10-20-2020, 10:36 PM | #1 |
Member#: 383942
NESIC
Vehicle:2014 Wrx DGM |
Spun rod bearing on dyno going IAG stage 2 shortblock
2014 Wrx hatch
Spun rod bearing on dyno on stock block (I knew it was going to happen eventually) and I've added a few reliability mods to my list so it doesn't happen again. Anything else I should ask the shop to do while they have the car and engine out? New block is being dropped in Monday so I have a little time to do last minute stuff. End goal 350-400whp with similar torque reliably and I know I'll have to be looking at tranny next. IAG stage 2 shortblock Upgraded intake/exhaust valves Upgraded titanium spring and retainers Invidia equal length headers Grimmspeed up pipe w ewg flange FP Blue turbo Grimmspeed downpipe Perrin catback exhaust Cobb SF Intake Perrin turbo inlet hose Cobb fuel pressure sensor kit Turbosmart comp gate 40mm EWG Grimmspeed electric boost control solenoid Grimmspeed top mount intercooler IAG TGV deletes 1050x injectors Am 340 lph fuel pump PST Carbon fiber drive shaft Perrin light weight crank pulley Koyo Radiator Killer Bee oil pickup Turbo blanket Tein Flexz coilovers Whiteline 22m front swaybar Whiteline 22m rear swaybars Whiteline endlinks and Bushings Perrin pitch stop mount Group N STI motors mounts Group N STI transmission mounts South bend stage 3 clutch Enkei RPF1 17X8 Firestone Indy 500
10-20-2020, 10:45 PM | #2 |
Member#: 487583
Vehicle:2006 WRX TR World Rally Blue |
Looks like a pretty nice and comprehensive mod list, if you have it readily available near you I’d consider throwing in an ethanol sensor for flex fuel. Would definitely help you hit those power goals with less stress on the engine IMO. Please post up your dyno results in the end!
10-20-2020, 11:04 PM | #3 | |
Member#: 383942
NESIC
10-21-2020, 10:16 AM | #4 |
Member#: 310506
South East
Vehicle:2005 WRX STi CGM |
I'd say you should get an AOS on the car. I'd also ask what oil pump is on the car, whether it has been deburred, etc.
Seems like there was some sort of oiling issue, to begin with, for it to spin a bearing. Just to be comprehensive ... what was replaced AFTER the spun bearing block? Oil cooler, turbo disassembled and cleaned, etc? If it were me, I'd want to be 100% confident that every nook and cranny of the heads, etc. were clean as a button. |
10-21-2020, 10:47 AM | #5 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
Good list. Glad we can be apart of it!
Assuming you'll be replacing most tired OEM parts like oil pump, water pump, etc...? |
10-21-2020, 11:06 AM | #6 |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
TGV and air pump delete are the big ones to do while the engine is out. Consider the Getadomtune cylinder 4 cooling kit; cheap insurance at this point in your build.
10-21-2020, 01:22 PM | #7 | |
Member#: 383942
NESIC
10-21-2020, 01:26 PM | #8 | |
Member#: 383942
NESIC
10-21-2020, 01:30 PM | #9 |
Member#: 383942
NESIC
I believe so, I know I'm replacing the oil pump, just have to call them and inquire about seeing if they were replacing the water pump as well! I believe they ordered me a an upgraded oil pan from you guys as well!
10-21-2020, 01:31 PM | #10 |
Member#: 383942
NESIC
Yeah I have to call them about this as well. Thanks for the reminder about the c4 cooling mod. Tgvs are already replaced though!
10-21-2020, 02:27 PM | #11 |
Member#: 428511
Vehicle:2016 STI |
10-21-2020, 02:45 PM | #12 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
Its due to being outside/seen...normally HOAs dont care if its out of sight...
10-21-2020, 04:07 PM | #13 |
Member#: 428511
Vehicle:2016 STI |
10-21-2020, 05:05 PM | #14 |
Member#: 515308
Put the drum in a big ass trash can
11-04-2020, 02:12 PM | #15 |
Member#: 443172
NESIC
Fellow New Englander. Where did you get your car tuned? VEMS is quite reputable up here in VT. Also that mod list is pretty good for a daily. Good balance of response and power with an FP Blue.
11-04-2020, 10:12 PM | #16 | |
Member#: 383942
NESIC
Ill post up results Monday! |
11-04-2020, 10:24 PM | #17 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
11-06-2020, 03:09 AM | #18 | |
Member#: 519868
Vehicle:2010 Impreza WRX Satin White Pearl |
Sounds like a great build though. Exciting times ahead! Interested to see what she puts down |
11-06-2020, 12:25 PM | #19 | |
Member#: 310506
South East
Some might say that if you change your oil and check it frequently, you can avoid it, up to a certain point. |
11-06-2020, 02:10 PM | #20 | |
Member#: 519868
I’m looking to pick one up but a bit wary now hearing these stories. I guess good care is what makes the difference so important to thoroughly check the car’s history. Anyway sorry for derailing. Looking forward to the results! |
11-06-2020, 03:48 PM | #21 |
Member#: 30804
SWIC
Vehicle:87 Yugo Red |
11-06-2020, 04:02 PM | #22 |
Member#: 481754
Vehicle:2017 STi Base Black |
11-06-2020, 04:23 PM | #23 |
Member#: 30804
SWIC
11-06-2020, 07:33 PM | #24 | |
Member#: 383942
NESIC
Not 100% if I describe what they said correctly from memory but I think thats what they said. Yeah I'm excited about the results but now I have to prepare for tranny repairs just in case. I am fairly easy on the car so it should be okay for a while hopefully. |
11-10-2020, 10:13 AM | #25 |
Member#: 383942
NESIC
Ended up with 331whp/316wtq with peak power pulling all the way to redline so it feels great with no dropoff.
Went conservative with 20lbs of peak boost on the fp blue as my TMIC was starting to heatsoak and they said it started to pull some timing on last runs. Im planning to go back for a retune maybe middle of winter and see to go a bit more aggressive after doing some heat management mods as I want to keep my tmic. |
