12-14-2018, 12:49 PM | #1 |
Member#: 477077
Vehicle:2019 WRX PremIum |
Are ‘15-‘17 Limited OEM LED headlights plug and play on ‘19 Premium model?
Had anybody swapped in the ‘15-‘17 Limited LED headlights into a Premium model? I know the current Limiteds have the turn signals in the headlights so those wouldn’t be plug and play, but the ‘15-‘17 still had the separate turn signals down by the fog lights just like the current Premium model does. I’m wondering if the wiring harness is the same so I could just swap out my Premium assemblies for the Limited ones and get the LED headlights and the better C light, and then use the Subispeed DRL harness to make the C lights work as the DRLs.
I know this would be a little pricey but I didn’t want leather seats so I’m thinking if I buy these units along with the mirror turn signals I’ll pretty much have the Limited lighting I wanted without the leather seats.
12-14-2018, 05:05 PM | #2 |
Member#: 472037
Vehicle:2018 WRX Limited CWP |
I think the limited has LED high/low beam in one housing as well as SRH.
The non-limited headlight is seperate high/low beam HID? |
12-14-2018, 05:48 PM | #3 | |
Member#: 477077
In 2018 the assembly changed and now the turn signals are inside the main headlight where the high beams used to be, so that one would require some wiring changes in order to fit since my car has the turn signals separate. So since I have separate turn signals it seems like the headlight assemblies from a 2015-2017 Limited would use the same connectors as mine and I would just end up with the full LED C-Light and LED low beam without the need to change any wiring. |
12-14-2018, 07:18 PM | #4 |
Member#: 198067
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
I want to remove this post.
