09-21-2011, 12:49 PM | #26 |
Member#: 141182
Vehicle:96 Impreza Coupe Black |
Good thread.
96 Brighton coupe: Eg33 Fxt trans 4.44 Wrx 12lbs flywheel 2.5rs rear LSD 4.44 02+ brakes all around 2.5rs body bits 9something legacy turbo trans crossmemeber Sti 5 speed short shifter w/ linkage kit Gutted Hydraulic hand brake 225/65/16 snowtires
09-21-2011, 12:54 PM | #27 |
Member#: 141182
After reading this whole thread, it feels like AA for swapped Subaru owners
"Hi, I'm Scott, I've been swapped for two years. But I still have thoughts of swapping again"... |
10-17-2011, 07:36 AM | #28 | |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
11-22-2011, 03:16 PM | #29 |
Member#: 98777
Just finished my swap.
2002 WRX EJ205 into 1998 Legacy GT wagon. Notes: (I'll add to this) -I used the stock LGT 5 speed transmission. I used a clutch disc, plate and flywheel from a 2006 WRX -Wiring was done by iWire. Brand new OEM bulkhead harness from the Legacy, complete donor chassis harness -Taking the dashboard out sucks. Label everything. Every screw, every connector. You don't want to put it all back together and realize you missed a plug. Twice. -I used a first generation Legacy turbo crossmember. The engine will sit higher than it does in the WRX engine bay. This is ok. The hood closes. -I used the factory Legacy throttle cable (DOHC) and bent the WRX throttle cable bracket slightly so the cable would reach. -I did not hook up the cruise control. Hopefully I wont miss it. The engine bay is cluttered enough. -Relocate the PS pump reservoir. Easy enough. -To retain the factory MAFS and airbox, I used the lower half of the Legacy air box, and the upper half of the WRX box. -I had originally tried the "hack" method for the coolant lines. I cut the spring out of the radiator cap, added a second seal, but could never get it to completely seal. I ended up deleting the waterbox by the intake manifold. Just run a section of hose from the turbo water pipe to the crossover pipe, and set the radiator up like normal. So far so good. -Invest in plenty of zip ties and assorted sizes and lengths of rubber hoses and clamps. -The engine bay gets tight. A set of slim fans might help with clearance up front. -My TMIC fit without any modification to the engine bay. However, to use the duct for the hood scoop, you'll need to cut and drill to get it to fit. -Burp your cooling system afterwards. Theres a step by step procedure somewhere on a forum. -I haven't installed the AC condensor and lines yet. I have all winter to procrastinate. Oh yeah, and of course it was totally worth it. PM me if you have any questions. This job will be burned in my memory for a while. |
11-23-2011, 01:23 AM | #30 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
It's thread like this that make me love subaru.
11-26-2011, 03:53 AM | #31 |
Member#: 200463
Vehicle:2000 2.5 swaped obs silver |
so i guess this is and old and short thread but heres what i did....
2000 obs with 2.2, i hydrolocked the motor being a retard so i decided to swap to a 2.5 n/a motor form a 2000 rs. All i did was swap intakes, drivers cam gear and, crank gear. it ran like crap for about 20 miles until the ecu learned how to run the motor 2 years later its running like a champ |
11-28-2011, 08:34 PM | #32 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
Here's one of mine
http://www.rs25.com/forums/showthread.php?t=84314 My currant project is a 98LGT swap w/ a 02 Wrx Last edited by sense of nature; 11-28-2011 at 09:18 PM. |
11-28-2011, 09:37 PM | #33 |
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
91 Legacy SS automatic with 06 Impreza-i SOHC heads & converted to manual 06 Impreza-i transmission
Sadly I sold the car before it was running 100% perfect because I had like $1500 invested with the purchase of the car an parts. Then found that it was not going to be tuneable unless run on stand alone management, witch would basically more have doubled the cost. It ran great when in boost but at idle and low RPM it was ragged and pig rich. Full Story Here: http://forums.nasioc.com/forums/show...highlight=crap I also currently own a 02 Impreza RS with a 04 STi swap Full Story Here: http://forums.nasioc.com/forums/show...highlight=swap I lost my 97 OBS with 02 WRX swap last year in Oct..... but I did not do that swap.....bought it already done |
11-29-2012, 11:02 PM | #34 |
Member#: 73974
Vehicle:04 RSTi PSM |
i guess ill chime in...
06 WRX EJ255 into a 00RS.. did the full drive line with interior swap as well so used about 90% of the WRX harness and just had to re wire the fuel pump tail lights doors and sunroof/dome/map lights... wasnt too bad though fairly straight forward if u have access to the wiring diagrams...need to tweak a couple things like my dash beam and then clean everything up yet, but functionally i am good to go!!! lots of mods on her too...plus she will be flared and painted up shortly as well the hood is off of my DD which is Sedona Red Perl...i traded my hood from this car for an L hood as i have a front mount that just needs the piping tweaked and then ill be rockin a 9K vent |
12-03-2012, 12:28 AM | #35 |
Member#: 211224
RMIC
Vehicle:2005 Saabaru Who knows |
Dam I thought I had a problem, But then read about your guys swap stories. Kidding!
Here goes my list 1996 gf wagon w/ a 2005 wrx wire merged ecu ( did myself and that was fun) 01 ra geared rs trans 4.11 full wrx subframes and brakes kw v1s and ran 11.8 1/4 miles Next is my 05 fxt has a v9 jdm 2.0 and full 6 speed swap on 255/45/17 17x9s has a 32 bit ecu! currently on winter setup before winter mode btw thats a 2" hit on the back and lastly MY99 gc 4 door coupe has a ej257 modded to run avcs on a 16bit jdm ecu has a 05 lgt box in it with full 02 wrx interior swap This is another great sleeper of mine. bumper has been fixed since this picture |
01-22-2013, 06:16 PM | #36 |
Member#: 291684
Vehicle:2004 Rs (Wrx Swap) San Remo Red |
Kevin T
(17 y/o) Car: 2004 2.5 rs.... San Remo Red Engine: 02wrx ej205 (everything needed to get this in came from the WRX donor car) full 02 wrx harness along with anything that is hooked up to the harness (including airbags) Turbo xs uppipe Nameless downpipe xtp stage 2 tune Silicon turbo inlet 3" catback (it changes a lot) Trans: 04rs trans 4.11 final drive 04rs rear diff. Act street disk Act pressure plate for a 4puck ceramic kit Short throw shift kit Suspension: Stock wrx struts Eibach 22mm f/r swaybar kit HD endlinks 02 wrx ront brakes (rears will be replaced when the RS ones go bad) Aftermarket Trailing arms Whiteline Steering rack bushings. Misc: Full 02 wrx interior 04 rs gauge cluster (keep the mileage the same) Glowshift boost gauge ($15 special) Pioneer DEH-P5800mp headunit PSM 04 sti hood w/04wrx hoodscoop. (hard to find SSR wrx hoods) |
02-18-2013, 06:24 PM | #37 |
Member#: 57156
SCIC
Vehicle:2007 V.8 207 STi Mercedes Polar White |
There are some nice swaps in here
10-25-2017, 03:48 PM | #38 |
Member#: 167794
Vehicle:08 500+whp sti |
1971 911t
-steel widebody 964ish style -kep adapter -eg33 motor odb1 with a chip -915 transmission so far so good, but plan to get it running on a standalone and do more work over the winter. no pics here, but have them on instagram as red911build. |
01-11-2018, 02:53 PM | #39 |
Member#: 73974
I take it you needed an adapter to mate the transmission?? Open or limited slip diff?? What kinda power does that trans hold?
01-11-2018, 02:53 PM | #40 |
Member#: 73974
02-25-2018, 03:18 PM | #41 | |
Member#: 482578
03-19-2018, 02:50 AM | #42 |
Member#: 425415
BAIC
Vehicle:66 Bug with ej20g |
I did an ej25D, now ej20g (robtune 'd)into my 66 bug. Currently doing an 2.2 into a bus. And building a beefy turbo ej251 for some real power
I learned that the recommended 5-30wt oil is not good with boost. Subaru's like to be bled from the outlet to the top hose Compatibility between pretty much all engine parts as I have mixed and matched around And more about swapping Subaru to vw than I cared to remember, so I wrote a 19 page guide to remind myself of all the details Mid engine with a Subaru tranny coming soon |
Similar Threads | ||||
Auto to Manual conversion successful! | PaulN | Transmission (AT/MT) & Driveline | 6 | 04-19-2009 12:08 PM |
Rear disk conversion/diff conversion | the mike | Subaru Conversions | 5 | 12-19-2004 08:50 AM |
'95 L Steering Pump Repair - Conversion to MY00 Pump Resevoir: Success!!! | Kostamojen | Subaru Conversions | 4 | 06-27-2003 04:23 AM |
WRX Front Rotor Conversion and Legacy Rear Rotor Conversion on a 01RS? | RS_NW | Brakes, Steering & Suspension | 4 | 08-09-2002 09:34 PM |
Poll: What type of board or boards do you ride & what would your next purchase be? | breaka19 | New England Impreza Club Forum -- NESIC | 21 | 10-09-2000 09:02 AM |
