Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 11-12-2016, 07:37 PM   #1
DirtyDub
Member#: 404264
17 WRX
LBP
Default SubiSpeed JDM style fog light bezel pics 17 WRX
I just installed my JDM style fog light bezels from SubiSpeed on my 17 WRX so I thought I'd post up some pics. I also have LED halo fog lights and Morimoto c lights. These are just my DRLs running.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
With the low beam on
DirtyDub is offline   Reply With Quote
Old 11-12-2016, 08:47 PM   #2
PrisonerOfDoom
Member#: 455157
2017 Base WRX
They look great! How was the fitment, quality, etc?
PrisonerOfDoom is offline   Reply With Quote
Old 11-12-2016, 10:36 PM   #3
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
Looks great. How was install and how do you have hooked up?
hekler is offline   Reply With Quote
Old 11-12-2016, 11:01 PM   #4
DirtyDub
Member#: 404264
17 WRX
LBP
Install is pretty simple. Takes about an hour or less. I tapped my power wire into my SubiSpeed DRL harness with the T-taps they provide. Just gotta remove the plastics underneath to route the wiring to the bezels themselves.
The quality of the LEDs seems good. They are nice and bright and match my halos on my fogs. The glossy paint could be a little better but after all these are knockoffs. I definitely like that the LED strip goes all the way across the bezel. I can't really complain so far.
Old 11-16-2016, 11:26 PM   #5
hekler
Member#: 388366
CBS w/eyesight
Ok dumb question here. When you turn your lights on (or auto lights) do all of these turn off?
Old 11-17-2016, 04:19 AM   #6
DirtyDub
Member#: 404264
17 WRX
LBP
I don't have mine set up that way, but it's very simple to do that if you prefer it that way. My halos have an optional yellow wire that you would tap into the headlight power wire. The SS JDM fog bezels have an optional white wire that you would do the same. So when those wires get power they shut off the DRL.
I want mine on all the time so I did not use those wires.
Old 11-17-2016, 03:14 PM   #7
hekler
Member#: 388366
CBS w/eyesight
Exactly, I would want those cool lights on all the time as well. Thank you!!
Old 11-18-2016, 04:03 PM   #8
jct133
Member#: 394173
2017 WRX Limited
Lapis Blue Pearl
I bought the JDM S4 bezels, installed the SS c light as drl harness and the JDM bezels and don't have any power to them. Check the harness connections, t taps, everything... cannot figure out what the **** is wrong. All headlights still work and the normal drls are still on, must've ****ed something up with the c light harness but no clue what. So frustrating.
jct133 is offline   Reply With Quote
Old 11-18-2016, 04:50 PM   #9
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
The difference in color temperature would bother me.
pho_shizzle is offline   Reply With Quote
Old 11-18-2016, 06:27 PM   #10
hekler
Member#: 388366
CBS w/eyesight
Can you see the lights while you drive??
Old 11-18-2016, 06:57 PM   #11
jct133
Member#: 394173
2017 WRX Limited
Lapis Blue Pearl
Okay finally got the fogs powered. I thought the C lights as DRL harness from Subispeed would disable the normal high beam DRL. What's the step I'm missing?
The reason I couldn't get power seems to be because the harness I got from SMY had the red/black wires switched. Called and asked about it, he suggested switching the red and black up top where the t tap connection was and it worked (even though it went against every instinct I have to go red to black).
Old 11-18-2016, 06:59 PM   #12
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
I think it was the DRL resistor that controls the high beam....
cyralax is offline   Reply With Quote
Old 11-18-2016, 07:09 PM   #13
jct133
Member#: 394173
2017 WRX Limited
Lapis Blue Pearl
That's what I had thought as well, but for some reason I thought the Subispeed C light for DRL harness should do it (thought that was kinda the point). So for people that have done this, does this seem to be the best way: https://youtu.be/5-Wr1urB0rE -- any other advice?
Old 11-18-2016, 07:49 PM   #14
Ultimateone
Member#: 48025
17 RS
SB
Yes you have to unplug the drl box plug, that won't affect your bezels at all.
Ultimateone is offline   Reply With Quote
Old 11-18-2016, 09:07 PM   #15
DirtyDub
Member#: 404264
17 WRX
LBP
Yeah the plug you need to disconnect to turn off your original DRLs is on the passenger side behind the fog light bezel basically. SubiSpeed shows it on their DRL harness how to vid I believe. I think it was grey and only had 2 wires.
Old 11-18-2016, 11:11 PM   #16
jct133
Member#: 394173
2017 WRX Limited
Lapis Blue Pearl
Thanks guys! I appreciate the help very much.
Edit: got it figured out this morning! Looking good! I'll post some pics soon. Thanks again for the help.
Old 11-19-2016, 05:57 AM   #17
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
You can definitely see it in the pictures. Its the finer details that perfect a build.
Old 11-21-2016, 01:55 AM   #18
DirtyDub
Member#: 404264
17 WRX
LBP
The color temperature is more noticeable in these pics than in real life. I also have low beam HIDs that match the c lights. I wish I would have known the Morimotos were gonna be a little more blue but oh well. I really like the way it looks. I also wouldn't want to tear the headlights apart again over it.
Old 11-21-2016, 03:58 PM   #19
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
Anyone with the Prolightz fogs as DRL harness install these yet?
Old 11-22-2016, 07:36 PM   #20
pcheninhk
Member#: 423460
Default Help
+1 Would appreciate to see how you guys install the wires
pcheninhk is offline   Reply With Quote
Old 11-23-2016, 10:16 PM   #21
jct133
Member#: 394173
2017 WRX Limited
Lapis Blue Pearl
I want to but haven't yet. I've seen at least 1 or two done that way but not sure where.
Old 11-24-2016, 12:11 AM   #22
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
That's good that it's been done, I have the Subispeed C-Light as DRL harness too so I can tap into that if I need to. Going to wait for the inevitable V2 to come out before I buy I think.
Old 11-25-2016, 11:45 PM   #23
biserker1
Member#: 427273
2016 WRX Limited
Question for those that installed with the subsided dRL harness. For the foglight bezel harness - did you just cut off the fuse tap, add the T tap and connect to the DRL harness? Also, where did you mount the balast?
biserker1 is offline   Reply With Quote
Old 11-26-2016, 01:34 AM   #24
Rico LSX
Member#: 458722
2017 WRX 6MT
Looks good! Thanks for sharing. My SubiSpeed LED bezels just came in today, can't wait to get them on! I am still waiting for my Morimoto LED fogs to come in so they can get installed along with Morimoto D2S projectors and a Diode Dynamics C light. I too wanted the Morimoto C light but the shop doing the conversion suggested the DD as it would better match the color temp of the LED fogs/HID's.
Rico LSX is offline   Reply With Quote
Old 11-26-2016, 11:19 PM   #25
DirtyDub
Member#: 404264
17 WRX
LBP
Yes just like that and I just zip tied the ballast onto something. Can't really remember
