11-12-2004, 04:12 PM | #1 |
Member#: 74525
1995 Legacy Headlight Wiring
I own a 1995 Legacy 2.2L. The headlight wiring is for lack of better term is melting. I was told there is an "aftermarket splice kit" available. DOes anyone know who is the manufacturer or where I can find this kit?
11-12-2004, 04:18 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
What type of headlight bulbs do you have? They should be either H4 or 9007. Your local auto parts store should have replacement connectors with wire pigtails that you can use to make a repair, just cut the old connectors off along with any melted wire and splice the replacement to the harness. Be sure to make good connections and insulate them well. Soldering and heat shrinking is the preferred method, butt-splices and electrical tape as an alternative.
After the repair is done be sure to use only stock wattage bulbs, use of aftermarket bulbs is the usual cause of harness/connector damage especially if the bulbs are higher than stock wattage. |
02 impreza headlight wiring issue | garinhash | Electrical & Lighting | 4 | 06-02-2010 12:49 PM |
Wiring an EJ22T ecu into a 1995 Legacy | Cstmboxermotorsports | Pre-2002 Factory Turbo Powertrain | 4 | 08-10-2008 05:17 PM |
1995 legacy headlight harness problem | apope709 | Electrical & Lighting | 0 | 12-17-2006 10:01 PM |
00-04 Legacy Headlight Wiring Diagram BE/BH | ryankenn | Interior & Exterior Modification | 0 | 07-07-2006 04:28 AM |
FS: 1995 legacy headlights (not JDM) | Benjamin Tang | Legacy Forum | 14 | 10-07-2005 11:46 AM |
