Welcome to the North American Subaru Impreza Owners Club Thursday August 16, 2018
Old 12-28-2009, 04:30 PM   #1
2.5izzy02
Member#: 181930
Unhappy Limp mode, but no CEL?
2002 WRX, won't rev past 4000-4500rpm.
Basically you hit the throttle to go past those rpms and it "bogs" as if it's being choked.
What would this be caused by? The car was previously hooked up to an AP running Stage 2 (which I no longer have).
I figured it was electrical, wires, or even the MAF sensor?
Any help would be greatly appreciated.
2.5izzy02 is offline   Reply With Quote
Old 12-28-2009, 04:33 PM   #2
JSarv
Member#: 163445
l33t *******
[email protected]
Your TGV's are not working properly.
-Jerod
JSarv is offline   Reply With Quote
Old 12-28-2009, 04:41 PM   #3
2.5izzy02
Member#: 181930
What would be the fix for this? The car ran fine, but then we had some foggy weather and ever since then the car has been misbehaving.
Old 12-29-2009, 02:48 AM   #4
2.5izzy02
Member#: 181930
Can someone direct me to a "fix thread" or something?
I searched, but couldn't find anything relevant.
Old 12-29-2009, 02:56 AM   #5
Franks2308
Member#: 228793
2004 Z
no cel's huh? Wanna throw down a list of mods so we can see what you're working with?
Franks2308 is offline   Reply With Quote
Old 12-29-2009, 03:56 AM   #6
Haelan
Member#: 151045
2013 Subaru STI
CBP
I disagree about the TGV's. OP would most certainly have a CEL if one was not working properly.
Start with the basics: check for any pending codes in the ECU, pressurize the air intake tract and look for leaks.
Haelan is offline   Reply With Quote
Old 12-29-2009, 10:04 PM   #7
2.5izzy02
Member#: 181930
CEL comes on for P0546 (EGT code), but nothing else.
Performance mods: full catback, weapon R intake, BOV, aftermarket intercooler...
Pretty sure that's it. I've been told MAF sensor, fuel injectors, fuel pump and now TGV.
Old 12-30-2009, 08:38 AM   #8
S7un7
Member#: 181709
2004 WRX Stage II
Did you replace the stock uppipe with a catless or gut the stock one? That code is related to the uppipe. There could be a serious problem or the sensor is bad. An easy fix is to unplug the EGT sensor and put a 2.2 K Ohm resistor in the end of the plug.
If you ever go with a TBE, I would suggest removing the sensor from the uppipe and gutting it (or replace with a catless) so it does not kill your turbo.
S7un7 is offline   Reply With Quote
Old 12-30-2009, 05:53 PM   #9
2.5izzy02
Member#: 181930
So is the EGT code related to it bogging at 4000-4500rpm?
It didn't seem like it was because it started happening when it became foggy.
That's why I thought it was an electrical problem.
Should I just take it to a dealership for a diagnosis?
Also, I never did the catback mod/install, so I have no clue what's on there.
Old 12-30-2009, 06:31 PM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
My guess is your MAF is extremely dirty or shot.
The EGT sensor will cause your vehicle to transition to open loop if the temperatures get too high. This should not cause your bogging issue.
Old 12-30-2009, 06:37 PM   #11
2.5izzy02
Member#: 181930
Well, the more I think about it...
MAF would make sense because that should be on my intake correct?
The weapon R intake I have is fairly dirty and the plastic on the wheel well is missing, so the sensor might have been damaged if the intake sucked in crap from there being an opening there the size of a basketball.
Old 12-31-2009, 10:50 AM   #12
quazimoto
Member#: 70395
The Weapon-R intake is also complete garbage and isn't helping the situation with the pos foam filter they use.
quazimoto is offline   Reply With Quote
Old 01-14-2010, 09:18 PM   #13
2.5izzy02
Member#: 181930
Car is fixed, quite simple actually.
I disconnected the battery (resets the ECU) and now the car runs very nicely.
Still gets the EGT code mind you...
Also returned the intake to stock before I reset it, so that could have helped a bit.
Old 01-14-2010, 09:42 PM   #14
Haelan
Member#: 151045
2013 Subaru STI
CBP
Edit: Missed the part that you swapped the intake. That was probably the true reason for your issues.
Old 04-09-2014, 12:50 PM   #15
timandally
Member#: 364828
2002 wrx
metalic maroon
I fought for two months trying to figure my car out. I put an accessport on the car and it stopped revving past 4500-5000 rpm. Tried everything. Found out that the ecu wasn't recognizing my boost control solenoid. It was tested and fine. The thing that was eventually learned was I unplugged the bcs turned the car on, reved it as high as it would go(5000) a couple times, then turned it off. I plugged the bcs back in and turned the car back on and it revved to redline smooth as ever. I am no expert but countless hours if research on these forums with trial and error worked for me this time
timandally is offline   Reply With Quote
Old 04-09-2014, 05:32 PM   #16
TomRex
Member#: 163243
you don't need to resurrect every thread that is remotely similar because you found a solution that worked in your case.
TomRex is offline   Reply With Quote
Old 04-09-2014, 05:40 PM   #17
timandally
Member#: 364828
2002 wrx
metalic maroon
See, if I dindn't the next guy looking for help or information would be stuck like I was. Working on your own stuff can be daunting and your glad to try someone's personal experiance. Most forums are personal experiance.
Old 04-09-2014, 06:53 PM   #18
pyrox
Member#: 345474
02 WRX
240sx 2jz GT4088R
^the next guy could use the search option and find his answer. if you keep resurrecting threads people that are actually looking for help on this section of the forum will not get help because some Monsieur. butt cheeks resurrected 2 pages worth of old threads.
pyrox is offline   Reply With Quote
07 wrx over boosted and went into limp mode... got 6 CEL codes now vhalin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 10-16-2008 11:08 AM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 12:29 PM
Only 6-7psi but no CEL AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-30-2002 09:12 AM
No boost but no CEL?? ideas? OBDii scanner help? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2001 04:18 PM
