#1 |
Member#: 31345
MWSOC
Vehicle:05 LGT, GC8, NA blue, white, blue |
![]() when I get a jdm swap I wanna know if the usdm ej20 parts work with the jdm ones by parts I mean a down pipe made for a usdm wrx and stuff like that
#2 |
Visiting NASIOC Timeout
Member#: 9093
Vehicle:1995 RHD STi RA Ver2 swap starr |
![]() parts for JDM? easy.
bottom end: crank/rods = EJ18 parts. most likely u will have for free bc thats what u are pulling outa it. air filter? same as the EJ18 oil filter: ditto turbo: im sure any bolt on WRX one will fit header: i spoke to HKS personally in asia and they said that their header will fit up-pipe: dont need on. its already no-cat and made outa incronel downpipe: same deal. most likely usdm will fit. u probbly dont need it though, i dotn think 280PS will be slower than any exhaust modded GDA some parts should be compatible with USDM legacy turbo. that is only a suspicion though rallispec can get u gaskets (although USDM ej20 shoudl work fine) clutch is identical to a USDM WRX GDA clutch. i have one in my attic. i have a exedy USDM GDA clutch on my 94 JDM STI trans OR u can just buy stuff off UK shops or UK ebay. stuff is cheap there, bc ej20 impreza is so frekin common. h |
#3 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() I agree with the statement made. Impreza engines are basically like lego's in that they will all fit each other...to an extent
#4 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() yeah pretty intchangeable
i used a ej205 oil pan on my ej20g no leaks .. |
#5 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
![]() Jaxx
Scooby Guru ^-- bastard -Jon |
Baja Turbos: What works with What? | honda killer | Baja Forum | 301 | 08-26-2023 05:15 PM |
will an ao with and 04 work with an 03 | Ben-no | AccessPort | 0 | 05-29-2006 12:58 PM |
clutch and flywheel what works with what?!?! | scobaru | Subaru Conversions | 10 | 01-06-2005 11:21 PM |
Advan RG works with what brakes??? | Subaruist | Brakes, Steering & Suspension | 1 | 10-23-2002 12:23 AM |
Which cold air intakes work with what FMICs? | Diversion | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 07-15-2002 08:55 AM |
