels? tolnep Transmission (AT/MT) & Driveline 3 05-31-2009 10:25 PM
Another 04 STi wheel bearing ? generalee69 Brakes, Steering & Suspension 5 05-25-2007 06:27 PM
04 STi Wheel Bearing Tgui Brakes, Steering & Suspension 8 01-20-2005 10:21 PM
