Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 12-16-2014, 04:25 PM   #1
Mishimoto
Member#: 207954
Default Mishimoto 2015 STI Performance Air Intake!
Hey guys,
We are getting a bit further along in the build process for our 2015 STI intake. Follow the build process on our blog, or posted in this thread!
http://engineering.mishimoto.com/?cat=179
Mishimoto 2015+ Subaru STI Performance Cold-Air Intake System, Part 1: Project Introduction and Goals
Launch Edition Subaru STI in Mishimoto garage
Introduction
Our team is finally working on some cool components for the new 2015 Subaru STI! As you know, the 2015 STI is essentially a hybrid of old and new Impreza components. It features the newer body style paired with the trusty EJ engine, instead of the new DIT motor featured in the WRX. We won’t get into which is better or which we prefer, because we have nothing but praise for the updated chassis. Our team has spent a great deal of time with both vehicles, and we are impressed with how the STI drives, handles, brakes, and functions as a comfortable yet sporty sedan.
As you may already know, we developed an intake system for the 2015 WRX recently, and we had a ton of success producing some really nice power gains. We also offer an intake system for the 2008–2014 WRX/STI equipped with the EJ engine. You can see where we are going with this. Before we had a look at the STI, we already knew we had a chance to use some preexisting components from one or both of the intake systems we already offer. Not only would this speed up the development process, but it also means we would be using proven components. Before we set our engineers loose on this vehicle, we set up some guidelines for this particular project.
Project Goals
  1. Must be direct fit and require no vehicle modification.
  2. Must provide an increase in power output while maintaining safe AFRs on the stock ECU tune.
  3. Include all necessary components for installation.
  4. Fully test product to provide real-world data.
Yes, these goals are rather intuitive, but we will provide a bit more detail below.
Direct Fit
As with any aftermarket component, fitment problems are always a consideration. Nothing is more frustrating than trying to install your new component, only to find that it has been poorly designed and does not fit well. Our goal here is to develop an intake system that is a 100% bolt-on unit. Obviously you do not want to have to modify your brand new car, so this kit will have to fit without any cutting, drilling, or trimming. Our engineering team is no stranger to this requirement, so this should be an easy one.
Adding Safe Power
Intakes and applicable tuning have been hotly debated in the WRX/STI community for some time. If possible, we will design this intake to provide increased power on the stock tune, and we will test this unit extensively to ensure engine safety is not compromised. With our 2008–2014 intake setup, we achieved gains of 25 whp and 25 wtq on the stock tune with completely safe AFRs. We tested this unit in all forms of engine operation to be sure that our customers would not have issues. The same testing regiment would be needed for the 2015 STI intake we design.
Easy Installation
An intake upgrade should be a simple bolt-on modification. We want this process to be extremely simple and achievable, requiring only simple hand tools and a basic mechanical knowledge. Part of making this process seamless is the inclusion of all necessary components for installation, which is a top priority for this project.
Testing Data
The last goal is the most important. We conduct a ton of testing for each product that leaves the facility. If it was designed by Mishimoto, you can be sure that we thoroughly tested and perfected our design. Our in-house Dynojet will certainly help with this portion of development. Our thorough testing and presentation of test data are key elements that separate our company from the others.
Vehicle Evaluation
With our goals in place, it was time to pull the STI into our shop and start evaluating potential designs and product fitments. The kind owner of this 15’ Launch Edition was nice enough to lend his brand new vehicle for some testing. Check it out!
Launch Edition Subaru STI stock engine bay
First, we wanted to check fitment for a few of our 2008–2014 components to see if anything would cross over to the new chassis. After replacing the stock intercooler with the Mishimoto unit, we noticed that this low-mile 2015 vehicle is already showing some oil in the intercooler system … evidence that a catch can system would be a wise investment. We will be working on a direct-fit kit for the 2015 STI, similar to what we offer for the WRX.
Stock intercooler oil buildup
Stock compressor housing oil buildup
Next we slid our intercooler into position to check for any fitment concerns. We were happy to discover that our 2008–2014 STI intercooler is a direct fit for the 2015 model as well!
Mishimoto intercooler installed on 2015 STI
We also checked out a variety of other vehicle components and discussed the similarities and differences in an informative video review. Check it out below.
First Mock Up
Now, back to the project at hand! With all our other product test fitting out of the way, we could begin planning what we would like to do for the intake.
Knowing that the body of the 2015 WRX and STI is similar, we started with checking the fitment of the intake box we designed for the WRX. The box obviously fit into the same location in the STI, but the piping presented an issue. With its front-mounted turbo setup, the WRX intake system utilizes a different intake tube setup that would not work with the STI box. Next, we grabbed our race intake system for the 2008–2014 models, which utilizes an intake box and a short-ram pipe with filter. We then mocked this unit into place.
Mishimoto intake box mockup
This design could certainly work, requiring modification to only the box. The setup also features a larger MAF housing compared to the stock inlet pipe. This would cause some issues with our claim of “no tune required,” which is why we offer this kit for 2008–2014 owners with aftermarket tunes. By doing so, we can cater to customers who have aftermarket tunes, as well as those who want to stick with the stock tune. We will come back to this particular setup later, when we move forward with a race intake design for the 2015 STI.
Check back with us next time as we explore another option for this intake system!
Mishimoto is offline   Reply With Quote
Old 12-23-2014, 12:43 PM   #2
Mishimoto
Member#: 207954
We have an update on this project! Check it out below!
Mishimoto 2015+ Subaru STI Performance Cold-Air Intake System, Part 2: Prototype Fabrication
After experimenting with some boxed designs in Part 1 of this write-up, it was time to turn our attention to a shrouded setup, similar to what we offer for the 2008–2014 models. We’re hoping we could utilize the piping from our existing kit, which is well designed and has proven power gains. After placing the shroud into position, we found that it would certainly fit, but would require some modification. The fabrication work began! Check out a few shots taken during the process.
Mishimoto intake shroud modification
Once all fab work was completed, we had a functional shroud that we could use for testing purposes. We could also use this shroud to develop a 3D model for our production units. Take a look!
Mishimoto modified intake shroud
Mishimoto intake modified shroud
We could then combine this shroud with our intake pipe, shown below, to capture some performance data.
Mishimoto intake pipe
This pipe features a stock MAF housing, as well as an air straightener to provide laminar flow across the sensor.
Check back next time for a look at the testing process, and the results from our dyno pulls! Check out the teaser shot of this car getting setup on the dyno!
2015 Subaru STI on dyno
Thanks!
Old 01-13-2015, 10:03 AM   #3
Mishimoto
Member#: 207954
Our data is up! Check it out below.
Mishimoto 2015+ Subaru STI Performance Cold-Air Intake System, Part 3: Testing
Dyno Testing
Time to see what kind of power gains we are able to achieve with our intake design! First, we strapped this Launch Edition to the dynamometer.
2015 STI on the dynamometer
2015 STI on the dyno
Then we began making pulls. On our first day we tested only the stock intake system. Once complete, we installed the Mishimoto intake system and sent the vehicle out for some road testing. We wanted to allow the ECU to adjust to the new intake before making our pulls. After well over 150 miles of road use, we returned the next day to compile dyno data for the Mishimoto intake.
Testing Results
So how did we do? Well, I think the plots below summarize our results quite well.
2015 STI dyno plots
As you can see, our intake made a great impact on performance, especially at the upper end of the rpm range. The biggest gains occurred from around 5,000 rpm to redline. We saw peak power increases of nearly 20 whp and around 6 wtq. We also saw maximum gains of 22 whp and 17 wtq.
With our past intakes that make power on the stock tune, we have had a few inquiries regarding engine longevity, AFRs, and knock. Our AFR charts for the runs above are shown below.
2015 STI AFR plots
Although leaner than the stock curve, we are still well within a safe range for engine operation up through redline. Also, we experienced zero counts of knock during our dyno and road testing. These results were expected and are similar to those from our 2008–2014 intake system.
Intake Shroud Design
Now that we had positive testing results, we could move forward with producing our STI-specific shroud to get this product on the market! Check out a rendering of the design in 3D!
Mishimoto intake shroud render
Thank you very much for following along with the progress of our intake. This was quite an exciting project!
We are around 8 weeks from releasing this item. Would anyone be interested in a discounted presale offer for the members of the forum?
Let us know and we can set something up!
Old 01-13-2015, 10:05 AM   #4
jimazz
Member#: 382302
2015 STi
CWP
Take my money!!
jimazz is offline   Reply With Quote
Old 01-13-2015, 10:56 AM   #5
Mishimoto
Member#: 207954
Originally Posted by jimazz View Post
Take my money!!
Haha! One in for the pre-sale. Anyone else?
Old 02-03-2015, 02:57 PM   #6
Mishimoto
Member#: 207954
Another update!
Mishimoto 2015+ Subaru STi Performance Cold-Air Intake System, Part 4: Race Intake System
As noted earlier in this article series, we would be tackling a race intake system to go along with our bolt-on unit. So what makes the race system different? For this particular system we are using a larger-diameter intake pipe with a larger MAF housing. This means greater intake flow, but it also means it will no longer function with the factory tune. This system is meant specifically for drivers who want aggressive professional tunes so they can take advantage of airflow modifications such as larger turbochargers and high boost pressures.
Because the 15’ model shares the EJ from the previous generation, we would be using the same intake pipe and filter as we did with our 2008–2014 kit. This unit is shown below.
Race intake pipe
Mishimoto air filter
Here is a look at this system fitted to a 2010 STi!
Mishimoto 2008–2014 Race Intake installed
So, all we truly needed was to design an airbox that would accommodate this pipe and function with the body of the new 15’ model.
We hit Solidworks and came up with the design you see below!
Mishimoto 2015 STi Race Intake rendering
We are working towards completing this kit alongside our bolt-on intake. Keep an eye out for a pre-sale on both kits coming next week!
Old 02-09-2015, 03:02 PM   #7
J03K3R
Member#: 404350
2015 WRX STI
WR Blue Pearl
I'm in for the intake if there is still a presale
J03K3R is offline   Reply With Quote
Old 02-10-2015, 04:46 PM   #8
jimazz
Member#: 382302
2015 STi
CWP
Just saw the pre sale is up. How long will the pre sale go for? Waiting for my tax return lol
Old 02-11-2015, 10:13 AM   #9
Mishimoto
Member#: 207954
Thanks! Details on the pre-sale are shown below.
Check out the details below. This deal will be available until the first week of March!
Start Date: 2/10/15
Est. End Date: 3/3/2015
Est. Ship Date: 3/6/2015
Performance Cold Air Intake
Price: $265 + Shipping
Link: http://www.mishimoto.com/subaru-wrx-sti-performance-cold-air-intake-15.html
Product Specs
  • Direct fit for 2015+ STI
  • Maximum gain: 20+ whp and 18 wtq
  • Mandrel-bent aluminum pipe offered in polished, wrinkle black, and wrinkle red
  • Includes heat shield to protect air intake from hot engine heat
  • Rubber cap supplied for noise generator
  • Made in USA
  • Mishimoto Lifetime Warranty
Tech Specs
Images
Race Air Intake System
Price: $170 + Shipping (W/Out Box)
$275 + Shipping (W Box)
Link: http://www.mishimoto.com/subaru-wrx-...intake-15.html
Product Specs
  • Requires tuning
  • Installs in under 30 minutes
  • Larger-diameter intake pipe for large turbochargers and more aggressive engine tunes
  • Exclusive optional airbox retains stock-like appearance and uses stock air-intake snorkel
  • Provides highly aggressive intake tone under acceleration
  • CNC-machined air diverter helps maintain reliable and consistent MAF readings
  • Works with stock and aftermarket induction hoses
  • Fits with front-mount intercooler kits
Tech Specs
Images
Feel free to follow up with any questions or comments!
Old 03-25-2015, 02:14 PM   #10
Mishimoto
Member#: 207954
Hey guys,
We have had a few shipping delays that have pushed back the actual ship date for this pre-sale. Our finished kits are expected in our warehouse very soon and we will begin filling orders from the pre-sale immediately. I apologize for the delay and any inconveniences this has caused.
Once these units ship out everyone who placed an order will receive tracking information via email.
Thanks again for all of the orders guys!
-John
Old 04-02-2015, 05:02 PM   #11
jspec4dr
Member#: 392785
Do you guys have an install guide or a reference guide we can use for this?
jspec4dr is offline   Reply With Quote
Old 04-07-2015, 02:45 PM   #12
Mishimoto
Member#: 207954
Sorry for the delay! Our video team is a bit backed up at the moment. The instructions for install are very similar (nearly identical) to our 08-14 STi intake system. The video below should help out!
https://www.youtube.com/watch?v=tkNfPou7KB0
Let me know if you have any questions!
-John
Old 04-10-2015, 02:05 PM   #13
Mishimoto
Member#: 207954
Hey guys,
Thanks to all who joined our discounted pre-sale! These intakes are officially available for purchase. Check out the details below.
Subaru STI Performance Cold-Air Intake, 2015+
Product Specs
  • Designed in Delaware, USA and filter made in USA
Tech Specs
Images
Subaru STI Performance Race Intake, 2015+
Product Specs
Tech Specs
Images
Product Development
Feel free to follow-up with any questions or comments!
-John
Old 03-11-2018, 06:39 PM   #14
Rowrx11
Member#: 338312
How long have you been using this intake without a tune? any problem? 17 sti.
Rowrx11 is offline   Reply With Quote
Old 03-12-2018, 11:56 AM   #15
Mishimoto
Member#: 207954
Hello Rowrx11.
The performance intake for the STI ( MMAI-STI-15 ) Has been out for a couple of years now. This intake system has been designed in an attempt to squeak out every last bit of performance. This dyno-proven air intake provides 20 whp/18 wtq gains over the stock intake while maintaining safe air/fuel ratios.
https://www.mishimoto.com/subaru-wrx...intake-15.html
-Jake
Old 03-12-2018, 02:06 PM   #16
Rowrx11
Member#: 338312
Originally Posted by Mishimoto View Post
Hello Rowrx11.
-Jake
How strongly do you advice to tune the car after it is installed? The car is currently running the stock map with 92 octane ( 97 RON)
Old 03-19-2018, 11:37 AM   #17
Mishimoto
Member#: 207954
Hello Rowrx11
Unless you are using 93 octane fuel, it is critical that you have your vehicle tuned to accommodate this upgrade.
-Jake
Old 08-21-2018, 02:40 PM   #18
davefedex5358
Member#: 309719
2012 Forester XT
Jake: Do you know if there's an off-the-shelf Stage 1 tune available for a 2012 Subaru Forester XT (auto transmission) with the Mishimoto intake? Would the WRX OTS tune work? Suggestions? Thanks.
davefedex5358 is offline   Reply With Quote
Old 10-10-2018, 02:47 PM   #19
ironmaninspace
Member#: 492161
Ohhh, it's amazing!
ironmaninspace is offline   Reply With Quote
