#29401 |
Member#: 373741
TXIC
Vehicle:2013 Impreza Hatch ISM |
![]() Replaced the front drive axle on Friday. Also, received my new tire from TR yesterday--had it shaved down to 6/32 to match the rest. First time ever using their shaving service, and they did an excellent job, definitely recommended.
#29402 |
Member#: 421858
Vehicle:2012 Impreza |
![]() My poor car... CVT hit 216f today. Trying to go up and down big hills at highway speeds with the AC on full blast. 100 degrees outside. It was really hesitant to go above 5000rpm because I haven't done so lately, so the learned programming seems to make it try to stay at a lower RPM when accelerating. Would rather have just gone straight to redline honestly.
#29403 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
![]() Try a 180F thermostat if those temps bother you.
#29404 |
Member#: 421858
#29405 |
Member#: 421858
![]() Decided to pick up some more CVTF. Will wait until the brutal part of summer is over so all the burning gets done, then get that crap out, probably drain, fill, drive a day or two, drain, fill, and possibly once more.
After that I think I'll be doing it every 15,000- 22,500 miles. If it was a full drain, all 14 or so quarts, and never overheated I would go to 45,000-60,000 probably but only getting 50% out at a time on a good day means I have to do it more often to reduce the old burnt crap in it. |
#29406 | |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
![]() Quote:
#29407 |
moon moon
Moderator Member#: 86213
NWIC
#29408 |
Member#: 470016
Vehicle:2011 2.5i Hatch |
![]() Hey guys, looking at purchasing a used 2012 2.0i hatch with a 5 speed, should I be worried about the oil consumption issues that I've read about? I've done some research but I'm still confused as to what the issue is, if it pertains to every car, and is it still an issue in slightly newer 2.0s?
-Thanks |
#29409 | ||
Member#: 421858
![]() https://www.mishimoto.com/subaru-wrx...er-kit-15.html
Costs about as much as a slightly used CVT from ebay. Quote:
#29410 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
![]() Yea what poop said, I think the warranty for the oil consumption was extended to 100,000 miles so if the car has less you should have time to see if it needs a new shortblock before you hit 100,000 miles.
#29411 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
![]() IMO, i wouldn't buy a used 2012 Impreza if you had a choice. I would opt for a 2013 or 2014
#29412 |
Member#: 421858
![]() It's the same car and it'll do nothing special but cost more. Just as many people all the way through the 15s had OC issues. And it was under one percent of owners at that. Really no different than many other car models.
#29413 |
Member#: 454773
![]() Yea I'm pretty sure there is a big myth that first year of a new model has more issues. Totally individual vehicle dependent most of the time. My 2012 still seems like a brand new car and I haven't done anything but typical maintenance so far.
#29414 |
Member#: 89967
NESIC
![]() Not just about oil consumption, a lot of little things here and there that have probably been improved after the 2012s. Seat squeak, rear hatch latch, now my oil burning smell. Other little things as well. Also, there were quite a few of TSBs for the 2012s as well, what if the previous owner had some of those issues and never got it fixed?
I would stay away from a first year model. |
#29415 |
Member#: 470016
![]() Thank you for the input, hoping to pick one up within the next week
#29416 |
Member#: 454773
![]() I feel you get it from a dealer the tsbs will be on the car fax, and I think you can look them up. Again have 0 issues with my 2012
#29417 | |
Member#: 421858
![]() Quote:
#29418 |
Member#: 421858
![]() The Castrol Transmax CVTF I got lists Subaru "iCVT Fluid" and "iCVT FG" as well as "Lineartronic High Torque Chain CVT". I imagine there can't be enough of a difference between whatever the hell those are and the plain lineartronic that it would matter, correct? From what I read the only difference is actually the torque converter for the high torque CVT.
I might just go crazy some day and order like 5 boxes of 6 quarts per box, it's only $35 currently on Amazon. Hardly any more expensive than regular ATF. |
#29419 |
Member#: 454773
![]() At that rate you might go through more cvtf than oil!
#29420 |
Member#: 421858
![]() Well when it has a capacity of 14 quarts and you can only get out 6 on a good day, the best you can do is multiple drain and fills to get all the old junk out to keep the fluid fresh.
#29421 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
![]() Quote:
#29422 |
Member#: 421858
![]() So apparently the gas gauge goes to zero bars before it's empty. Interesting.
Believe me I wouldn't run it that low normally, but I had to drive this morning and forgot my wallet so I couldn't get any gas until I got home again. I try to avoid ever having the gas light on. It's maybe OK when I take everything out of the car and try to run it as light as possible to have fun which happens like once a year. |
#29423 | |
Member#: 453739
![]() Quote:
For a 2nd time 2 weeks ago. Hope it solves the problem. If yours seem to Have stopped. There's hope for Me ***128536; Last edited by kanjii; 07-01-2017 at 03:30 PM. |
#29424 | |
Member#: 340297
![]() Quote:
#29425 | |
Member#: 445904
![]() Quote:
The 'low fuel' light will come on when there is still plenty of gas left. The trip meter estimation is also about 40 miles pessimistic. I think it's all calibrated to warn you that you are about to be completely empty when you have 1 gallon left. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 06:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 03:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 08:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 05:09 PM |
