11-02-2006, 07:27 PM | #51 |
Member#: 123876
Vehicle:2006 Impreza WRX STI WR Blue Pearl |
I used my dremel to make a notch very carefully.
11-02-2006, 07:36 PM | #52 |
Member#: 121883
E. Canada
oh so I have no choice but to mod the fuse holder a bit so this will fit into the socket.. Hmm..
what if the relay itself was shaved so the wire would recess into it a bit allowing proper clearance? I was thinking of this also.. thanks for the reply. |
11-02-2006, 10:00 PM | #53 | |
Member#: 35350
Vehicle:2004 Impreza WRX STi Java Black Pearl/Gunmetal |
Glad that this mod works on the 2006. Editing title... |
11-13-2006, 11:37 AM | #54 |
Member#: 121883
E. Canada
I've done this mod yesterday on my 2006 wagon (2.5i) and it's working perfectly !
I bent the leg on the relay (as shown in the above picture) soldered a wire to it and got an "add a fuse" and stuck it into the "illumination fuse" 10A. When I arm&disarm my car, the fog lights flash.. when I use my remote car starter, the fog's are on when the car's running. Works great ! although I did have to cut into my fuse box to make the relay slip back into its holder, but I'd prefer this than cutting my oem wires =) Thanks guys! |
11-13-2006, 03:20 PM | #55 |
Member#: 35350
So I guess 06 needs to trim fuse box to fit relay after relay spade leg is bent?
11-13-2006, 03:53 PM | #56 | |
Member#: 121883
E. Canada
Don't know if anyone else had this problem on the 06? This mod's working perfectly so far. thanks! jesse |
11-29-2006, 10:55 PM | #57 | |
Member#: 118086
Vehicle:2003 WRX WRB |
Will this work on an 03? the reason i ask is because the Schematic blow is just like the one in my FSM for a 03 same color wires the only thing different is the numbering/nameing of the plugs,
Front fog light Relay = [B48] on my FSM & on Zalthras Schematic Front fog light Relay = [B225] But its the same wiring Schematic any way i think i'm going to do it this way on my 03 i have looked over the Schematics & i see no reason that it will not work . i'l get back to you in a day or two & tell every one if it works Quote:
11-30-2006, 04:32 PM | #58 |
Member#: 102022
NWIC
Vehicle:2006 wrb WRX 1987 panda FX16 |
Yes it should work. If you want to be absolutely sure, you can pm me the schematic for your 2003 and I can tell you exactly what you need to do.
12-05-2006, 11:48 PM | #59 |
Member#: 127908
Vehicle:1999 Forester Stb White |
could some 1 clarify how to get the fogs to stay on with the highbeams with the US Spec 06 WRX?
i plan to do the mod some time tomorrow or this weekend but just need to figure out where to ground to keep the fogs on. |
12-06-2006, 01:56 AM | #60 | |
Member#: 118086
the Schematic just up a couple posts shows you how to do it Not to be a dick but can't you see the Blue on the Schematic And jezzy says it worked for him On post #54 it has got really cold out so i have not dun it yet |
12-06-2006, 07:43 AM | #61 |
Member#: 94698
Vehicle:2005 30R Wagon CGM |
*subscribe*
12-06-2006, 08:23 AM | #62 | |
Member#: 127908
im horrible with electrical. but great with mechanical. |
12-06-2006, 10:48 AM | #63 |
Member#: 121883
E. Canada
Yep.. check my post. Within this thread, you'll see someone using a "add a fuse" basically you remove your left knee panel under the dash, you'll need to get to your fuse box.
Remove the fog light relay (4th from the top?? anyone confirm? I can't remember), Then bend the leg (as show somewhere within this thread), solder a wire to that leg, then attach it to the add a fuse wire. Put the relay back in (I had to trim my fuse box to allow the relay to slip back into the holder). I personally put the 'add a fuse' into the illumination fuse (10A) and when I turn on my corners, the fogs turn on. To get the headlights to stop turning on when you release the hand brake, you need to disable the daytime driving relay (behind the glove box.. takes 5 seconds) So now I have control on my HID's while driving. I use my fogs as my daytimes, and I can turn on the headlights whenever I feel like it.. this saves many hours of use on those HID bulbs. hope this helps |
12-06-2006, 07:14 PM | #64 |
Member#: 102022
NWIC
There is no blue wire in my picture, he's refering to the blue text, and blue line added into the schematic. Basically you ground the [Yellow/blue] wire to solve the foglight/highbeam switching.
12-12-2006, 05:28 PM | #65 |
Member#: 118086
Does any one know Wear the B112 Diode is. i got my car apart & i'm sick of looking
12-12-2006, 08:24 PM | #66 |
Member#: 118086
Change the thread Title ! this works on a 2003 WRX all so
12-13-2006, 01:55 AM | #67 |
Member#: 94524
electrical n00b here, so this basically lets you turn on and off the fog lights with the factory switch so you DON'T have to have the headlights on, correct?
Didn't really see a specific description of the mod in the first post... |
12-13-2006, 02:25 AM | #68 | |
Member#: 118086
And if you run the the rea/green wire to a + 12 ACC you dont have to have the parking lights on to have fogs. |
12-13-2006, 12:48 PM | #69 |
Member#: 94524
^ got it, thanks!
12-24-2006, 11:05 PM | #70 | |
Member#: 21508
Vehicle:'03 WRX Wagon Silver |
12-25-2006, 11:26 PM | #71 |
Top Scoob 008
Member#: 77299
Vehicle:'05 2.5RS #78 ST, MAXIMUM ATTACK! |
this modification with the add-a-relay works great on my 05... here's some pics,
got bored on christmas night after all the days events.. decided to take some pics of the lighting mod i have done; diy foglight on-whenever you want diy rear fog lamp high beam/foglamp - ion yellow, lowbeam - 6000k HID |
12-26-2006, 09:26 AM | #72 |
Member#: 25039
Vehicle:2005 CGM Stage 2 WRX SQC 275 |
SiFuSpEc- How did you do the rear fog? I thought that was only doable on the 02-03's?
12-26-2006, 10:18 AM | #73 |
Top Scoob 008
Member#: 77299
ran a positive lead from the bulb too a 12v and swith up front,
i'll be helping someone with an 02 do this today.. both fog mods. |
12-26-2006, 05:24 PM | #74 |
Member#: 108194
Vehicle:2006 wrx 51E |
great write up. will definetly be doing this to my 06!
12-26-2006, 05:44 PM | #75 |
Member#: 25039
FS: VA-2004-2005 Fog Lights, Trim/Bezel (PSM), Switch, Brackets | DC-WrX | Exterior/Styling | 1 | 08-29-2009 12:01 PM |
Anyone in roy area know how to fix the HID w/ fog light issue on bugeye? | Jncominco2 | Rocky Mountains Impreza Club Forum -- RMIC | 8 | 10-14-2008 02:15 PM |
FS:Socal 2004/2005 Fog light covers + more. | L7nx | SCIC Private Classifieds | 0 | 01-29-2008 06:30 PM |
PSM 2004-2005 Fog Light Covers | Crump | Exterior/Styling | 0 | 08-20-2006 12:34 AM |
PSM 2004-2005 Fog Light Covers | Crump | Tri-State Area Private Classifieds | 0 | 08-20-2006 12:32 AM |
