![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Member#: 34935
Vehicle:Dad- Core OG |
![]() Symptoms happened this morning in Shannon's wagon. We smelled gas while sitting at a light right by home and then again in the parking lot at work once we stopped and idled for a few moments.
I popped the hood and sniffed around in there, but didn't smell any gas. Shannon says the smell was really strong on her side(driver's side) outside of the car. What do I check first? |
#2 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
![]() Lift left-outter cheak and inspect for leaks in das pooper?
#3 |
Member#: 34935
![]() Gasoline.
#4 |
Member#: 71380
RMIC
![]() Oh noes your NOZ is leaking!!!
#5 |
Member#: 64127
Vehicle:2001 PY ITR, 2012 X5 on order |
![]() Was it cold this am? That is a known issue..do a freakin search n00b!!!
#6 | |
Member#: 44638
Vehicle:04 Sage 2.5 WRX going to the pants party |
![]() Quote:
#7 | |
Member#: 64127
![]() Quote:
keep it up. No red hazard button |
#8 | |
Member#: 44638
![]() Quote:
#9 |
Member#: 21007
![]() [asshat-ish mid-a representative] do a ****in search noob and you will find your answer...this has been covered a million times!!! [/asshat-ish mid-a representative]
#10 | |
Member#: 34935
![]() Quote:
Sean already told him he was stupid. We're past that. |
#11 |
Member#: 64127
![]() Seriously, I have had the same smell. The reason it may not have been noticeable in the engine bay, logic dictates, would be it is in the OPEN FREAKIN AIR!!!! Duhhhh!!! Gaaawsh!!
#12 | |
Member#: 34935
![]() Quote:
a;slkdjf;laskdjf;kahsd;flkjas;dlf |
#13 | |
Member#: 64127
![]() Quote:
#14 |
Member#: 21007
![]() i have only had it bad once and then it went away...way back when i first had my car.
only happens on cold morning it seems. some say it is the fule rails, that if you replace those you will be just fine. http://forums.nasioc.com/forums/show...as+smell+cabin can i have the red hazard button? |
#15 |
Member#: 34935
![]() Now that we're done with that...
I mean I obviously think it could be the TB fuel leak. I'll check all lines when I get a chance and see if there are any loose clamps or crap like that. I was just surprised since it was 39 F this morning and it has been a lot colder out in the last few months and this never happened. |
#16 | |
Member#: 44638
![]() Quote:
Was the car already warmed up or was the engine still cold? |
#17 | |
Member#: 34935
![]() Quote:
The car was warmed up when we got to the parking lot at work and smelled it again. |
#18 | |
Member#: 64127
![]() Quote:
#19 |
Member#: 24308
Vehicle:Oh, **** it I'm gonna have a party |
![]() typical issue with the 240 is to not have the inner gastank cover sealed properly...just a thought, if you happen to have installed a pump.
I would then just check all the lines, especially near the firewall where it goes from hard to soft (he heh heh heh). |
#20 |
Member#: 6590
![]() Didn't you just finish installing a drivers-side flamethrower option on her car?
#21 |
Member#: 993
![]() Did you get the exhaust gaskets fixed?
#22 | |
Member#: 34935
![]() Quote:
![]() Another note: The car idles and runs fine. |
#23 |
Member#: 59872
Vehicle:2004 Impreza WRX White |
![]() My sub stinks like gas a lot. And I drive from inside the car rather than the engine compartment so I tend to smell the gas from inside the car.
#24 | |
Member#: 34935
![]() Quote:
#25 | |
Member#: 21007
![]() Quote:
add your region/chapter info and we will start paying attention to your posts ![]() if they are helpful ![]() |
Lisa Fleming, so hot or not so much? | rice h8r | Off-Topic | 37 | 05-28-2007 03:19 AM |
Gas smell coming from alternator and a check engine | ansonb505 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 05-17-2007 09:38 PM |
Gas smell that is not related to cold weather | ImpreziveWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-08-2006 09:41 PM |
I like what you've done here, and here, but not so much here...... | Ripper | Off-Topic | 12 | 12-13-2003 08:21 PM |
Not knowing much about engine design, I have this question. | redoktober_99 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-14-2002 09:43 AM |
