Welcome to the North American Subaru Impreza Owners Club Sunday May 9, 2021
Old 10-19-2007, 10:31 AM   #1
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Default BPV vacuum hose
I noticed that the hose that runs from my BPV to the blue T-connection has come off and I cannot find out where it went. For now, I have a very thin hose (barely fits over each fitting) connected in its place, but am wondering if anyone knows the size of the hose, or where to get a proper replacement.
If I remember correctly, the stock hose has fairly thick walls (to prevent collapsing under vacuum I believe), and is somewhat of an "L" shape.
Can anyone help me out here? I am worried the thinner hose may be hindering how the system operates.
Thanks,
Jeff
REXtard04 is offline   Reply With Quote
Old 10-19-2007, 02:02 PM   #2
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
ok, guess I'll just do a little test fitting on my own to fix the issue.
Old 10-19-2007, 02:15 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
I'm not sure of the size, but one option is to call a local Subaru dealer and order it. As long as you explain it's the hose from the BPV to the intake manifold they should know what you're talking about.
Haelan is offline   Reply With Quote
Old 10-19-2007, 02:55 PM   #4
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Yeah, thanks. Hard part is, my local dealership is full of monkeys who have no clue about anything. I went to buy a replacement wheel well liner, even showed the guy ON my car what I was referring to, and he ordered the plastic under-tray, for a Legacy none the less.
I'll give it another shot, thanks for the response.
BPV vacuum hose? burtonboy759 Newbies & FAQs 2 01-30-2010 09:56 PM
FS: Perrin throttle body hose BPV return hose Marlons101 AKIC Private Classifieds 4 08-02-2009 04:20 AM
FS: OEM parts-BPV,MAF hose,Radiator hoses obsti2 Engine/Power/Exhaust 1 06-08-2008 11:45 AM
BPV Vacuum/Pressure Line Size? ocso639 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2007 12:12 PM
Brass Vacuum Hose Insert and T Vacuum Hose adapter blitzej20 Engine/Power/Exhaust 8 08-28-2006 08:35 PM
