05-21-2009, 08:13 PM | #1 |
Member#: 118484
SCIC
Vehicle:04 sti RotatedGT35 wrb harman motive tunned |
04 sti hid headlights on 05 wrx?
what has to be done to get 04 sti hid headlights on a 05 wrx? is it plug and play? or do you have to do some wire modding and if so how hard is it? please help guys im selling my sti headlights to a kid with a wrx and need to give him a solid answer..
thanks... rob |
05-22-2009, 05:47 PM | #2 |
Member#: 152591
MWSOC
Vehicle:2010 Jetta TDI Cup Jet Black |
It's not plug and play, but not far from it. Please do a seach, as this has been disscuess 1000 times before...But since im bored, and only have 15 minutes of work left before the long weekend I will chime in.
There is nothing you need to do on your end to make things any easier other then possibly include the leveler switch from the dash, if you do a seach under my name, you will find a write up on how to DIY wire the leveler swithc that you can forward onto your customer. He will need to either build, or buy a headligh wiring harness, this should include a relay that when activated by the stock lowbeam harness, will pull power directly from the battery, as to not overload the stock WRX harness. Although this may not be as descrirpitive as you may have been looking for, like is stated earlier, if you do a search under my name, you will find all the threads you will need as i have done this swap in the past, and made some threads pertaining to it with pictures. **EDIT** Here is the info for the levler switch wiring: As far as the wire harness to power the ballasts, ANY quality HID wiring harness that has a relay and doesnt rely on the stock wiring (meaning it pulls the power directly from the battery) will work. These can be sourced anywhere from $10-$100 If i can find where i purchased mine, i will post that link as well. best of luck with the sale. If you didnt get the plugs with your headlights, and cant find plugs for it, here are the pins for the USDM 6 pin (8pin with 2 dead pins levler switch) if you need the schematic for the leveler system let me know i have it. Switch Headlight Pin Pin SW0 - 7 1 SW1 - 6 2 SW2 - 3 3 SW3 - 4 4 +12V- 2 5 +12V GND - 8 6 GND |
05-22-2009, 09:03 PM | #3 |
Member#: 118484
SCIC
thanks bro i dont want to pull my leveler im just selling him the headlights and want to get them to turn on and off and get the high beams to work.
05-23-2009, 07:02 PM | #4 |
Member#: 152591
MWSOC
High beams are P&P and the low's only require the harness like i stated the turn signals are PnP as well.
But why not inlucde the leveler switch? It does nothing for you without the STI headlights. Nothing at all. So it seems like your selling an incomplete set. But that is for you and him to decide. Just my .02 |
05-25-2009, 04:03 PM | #5 |
Member#: 118484
SCIC
i sold these for dirt cheap but thanks for the info.
05-25-2009, 08:38 PM | #6 |
Member#: 159057
Vehicle:2004 ts wagon aspen white |
hey rob, if you don't care about leveling, it's pretty easy, you have three options
1. buy the oem sti wiring harness from lightwerkz (easiest, safest, i did this and it works perfectly ) 2. make your own wiring harness that draws power from your battery, and has inline fuses, and relays, etc. (saw some bug eye guys do this with their jdm/sti headlights, i'll post links if i find them again) 3. cut and splice the plugs to your current low beam wires (some say this works, but others say this could causes malfunctions with your wiring harness) hope this helps, good luck, pm me if you have any more questions |
Similar Threads | ||||
sti hid headlight on a 2002 wrx | giuseppelosi | Interior & Exterior Modification | 2 | 12-05-2009 02:00 PM |
04 sti cv joints on 05 wrx | nickd05wrx | Transmission (AT/MT) & Driveline | 1 | 02-28-2007 06:18 PM |
04 STi Shift Trim on 05 WRX Console? | D-Speed 2.5 | Interior & Exterior Modification | 2 | 12-27-2005 12:12 PM |
04 STI complete headlight and 05 cleared STI headlight housing + more | SpoolinU | Private 'For Sale' Classifieds | 25 | 09-24-2005 09:09 PM |
