12-08-2018, 10:16 AM | #1 |
Member#: 425518
2010 Wrx Turn signal issue
Front drivers side turn signal only works when headlights are off, but is out with the headlights on. havent had a chance to check the grounds / relays. anyone with any other ideas before i just start with putting a bulb in it?
12-09-2018, 06:38 AM | #2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
Since the headlights make the problem happen then your suspicion of a faulty ground is correct. You can verify that by adding your own ground wire between the battery and to the suspected bad ground point.
12-09-2018, 09:34 AM | #3 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Could be broken wire strands in the wire, bad crimp, loose ground connection, corroded ground connection. |
