Welcome to the North American Subaru Impreza Owners Club Friday December 8, 2023
Old 12-09-2005, 05:59 AM   #1
a1ex
Member#: 73714
2003 Impreza WRX
Sedona Red
Default help me with my camry :(
hey, guys. I'm looking for an opinion on what could be the problem with my toyota camry. It's a 96 4cyl model with low miles (68k). On cold mornings, the power steering squeeks and the wheel is difficult to turn. I checked the fluid level and it's normal; there aren't any leaks, either; the belt is in good shape.
is it a bad pump? something with the steering rack? please help
a1ex is offline   Reply With Quote
Old 12-09-2005, 06:00 AM   #2
sdogg3kgt
Member#: 38397
2002 Lovemachine
Bad pump
sdogg3kgt is offline   Reply With Quote
Old 12-09-2005, 06:01 AM   #3
sdogg3kgt
Member#: 38397
2002 Lovemachine
that is if there are absolutely no leaks
Old 12-09-2005, 06:03 AM   #4
a1ex
Member#: 73714
2003 Impreza WRX
Sedona Red
how can i really check for leaks?
Old 12-09-2005, 06:32 AM   #5
chri3
Member#: 16245
Are you kidding?
Look for residue, drips. Then check the level periodically....or you could just replace the pump/
chri3 is offline   Reply With Quote
Old 12-09-2005, 08:18 AM   #6
avk
Member#: 17252
'06 WX8
59E
There's a condition called "morning sickness", it's caused by internal leaks resulting from wear that go away at warm-up. Can't tell for sure if that's really the problem. You can start with replacing the fluid, maybe adding some seal conditioner and see if it changes anything.
avk is offline   Reply With Quote
Old 12-09-2005, 10:24 AM   #7
Buckeye Kid
Member#: 41369
2002 Subaru WRX
Maybe it's the power steering pump. Also may be the steering rack. I'd recommend checking your blinker and turbo fluid.
Check this thread for more information.
Buckeye Kid is offline   Reply With Quote
Old 12-09-2005, 10:26 AM   #8
runnah
Member#: 77447
2000 RS
Salty
Mittens and earmuffs.
runnah is offline   Reply With Quote
Old 12-09-2005, 10:33 AM   #9
BhamRoadrunner
Member#: 87294
98 Silver
POS
Kittens and handcuffs.
BhamRoadrunner is offline   Reply With Quote
Old 12-09-2005, 12:47 PM   #10
boxxxer
Member#: 84647
Squeaks = Loose belt. Internal wear would make a grinding / burbling noise if anything. If it's squeaking then it's the belt slipping.
When was the last time the belt was replaced? If the face that contacts the pully is shiny then the belt is done even though it may not be cracked or show any other signs of wear.
boxxxer is offline   Reply With Quote
Old 12-09-2005, 02:05 PM   #11
Impresario
Member#: 344
2004 Impreza WRX
Java Black Pearl
check if the belt is loose/stretched.
Impresario is offline   Reply With Quote
Old 12-09-2005, 02:07 PM   #12
HOV
Member#: 64632
Bitemarks and donghuffs
HOV is offline   Reply With Quote
Old 12-09-2005, 02:20 PM   #13
volume311
Member#: 56615
COld morning = steering fluid that thickens up and doesn't want to flow smoothly. Change to synthetic steering fluid*
*talk to a professional before doing this
volume311 is offline   Reply With Quote
Old 12-09-2005, 03:02 PM   #14
stuttgart
Member#: 13920
2006 WRX
CGM
let me go ahead and bandwagon on this post. I have a '91 camry and for some reason when I go through a big puddle or something my power steering will go out for a second, usually when i'm making a turn onto another street. whats the deal?
stuttgart is offline   Reply With Quote
Old 12-09-2005, 04:50 PM   #15
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Belt slips, causing loss of power steering for a few seconds. When the belt dries back up, it gains power 'cuz belt no slippy any more.
Mika
finnRex is offline   Reply With Quote
Old 12-09-2005, 04:52 PM   #16
bluesunlion
Member#: 11377
2016 WRX Sti
Mika
Ditto
bluesunlion is offline   Reply With Quote
Old 12-09-2005, 05:17 PM   #17
STimpede
Member#: 100603
Default leak
Hey there
I have a '95 (gen 3) camry and I've got that same problem. I can guarentee you it's probably a minor leak and you've been leaking tiny amounts of fluid, just never knew it. the little meter thing on the side of the fluid can is never readable so you have to read it looking into the can with the cap off.
Replacing the hosing and pump would've cost waaaay too much for me so I just got myself a 3 dollar quart of power steering fluid and every time i hear it (not very often) i just add a few tablespoons and problemo = solved.
Let's compare:
1) set of hosing
2) steering pump
$ Assload.00
as opposed to
1) 1 quart of power steering fluid
$3.16 at Kragen
If that doesnt work then I guess you just wasted 3 dollars but worth a shot I would think.
STimpede is offline   Reply With Quote
Old 12-09-2005, 05:25 PM   #18
Buckeye Kid
Member#: 41369
2002 Subaru WRX
That is an awesomely ghetto way to fix a POS car.
Thread title: Got a flat tire, how to fix!
Poster: A tire costs way too much money for a 1995 Camry. I have a slow leak caused by a nail years ago I never bothered to pull out. I simply pull up to BP once a week and fill my slowly leaking tire everytime it looks low.
Problem solved!
Old 12-09-2005, 05:27 PM   #19
Sephro
Member#: 22319
05 LGT LDT
Change the fluid...
Sephro is offline   Reply With Quote
Old 12-09-2005, 05:27 PM   #20
Buckeye Kid
Member#: 41369
2002 Subaru WRX
I know some of you guys are poor but come on, making sure your 3500 lb death machine is operating correctly may need to be a bigger priority in your life than it currently is.
Old 12-09-2005, 05:49 PM   #21
Briman2021
Member#: 70363
1989 Conquest
Problem solved!
I did that for 2 months last summer, it works.
Briman2021 is offline   Reply With Quote
Old 12-09-2005, 05:53 PM   #22
Buckeye Kid
Member#: 41369
2002 Subaru WRX
Hey I'm not saying it's right or wrong, just ghetto.
Oh, wait, I am saying it's wrong. My bad.
Fix yer junk before it collides with me!
help me with my canary :( P03w Off-Topic 17 07-02-2014 01:40 PM
Please help me with my brake pad problem really making me mad Jkmaynard Newbies & FAQs 12 08-12-2009 11:51 PM
Olympia Rally pictures for sale, help me pay my bills! :( LandCruzer94 Off-Topic 2 08-16-2006 03:48 PM
OT Help Me with my School Project (Photoshop my pic) The Enemy Off-Topic 5 01-10-2004 12:13 AM
Help me with my PHP script :( Kinsbane Off-Topic 23 05-21-2003 07:53 PM
