08-24-2006, 05:44 PM | #26 |
Member#: 35350
Vehicle:2004 Impreza WRX STi Java Black Pearl/Gunmetal |
Yes. You can then turn it on without the headlights. Also another mod is to make them not go off, when you are using the HighBeams.
08-24-2006, 08:54 PM | #27 |
Member#: 121883
E. Canada
This should be a sticky =)
08-24-2006, 09:09 PM | #28 | |
Member#: 100204
VIC
Vehicle:2006 STI (retired) WRB |
After all these months, the mod is working perfectly with no issues. One thing that I noticed about the indicator on the fog light switch. Although normally it doesn't turn on when the headlights aren't turned on, if the headlight stalk is pushed for high beams, the indicator light will illuminate even when the headlight switch is off. |
08-24-2006, 09:23 PM | #29 |
Member#: 121883
E. Canada
lol ya! include 2006 in that title..!
Maybe the indicator light within the fog light switch draws power from another leg in the relay (also feeding from the v12 you tapped into)..? Glad to hear it's been working for months without issues.. can't wait to try it. |
08-25-2006, 01:52 AM | #30 |
Member#: 110109
VIC
Vehicle:2006 Impreza 2.5i Aspen White |
Just curious... is having this setup bright enough for driving at night with thick fog? I'm worrying because my 06 factory foglights are quite small and don't seem to put out a lot of light.
08-25-2006, 02:12 AM | #31 |
Member#: 100204
VIC
I have the same fog lights as you. They only illuminate the very front of your bumper. I've driven in some really, really, pea-soup fog in the past. In that kind of fog you actually don't want to use the low beams because the reflect too much glare. With the ability to turn on the fogs by themselves without the low-beams, I'm able to drive with better visibility in more situations without worrying about glare.
Of course, with fog that thick you would be driving very slowly anyway so the fog lights do provide enough light. Under normal visibility conditions (and light fog), the fog lights by themselves are not bright enough to drive at night because they only light up the front of your bumper (like they are supposed to do). They are bright enough during the day to act as DRLs though. |
08-25-2006, 07:41 PM | #32 |
Member#: 102022
NWIC
Vehicle:2006 wrb WRX 1987 panda FX16 |
I made this picture to hopefully explain a few things about the foglight mod.
What the original poster posted basically is the relay half of the positive side of the mod (red text). Doing this only does allow the fogs to come on without having headlights or parking lights on, but the switch indicator does not indicate the same. You should do the same to the switch side of the red/green wire. Foglights going off when you flash/turnon high beams is caused by the ground side (blue text). Ground the yellow/blue wire and you will have fogs stay on even if you flash/turnon high beams. Last edited by Zalthras; 11-06-2007 at 05:40 PM. Reason: updated link |
08-25-2006, 07:52 PM | #33 | |
Member#: 100204
VIC
08-25-2006, 08:02 PM | #34 | ||
Member#: 102022
NWIC
Last edited by Zalthras; 08-25-2006 at 08:36 PM. Reason: added quote from Oregon Department of Transportation |
10-08-2006, 04:57 AM | #35 |
Member#: 25033
NWIC
Vehicle:06 sti my $$ pit 05 xt sold |
thanks for the info!
10-08-2006, 10:47 AM | #36 |
Member#: 68902
Vehicle:2011 WRX - WRBM 1988 Fiero GT - black |
There has been a similar mod on ScoobyMods for a few years now. I don't know how this mod is different, but with the ScoobyMods mod, whenever I run my fog lights alone, one of the bulbs eventually burns out in about a week or three. Then the other. So it might be getting a surge of energy when the power is turned off (when turning off the car) that is dissipated more when low and fogs are on together.
So I did the ScoobyMods foglight mod, but I almost never run with only my fogs on now because I don't want to have to replace the damn bulbs. Anyone else with similar experiences? |
10-08-2006, 04:12 PM | #37 |
Member#: 123876
Vehicle:2006 Impreza WRX STI WR Blue Pearl |
Is this correct? Thanks, |
10-08-2006, 04:55 PM | #38 |
Member#: 100204
VIC
This mod is different than the ScoobyMods one because it doesn't burn out your bulbs in a week or three. I've had this mod since early this year and have had ZERO problems.
10-08-2006, 04:59 PM | #39 |
Member#: 123876
So... will my fog light switch still function? if I do this mod?
Thanks, Bennett |
10-08-2006, 05:04 PM | #40 |
Member#: 100204
VIC
10-08-2006, 05:11 PM | #41 | |
Member#: 123876
Thanks, Bennett |
10-08-2006, 06:24 PM | #42 |
Member#: 128502
I figured this might be a useful visual aid for any who have problems understanding the wiring diagram.
~Miah Last edited by notamember; 10-08-2006 at 06:31 PM. |
10-16-2006, 03:40 AM | #43 |
Member#: 122648
Zalthras-
So let me see if I got this all straight. The car: 2006 WRX Sedan or Wagon US spec The Goal: Be able to turn the fog lights on with the factory fog light switch when the head light selector switch is in any of the following positions: Parking lights only, Low Beam, High Beam, and Headlight flasher aka flash to pass. The parking light switch on the top of the steering column will not enable the fog lights after the mod, just as it does not enable the fog lights in the stock configuration. The stock factory fog light switch will still illuminate and dim with the brightness control, and the on/off indicator portion of the fog light switch will still correctly indicate the status of the fog lights as on or off correctly, after the mod the same as it did before the mod. The Method: Remove the Fog Light Relay and bend the #23 pin so as to be accessible when the relay is plugged in, as shown in the above photos. (This also effectively cuts the Red/Green wire at the fog light relay) 1.Attach 16 gauge wire to bent relay pin and connect to the Black and Red wire labeled FB #10 in the wiring diagram above 2.Cut the Red/Green wire where it comes out of the Fog Light Switch and also connect it to the F Black/Red wire. 3.Cut Yellow/Blue wire coming out of the fog light switch and connect to ground (Black wire). (Note: It is my understanding that the 2006 WRX uses a "variable ground" to change the brightness of the dash lights. Be sure that you DO NOT use this "variable ground" to ground the Yellow/Blue wire. Test the resistance of the ground you choose with a multi-meter it should be somewhere near 0 ohms) and does not change when you adjust the brightness of your dash lights) A question: Based on the wiring diagram you posted, which I assume is for the US Spec 2006 WRX, it looks like you suggest taking the Yellow/Blue wire to ground BEFORE the Diode. Now, please correct me if I'm wrong, my understanding of a Diode is that it is a directionally limiting device, i.e. electricity only flows one way through the diode and is thus a circuit protector of sorts preventing the flow of electricity in the wrong direction. So based on that, is there any reason why you could not choose to ground the wire labeled YG (Yellow/Green I assume), instead of grounding the Yellow/Blue wire? If this is all correct, I hope it solves some confusion. Thanks |
10-16-2006, 04:31 PM | #44 | ||||
Member#: 102022
NWIC
I hope all my run-on sentences made some sense.... in short, I felt that it was an unnecessary 0.7v drop device in the circuit once you make the wiring changes I showed in the picture. You can by all means leave it in if you want. |
10-16-2006, 07:50 PM | #45 |
Member#: 123876
Soldiered it on. I also shaved the clips on the side to make it easier to remove next time.
Got the add a fuse at Auto Zone for 7 bucks. End Results: However, I didn't cut any wires behind the foglight switch. I just connected it the way I have in the picture. is it bad how I have it hooked up? It seems to work just fine, but I don't want to break anything. Bennett Last edited by Bennett; 10-16-2006 at 08:06 PM. |
10-16-2006, 09:34 PM | #46 |
Member#: 100204
VIC
That's exactly how I did mine and I haven't had any problems at all.
10-17-2006, 12:50 AM | #47 |
Member#: 123876
10-17-2006, 11:08 AM | #48 |
Member#: 129215
Vehicle:2007 Outback Impreza Obsidian Black Pearl |
Def going to try this soon, think it will work with an 07 Impreza Outback?
10-17-2006, 11:14 AM | #49 |
Member#: 129215
I was just told it wont work?
11-02-2006, 07:16 PM | #50 | |
Member#: 121883
E. Canada
I tried this.. I couldn't get the relay back into the relay holder with the leg bent !! how did all of you guys manage to get it back into the holder? Only idea I had was to 'trim' the relay box, but I didn't want to do that.. any ideas?? |
FS: VA-2004-2005 Fog Lights, Trim/Bezel (PSM), Switch, Brackets | DC-WrX | Exterior/Styling | 1 | 08-29-2009 12:01 PM |
Anyone in roy area know how to fix the HID w/ fog light issue on bugeye? | Jncominco2 | Rocky Mountains Impreza Club Forum -- RMIC | 8 | 10-14-2008 02:15 PM |
FS:Socal 2004/2005 Fog light covers + more. | L7nx | SCIC Private Classifieds | 0 | 01-29-2008 06:30 PM |
PSM 2004-2005 Fog Light Covers | Crump | Exterior/Styling | 0 | 08-20-2006 12:34 AM |
PSM 2004-2005 Fog Light Covers | Crump | Tri-State Area Private Classifieds | 0 | 08-20-2006 12:32 AM |
