#7851 | |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
![]() Quote:
Also, its impossible to get a Mustang at base MSRP unlike the STI. Lots of options, dealers never ordered the cheap cars. Going to a lot today its hard to find a GT with an MSRP under $50k even without ADM. Thats been the one good thing about Subaru not doing options and packages, base models have always been easy to find.
#7852 |
Member#: 161333
NWIC
Vehicle:135i vert fast leaf |
![]() The ford dealer around here that is most notorious for ADM has a bunch of GT's in stock. I could drive away with one today for 40k. Granted, their most expensive is 80k for a rousch gt
#7853 |
Member#: 278626
South East
Vehicle:2001 S2000 |
![]() The mustang is the same relative price it has always been. 25k in 2003 dollars is the same as 36k in 2021 dollars (intentionally excluded 2022 since they didn't make STIs this year). The mustang is more powerful now because Ford has continued to design the car at the same level on the technology curve.
The straightline performance differential existed then as well. A SVT Cobra was basically the same price as a STI, but substantially faster in a straight line. A STI sold for 32500 in 2003, is the equivalent of 47800 in 2021. The 2021 STI is discounted essentially 20% compared to the 2003 model. By using the same old powetrain technology, Subaru was able to substantially drop the price. |
#7854 | |
Member#: 416864
Vehicle:2016 STI WRB |
![]() Quote:
As far as prices go, then it would appear my sources I found online were a bit off, as it listed original 2004 STI price at like 30.5k and then last year's at 37k. Whereas the Mustang GT went from around 28k to 38k. Again, I think Subaru has done well at managing to keep the price increases minimal over the years, but again... my whole point is that back in 2004/2005, we had a 30k car competing with 30-50k cars in terms of performance. And for almost the last decade, we've had a 35k car competing with other 30-35k cars. Does that mean I think the STI should've become a $50,000 450hp car? Nope. But I think - in an effort to appeal to more people to buy - they made the car softer and safer. It's still a good all around performance car that can double with daily duties, and I don't think the car needs to ditch AC and add manual locks/windows.. But the car has become a boat in terms of size for one; and that's my gripe with a lot of cars these days. Today's Civic is larger than an Accord from 10yrs ago, just as today's WRX is with the Legacy. If it were up to me, I would've made the VA model ever so slightly smaller than the GR model and focused on reducing weight in an effort to drop the weight back down towards the original 2004 model we got here. Carbon driveshaft, less sound deadening, and 2 piece brake rotors alone would've shaved over 50lbs. Not to mention more use of aluminum, which could've saved quite a bit more. Engine wise, I think some of what they were using in the engines used for the RA/S209 with the different pistons, sodium filled valves, and IC sprayer should've been on the regular STI as well. Additionally, I would've done like what Mazda does with their Miata, and utilize eccentric bolts front/rear to allow for camber/toe adjustments to some extent at all 4 corners from the factory. Because the stock alignment is **** and done purely to keep kids from wrapping their car around a tree... which they still manage to do anyways. So a sub 3,200lb car with 320-330hp, better drivetrain/engine response, better handling, and better braking. Would it have cost a bit more money? Sure, a bit. But enough to make a reasonable performance difference where it counts and not trail behind other cars in the same price range like the Focus RS and CTR; both of which proved to be noticeably quicker around a lot of tracks. |
#7855 | |
Member#: 2272
BAIC
![]() Quote:
Prior to the pandemic, when there were plenty of STIs and Mustangs on the lot, the price difference was quite clear. Lots of base model STIs for mid 30s throughout its run in the late 2000s and all of the 2010s. The muscle car trio has been in a higher price bracket for awhile now is the point and it wasn't that way when this all started. |
#7856 | |
Member#: 194216
W. Canada
Vehicle:2022 Fast POS |
![]() Quote:
#7857 | |
Member#: 416864
![]() Quote:
I only mentioned it because you're the one that said that Mustang GTs today are more expensive than STIs today.. when the STI doesn't even exist anymore. ^Yup. This too. Though I got lucky and purchased from the same salesperson at a dealer I had purchased from before so I was able to get a bit of a discount. |
#7858 |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
![]() If you have a STi, your'e all set up. Quit daily driving it and you should have a very long term car you can drive corners on the weekends, and go to the track. Buy a daily and consider your STI a classic no matter what year it is. Got extra bennies? Yank the motor and put a 207 in that bish.
#7859 |
Member#: 139693
![]() If you have a STi, your’e all set up. Quit daily driving it and you should have a very long term car you can drive corners on the weekends, and go to the track. Buy a daily and consider your STI a classic no matter what year it is. Got extra bennies? Yank the motor and put a 207 in that bish.
#7860 |
Member#: 442
NESIC
Vehicle:17 Imp Spurt 00 S2k |
![]() Subaru, wat r u doin'?
Someone else finally put it on video what's been generally known, the WRXGT is not only a disappointment, it's going to be a failure. You're peddling a name here, resting on laurels, and it's now stupid to pay that money for something that bad (unless your sole intention is to turn corners a bit more quickly, but that will come at a steep price) Sure, outback vs WRX isn't a good match because 2 different segments, but come on! There's no reason to have worse gas mileage, slower, and lighter, just to have "sporting intentions". |
#7861 |
Member#: 873
TXIC
Vehicle:2020 JEEP / RAM Datsun 71 240Z & 68 2000 |
![]() how incredibly sad for the WRX. Shamed by the outback, on regular gas, with less horse power and more weight, and worse tires.
Just discontinue it. |
#7862 |
Member#: 873
TXIC
#7863 |
Member#: 75071
Vehicle:AR Giulia,Tesla MY Old: 05 08 11 WRX, 18 STI |
![]() I hate it, I love it, I'm so torn.
#7864 |
Member#: 873
TXIC
![]() outbacks have always been brilliant
#7865 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
![]() They make coilovers for it, too. So even less reason to get a WRX GT.
#7866 |
Member#: 528403
NWIC
Vehicle:22' WR-HikingShoe 23' F250, 18' Q5, 18' CRV |
![]() The difference in R&D fund allocation is staggering. The Spirit of the LGT lives on!! lmfao
#7867 |
Member#: 139693
#7868 |
Member#: 67807
![]() Hood. Scoop.
#7869 |
Member#: 300811
RMIC
Vehicle:1939 International School bus |
![]() This new wrx is fast. Wow.
Haha. |
#7870 |
Member#: 75071
![]() It gets better. MT clocked the Toyota bZ4X (Subaru Solterra) [214 hp/248 lb-ft] at 5.8 seconds and 14.5 1/4mi...
#7871 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
![]() I do not like the design direction for the new Subarus...that Outback front bumper is hideous
#7872 |
Member#: 159474
NESIC
![]() It may be hideous, but you're forgetting about rally roots and how practical all that plastic can be. Everyone knows you can't design plastic pieces to look appealing, so Subaru skipped all the thought process and just threw up chunks of plastic on the entire body. INSPIRING!
#7873 | |
Member#: 528403
NWIC
![]() Quote:
#7874 |
Member#: 416864
![]() I don't understand why the cost keeps going up for Subarus considering that their cars today only come 2/3rds painted from the factory.
#7875 |
Member#: 419593
![]() I am actually surprised they were able to keep the WRX price so low given the improvements. I am referring to the base/premium with 6 speed trim. GT is a bit too pricey. I am not sure what audience they are pursuing with that.
