01-17-2018, 01:58 PM | #1 |
Member#: 403329
Vehicle:2003 wrx stage 3 |
Grinding noise braking on slippery surface.
Hi guys, starting a new thread since I can't find anyone who has had this problem.
After getting the classic center diff binding I replaced it with a supposedly known good diff from a 13 WRX. First drive out I got on the brakes on snow and while the wheels began to lock up I heard an awful grinding noise which seems to come from the tranny. Wondering if maybe the whole time my problem was in fact the rear diff instead of the center, I went ahead and just replaced it with a newer unit. Now I still have the problem, and I am stumped, it seems like the only assembly that could cause this noise would be the center differential considering I can reproduce the noise while braking in neutral. It also seems worse when I pull the hand brake rather than braking, which would cause the c diff to work the most. Am I missing something? Should I go back to the shop that sold me the used center diff? Thanks!
01-17-2018, 02:25 PM | #2 |
Member#: 47143
Are you talking about the noise that the ABS makes when it is trying to stop your wheels from locking up?
01-17-2018, 06:23 PM | #3 |
Member#: 403329
01-18-2018, 11:04 AM | #4 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
So, you have now installed used center and rear diffs? And, you still have the noise. Did the sound get any better with the installation of either diff? I can't think of a good test, just getting more info for the next person...... |
01-18-2018, 12:19 PM | #5 |
Member#: 448391
I had a very similar noise in my 02 Impreza. When braking softly at low speeds on wet surfaces I would get a horrible grinding noise from under my car. Sounded like from/center diff. I found out that the previous owner ran snow chains on the rear of the car during the winters and none on the front and toasted the center diff. I replaced the transmission+center diff and the noise and issue went away.
You might have gotten a bad diff. If you have a friend with a shop/lift you can put the car up in the air and let the car roll at low speed then have them lightly pull up the e-brake and see if you can pinpoint where the noise is coming from. |
01-18-2018, 01:16 PM | #6 | |
Member#: 403329
Good thinking, I have a lift at work and will see if I can pinpoint it with a stethoscope. Seems to me the only possible culprit is the center diff. That's right, I have replaced both diffs with used ones. The center was a 2013 WRX, and the rear from an 05. |
