Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 06-24-2011, 11:04 AM   #2001
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by dblo View Post
so if they fit and clear the 06 sti brembos, can I be sure that they will clear the '11 sti brembos as well? i found (but havent bought) a set of 17x7 +42 rims that were used on an 06 sti
yes. there's always the option of 05-07 sti wheels.
nhat is offline   Reply With Quote
Old 06-26-2011, 01:31 AM   #2002
dblo
Member#: 285868
thanks, i certainly wouldn't mind finding a set of those for cheap
dblo is offline   Reply With Quote
Old 07-03-2011, 01:21 AM   #2003
dblo
Member#: 285868
5zigen FN01R 17x8 +25mm, would these fit on 08+ STi?
Old 07-03-2011, 01:05 PM   #2004
nhat
Member#: 140163
03 STi
hellaflunctional
yes but it's nowhere near an ideal offset. you're looking at a lot of mods to fit those without rubbing.
Old 07-03-2011, 03:24 PM   #2005
Scargod
Member#: 260314
2007 STI
silver gray metallic
Default Need to study-up
Use these:
http://www.1010tires.com/wheeloffsetcalculator.asp
http://www.rimsntires.com/specs.jsp
http://www.rx7.org/Robinette/tire_diameter.htm
Try and avoid spacers. Any significant spacer would require longer wheel studs. You need full thread contact of the lug nuts!
When you get to a realistic offset (like 40-55), you may find someone who has used the specific rim you are interested in and they may know if it will clear the calipers. Don't hesitate to call the wheel seller or manufacturer and ask if they will clear the Brembos. Some have drawings you can print out and cut out that will show you clearly, in a visual manner, how the wheel will fit.
Scargod is offline   Reply With Quote
Old 07-03-2011, 06:24 PM   #2006
dblo
Member#: 285868
Originally Posted by Scargod View Post
Use these:
thanks! these are very good reference materials
Old 07-03-2011, 11:01 PM   #2007
nhat
Member#: 140163
03 STi
hellaflunctional
www.miata.net/garage/tirecalc.html is another good resource
Old 07-04-2011, 02:38 AM   #2008
littlewhitewagon
Member#: 103068
11 STI sedan
A 17x8+25 would fit very easily, just not the right fit and you are going down from what is stock.
Short answer is don't do it.
littlewhitewagon is offline   Reply With Quote
Old 07-09-2011, 12:09 PM   #2009
nhat
Member#: 140163
03 STi
hellaflunctional
closing it so i can attempt to edit the first post with as many of the new wheels as possible and ask for different information.
Old 07-07-2017, 05:54 PM   #2010
[email protected]
Tire Rack Moderator
Member#: 1215
ext. 4362
re-opened for any new wheel availability
Luke@tirerack is offline   Reply With Quote
Old 07-07-2017, 05:56 PM   #2011
charlesavila
Member#: 461921
I have a question. I know that ypu can't run staggered wheels on awd, but would it be bad say if I was running 18x8 and 18x9 both +35 (on a 2001 Forester L) and use 225/40 r18 on all 4? The amount of tire that would contact the ground the same but I just want to get some insight.
charlesavila is offline   Reply With Quote
Old 08-08-2017, 02:42 PM   #2012
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Hey guys. Need some direction with the new 6pot brembo brakes on the 18 STi I bought a set of wheels from a 2014 STi (17") and they don't clear... does this mean we need to run 18" tires for winter!?
ScoobyDrooler is offline   Reply With Quote
Old 08-12-2017, 05:44 PM   #2013
Homeless Junkie
Member#: 471630
2018 STi, ZL1 1LE
2500 Cummins
Yes
At least five characters
Homeless Junkie is offline   Reply With Quote
Old 09-25-2017, 04:42 AM   #2014
STIGuyx
Member#: 475098
Advanti V3 Pros +35 Fit perfectly
STIGuyx is offline   Reply With Quote
Old 09-25-2017, 04:46 AM   #2015
STIGuyx
Member#: 475098
So do the +30 Offset, just needs a slight roll in the rear.
Old 10-13-2017, 09:53 PM   #2016
Bmize89
Member#: 360896
2006 WRX
I have a 09 sti hatch, I have a local shop that can get me good deals on enkei wheels so that's the brand I'll be going with. I think the nt03's are at the top of my list at the moment but if you guys recommend another enkei rim I'd love to hear your suggestions. I'm not looking to do any fender modifications and at the moment I have all stock suspension but in the future I'll be running RCE yellows. I'm looking to stay with 18" rims and my Michelin as3+'s at 245 width. So with that being said what width and offset do you guys recommend to achieve a flush-ish fitment without any rubbing issues. I don't need to go super aggressive just wanting a better look and better performance. I'll also be going with ARP extended wheel studs and open ended lugs for overall safety. Any info, ideas, expierence, and photos you guys can provide would be outstanding. Thanks again for the support. I'll include a pic of the car at the moment with 2018 wrx limited wheels and 5mm spacers up front (not comfortable running spacers even tho I've had no issues)
Bmize89 is offline   Reply With Quote
Old 10-14-2017, 09:35 AM   #2017
Scargod
Member#: 260314
2007 STI
Originally Posted by Bmize89 View Post
..if you guys recommend another enkei rim I'd love to hear your suggestions. ... (not comfortable running spacers even tho I've had no issues)
I really like the looks of these Enkei Racing RS05RR Bright Silver on my car and they are light. I can't address the exact size/offset you'd need.
Mine are rolled, pulled, cut, etc. These are 10.5 inch width with 35 offset.
I have to run 5mm spacers on the front or my 285 X 30 Hoosiers will rub the coilovers @ 3.2 -camber. I would not be concerned about modest thickness wheel spacers.
What about a 255 X 35 size? I run a Pilot Super Sport 245/40ZR18 as a rain tire on the car... and am often one of the fastest on the track when wet. Softer than your tires.
Old 10-14-2017, 03:34 PM   #2018
Bmize89
Member#: 360896
2006 WRX
@scargod I gotta say those rims look mean yet classy. I'll definitely be looking into them. I just got these tires for all season basically and they're pretty good for daily driving. Im not wanting to track the car at the moment. Nor do I want to do any fender mods at this time...im just trying to find that 'sweet' spot with width and offset.
Old 11-04-2017, 11:55 AM   #2019
xgame4u
Member#: 388901
2018 STI
Trying to find information on the 2018 sti wheel and tire fitment for winter. Anyone already have their winter setup yet? What are you running?
xgame4u is offline   Reply With Quote
Old 11-04-2017, 01:45 PM   #2020
Homeless Junkie
Member#: 471630
2018 STi, ZL1 1LE
2500 Cummins
Check out this: https://forums.nasioc.com/forums/sho...r+wheel&page=4
I put OEM tire size all seasons on my stock 19s and got 19" Volks from another member in the classified.
The way i looked at it, the gap between wheel and fender looks horrible without lowering the car. Coilovers or lowering springs would look sweet but warranty. Therefore I bought, got crazy lucky, a set of light 19s (Volk G12). The setup looks pretty good without lowering and I'm still OEM wheel and tire size.
Old 03-21-2018, 04:24 PM   #2021
Ramzo
Member#: 483671
nice!
Ramzo is offline   Reply With Quote
Old 03-26-2018, 02:08 PM   #2022
scarewed
Member#: 429908
wrong section
scarewed is offline   Reply With Quote
Old 03-26-2018, 05:51 PM   #2023
Scargod
Member#: 260314
2007 STI
Originally Posted by charlesavila View Post
... (on a 2001 Forester L)
Read the thread title! WHEELS THAT FIT THE STi.
Thank you.
Old 05-20-2018, 06:28 PM   #2024
Zumiez87
Member#: 206481
2013 WRX STI
Hey guys. I have a 13 sti and am looking into getting some rs05rr's. I want 18x9 +35. Fenders are already rolled. Does anyone have any experience with this size set up? I currently have 20mm spacers all around and the stocks sit pretty much flush with the fenders. I'm looking for the same "flushness"
Zumiez87 is offline   Reply With Quote
Old 05-20-2018, 07:10 PM   #2025
Scargod
Member#: 260314
2007 STI
You talkin' to me? 2008 STi. (2011 is same as '08, but don't know about '13's)
Enkei RS05-RR, 18" X 10.5" +35ET. Run fronts with 5mm spacers. I am running -3.5 camber. Tires would rub the coilovers without the spacers. YMMV! You will have to figure out strut spring diameter vs my 2.5" dia. coilover springs.
Note: front fenders have no lip and are stretched a bit to make everything clear. I am running 285 DOT radial slicks and coilovers. Rears are fine with just rolling.
I'd say you cannot stuff anything bigger in there without flares.
From this data and a good tire calculator you should be able to figure it out.
You don't mention tires...
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 10:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 02:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 02:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 04:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 01:51 PM
