Welcome to the North American Subaru Impreza Owners Club Sunday June 15, 2025
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC > SWIC Vendor Classifieds
Old 11-28-2007, 04:00 PM   #1
IA Performance
Vendor Sales Rating: (61)
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default RA Gearsets ~ RA Gearboxes ~ Clutches ~ and more
Black Friday Special, $1450 shipped 48 for (1) RA Gearset. Available only on 1 set. Once it is sold then the remaining units will be at the price stated below.
Gearsets:
Our shipment has finally arrived. We have 2 RA Gearsets ready for new homes. Each set is Cryo and Micro Polish Finished. These bad boys are built to withstand ~350-390 whp of raw Subaru power!. Plus, check out the ratios, this is how Subaru should have built the WRX from the factory. If you would like, you can retain your stock 5th gear assembly for highway cruising. More gear set information can be found below in this post.
Priced at $1599 shipped 48 (used to be $1450, but we now have added cryo and micro process)
Assembled Gearboxes:
Take the guess work out of the install and let one of our Subaru Master Techs build your gearbox for you. Each box comes with new Synchros and Bearing sets installed. Stock 5th gear is also optional for same price. Direct plug and play for Subaru 5 speeds. Please denote model year when ordering. $2650 + $800 refundable core + ship
Bearing / Synchros:
We also have Bearing and Syncro sets in stock ready to ship with these at no added shipping charge. Plus these are Subaru factory parts, sold cheaper than your local dealership.
  • Bearing Set $360
  • Syncro Set $305
Clutches:
(free Next Day ship on clutch only good with purchase of RA BOX, otherwise you get free ground ship)
Exedy 5 speed stg1- $499 shipped w/ free next day air
Exedy 6 speed stg1- $450 shipped w/ free next day air
Exedy Twin disc 6 speed- $1599 shipped w/ free next day air
ACT 5 speed stg1- $550 shipped w/ free next day air
ACT 6 Speed stg1- $569 shipped
Short Shifters:
Cobb Short Throw Shifters. All apps in stock.
6 spd- $165 shipped 50 & PR
5 spd- $135 shipped 50 & PR
Shifter Bushings and Mounts:
Cobb Shifter bushings
6 spd- $35
5 spd- $30
Subaru Group N lower transmission mounts
6spd- $79, free shipping 48 states when purchased with any other item
5spd-
Subaru Group N pitch mounts (5spd and 6spd same part)
5spd and 6spd- $39.99
STI Type RA Gearsets 02+ WRX
Close ratio gears from the STi RA feature strengthened and hardened components for improved reliability of the 5MT in modified Imprezas. Treated gearsets now feature optional cryo w/ micro-polishing for improved reliability, strength, and reduced frictional losses. Each gearset includes all necessary parts for installation including a custom speedometer gear (specify 3.9, 4.1, or 4.4 final drive ratio when ordering).
Non-turbo adapter kit includes additional parts to allow proper fitment of the gearset into non-turbo applications. Professional installation is recommended. Gear Kit Includes
STI RA Main Shaft
STI RA 1st Driven Gear
STI RA 2nd Driven Gear
STI RA 3rd Driven Gear
STI RA 4th Driven Gear
STI RA 3rd/4th Driven Gear Cluster
STI RA 5th Drive Gear
STI RA 5th Driven Gear
3rd/4th Shift Fork Rod
3rd/4th Synchro Hub Set
4th Gear Thrust Washer
Lock Nut, Main Shaft
Lock Nut, Pinion Shaft
Lock Nut, Driven Shaft
Oil Seal, Main Shaft
Custom Steel Speedometer Gear, Calibrated for 3.90 Final Drive
Case Gasket
STi RA ratios: 3.083 (1st), 2.062 (2nd), 1.545 (3rd), 1.151 (4th), 0.825 (5th)
Optional Items
  • Cyro/Micro finish:
The treatment is a 2 part process. The 1st part is a cryogenic tempering process designed to compliment the original case hardening and stress relieving done by the manufacturer. The cryo treatment helps to convert the metal's structure to a uniform crystalline configuration which reduces areas of stress concentration which could otherwise serve as a starting point for failures under high loads. The 2nd part involves a unique micro-finishing porcess that leaves all of the gear surfces hightly polished. This helps to reduce friction between the gears. The benefits include reduced power loss through the transmission, reduced oil temperatures (which improves shifting performance under severe conditions), and improved break-in and longevity.
All Major CC's and Paypal accepted.
Stephen
IA Performance is offline   Reply With Quote
FS (moco, MD): PPG1/2 s/c, 3/4 LGT Gearbox, clutch, and lightweight flywheel GreenLantern MAIC Private Classifieds 18 03-28-2009 08:04 AM
WTB: RA Gearset or Gearbox gling NESIC Private Classifieds 7 06-10-2007 09:57 AM
Now on Ebay... ra gears, aem, perrin, zerosports and more hybrid gti 2 Private 'For Sale' Classifieds 38 05-25-2006 02:56 AM
Ver. 6 STI RA gearsets in stock! ACT and Exedy Clutch combos! Gruppe-S Drivetrain 11 02-09-2006 03:39 PM
CA: New Exedy Sport Clutch and more grantn Private 'For Sale' Classifieds 0 07-22-2004 06:09 PM
