Welcome to the North American Subaru Impreza Owners Club Saturday October 23, 2021
Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 08-16-2020, 11:58 AM   #3201
steve30avs
Member#: 426821
Default TSB work not fully covered
Make: 2016 WRX CVT
Mileage: 74000km (46000mi)
Time Out Of Use: 2 weeks, can't drive for more than 30 mins at a time
Problem And Likely Cause: CVT fluid seepage, low power coming from a stop, lurching. TSB 16-103-16R should fix this.
Modifications: Radio
Submitted For Warranty Work (Yes/No): Yes
Reason Given For Denial: Work is covered, but CVT fluid not covered under warranty, despite needing to be drained to do the work
Your Story: I've noticed some fluid seepage in the transmission, similar to what's in TSB 16-103-16R. The car starts to lose power after driving for over 30 mins, which I saw on here could point to torque converter issues (lack of fluid from the seepage maybe).
I brought it into my dealer and they agreed that this issue fell under the TSB and that the work would be done under warranty.
6 hours later, on the phone, they mentioned that 'oh yeah, you'll need to pay $350 CDN for the CVT fluid when we reopen it'.
This doesn't seem right to me, as they would obviously have to drain the fluid to do the resealing work, so you think it would be covered.
On the WRX CVT Facebook group, most responses have said this is indeed the dealer trying to rip me off, but the other Canadian also mentioned he had the same issue and had to pay, in another province too.
Any thoughts?
steve30avs is offline   Reply With Quote
Old 08-16-2020, 12:06 PM   #3202
Supraru
Member#: 23313
99' 2.5Rs
black
Originally Posted by steve30avs View Post
Make: 2016 WRX CVT
Any thoughts?
I’m sure Canada does some things different but in the USA if we were performing a tsb and was done as a warranty job everything is covered.
Supraru is offline   Reply With Quote
Old 01-22-2021, 10:49 PM   #3203
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
Default Warranty issues
I curious on what i should expect in the coming days. Just sent my 2019 sti to the dealership. At 20k miles it looks like i either spun a bearing or broke a rod. Never raced, daily driven, but i have an aos and an intake. So i suspect it might be a battle to have this covered under warranty.
Rtec94 is offline   Reply With Quote
Old 01-23-2021, 07:50 AM   #3204
Supraru
Member#: 23313
99' 2.5Rs
black
One of two things here. Simply having an intake on your car should deny you. Subarus tuning from the factory when you throw on an intake makes it run lean. So you either had the intake on and didn’t do your research to realize you need a tune too or you also have a tune and aren’t admitting it. Either way you’re probably screwed. Maybe you’ll get lucky but I doubt it.
Old 01-23-2021, 04:47 PM   #3205
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
No i had an AP on it, cant run intake without it. Talked to the dealership, and they seem pretty understanding. We will see how it plays out. I was honest with the service rep, and i think that went a long way.
Old 01-23-2021, 05:02 PM   #3206
Supraru
Member#: 23313
99' 2.5Rs
black
So then why are you lying on here? You said you had an AOS and intake. Nothing of a tune. If your tune was on there you have to call in to Subaru to verify your cid and cvn numbers. If it doesn’t match more than likely your going to be denied. If you removed the tune you’re clearly hiding something and either way a a mod report gets filled out.. Like I said originally maybe you get lucky and the dealership doesn’t care. If you came to my dealer you’d probably be denied.
Old 01-29-2021, 07:24 PM   #3207
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
Default Supraru your funny
Why am i lying on here?!? You obviously have something wedged firmly up your butt. I asked some simple questions and got alot of great answers none of which came from you. I didnt lie to the forum nor to the dealership. Im sorry im not obviously as intelligent when it comes to subarus as you are. Its my first 4 banger and first turbo car ever. Now granted im pretty old at 41. But your god complex can go. The dealership is going to warranty the engine. And i made it very clear how thankful i was about it. It will have the stock parts put back on and will keep it that way knowing what i do now about how temperamental the engines are now. Hope you have a great day, and please see your proctologist...
Old 01-29-2021, 07:49 PM   #3208
Supraru
Member#: 23313
99' 2.5Rs
black
While you were making it sound like you baby the car you conveniently left out you were tuned. Hence my “lying on here” comment. You clearly left it out for a reason because clearly you have an intake and know it needs to be tuned. So why did you leave that part out? I assumed because you wanted to sound like you were innocent in the matter.
Old 02-07-2021, 11:45 AM   #3209
leblancc_99
Member#: 61520
2000 impreza
Make: 2017 Legacy
Mileage:51000 miles
Time Out Of Use: 6 days
Problem And Likely Cause: Clutch disk worn out
Modifications:
Reason Given For Denial: Clutch is a wear item, pilot bearing not covered under drivetrain warranty
Your Story: At first I suspected an oil leak from the engine or the gearbox to the clutch compartment but the picture showed that the clutch was 100% dry and not contaminated.
Turns out that the clutch disk was worn out. The technical dvisor tells me that the traction control of the Gen6 slips the clutch and it is the reason why he clutch wears faster
I have many manual cars in my life and I never have to change a clutch before 100k miles
anybody ears of that story before?
leblancc_99 is offline   Reply With Quote
Old 02-19-2021, 08:33 PM   #3210
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
What? So the traction control operates the clutch pedal when activated...?
Originally Posted by leblancc_99 View Post
Make: 2017 Legacy
Mileage:51000 miles
Modifications:
murrdogg24 is offline   Reply With Quote
Old 08-08-2021, 03:03 PM   #3211
Lone Wolf 75
Member#: 2221
2018 Subaru WRX
Lapis Blue Pearl
Make: 2018 Subaru WRX
Mileage: approx. 42,000
Time Out Of Use: None, took dealer 1 week to perform fix
Problem And Likely Cause: Faulty oil hoses to turbo as indicated in TSB 11-195-20
Modifications: Cosmetic only - JDM shift trim, armrest extension, badging color
Submitted For Warranty Work (Yes/No): Yes - Powertrain
Reason Given For Denial: TSB and parts (turbo hoses) not covered under powertrain warranty
Your Story: I noticed a small oil leak on my garage floor a few weeks ago. Inspected underneath the car and found oil under the front of the engine, passenger side. Took it to the dealer with the expectation that the repairs would be covered under the Powertrain warranty. Dealer informed me that the repair would cost around $475, and they would have to call Subaru to see if the repair was covered under the powertrain warranty. Claim was denied by Subaru and the dealer charged me $486 for the repair. I am currently contesting the claim - is the turbo not part of the powertrain?
Lone Wolf 75 is offline   Reply With Quote
Old 09-27-2021, 08:38 PM   #3212
badmambajamba
Member#: 480187
2018 WRX
Crystal Pearl White
Mileage: approx. 26000
Time Out Of Use: Dealership had for 1 week
Problem And Likely Cause: Bent pressure plate
Modifications: wheels, shifter bushing
Reason Given For Denial: They covered everything under warranty
Your Story: I heard a ticking sound coming from my clutch, the ticking sound would stop once I Started using my clutch. The car drove perfectly ok, that ticking sound bothered the crap out of me though. I thought it was a bad throwout bearing so I took it into the dealership. They took it apart and said a couple of my pressure plate forks were bent and put hot spots in my clutch and flywheel. The excess clutch dust got into the thowout bearing which caused it to start making noise. The dearlership replaced the clutch assembly, flywheel and throwout bearing at no cost to me.
badmambajamba is offline   Reply With Quote
Old 09-27-2021, 08:38 PM   #3213
badmambajamba
Member#: 480187
2018 WRX
Crystal Pearl White
Old 10-08-2021, 07:50 PM   #3214
hackney1
Member#: 391014
'18 Prem. Perf Pkg
ISM
Default 2018 Outback, Engine Bucking
Name:
Make: 2018 Outback 3.6l
Mileage: 45k
Time Out Of Use: 1 day
Problem And Likely Cause: car hesitated and bucked on acceleration. No check engine light. Sounded like transmission issue but turned out to be a loose spark coil. The bolt was entirely back out and the coil came off the plug. Dealer repair completed.
Modifications: None
Reason Given For Denial: For some reason they believed I had work done on the engine
Your Story: The engine was never touched, changed oil and filters, that's all! Total repair cost $250, it does not seem to be worth fighting about warranty. But it was obviously a Factory workmanship issue
hackney1 is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 143 07-23-2020 06:21 AM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 58 10-19-2019 04:03 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 97 09-27-2019 12:46 PM
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 146 03-02-2019 12:31 PM
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 71 11-14-2018 08:18 AM
