#151 |
Member#: 413709
![]() Just ordered my harness from the alternate source that Joe used. Compete harness for $49. Pm Joe for details. I'm glad I did.
#152 |
Member#: 410714
![]() Just an update on satellite radio. If you don't plug in a satellite antenna you will get a warning message "check antenna" each time you turn on the head unit.
The closest adapter I've found is this:- Fakra "Z" Plug male to HRS GT5-1S It will require a sharp knife to cut the plastic ends a little as neither connector is a prefect fit, but they are both VERY VERY close. Round end is too deep, so you need to cut it back, the square end has one extra tab/corner that you just need to shave off. You still need a real satellite antenna that you plug into the adapter. If you use a Sirius antenna it will work perfectly for audio, but the "now playing" song information will be missing and you will still get the "check antenna" warning message. If you use an XM antenna it will all work correctly and you will NOT get the warning message. I always thought the Sirius and XM antennas were identical these days, but they are not. Last edited by sheep shagger; 02-21-2015 at 07:02 PM. |
#153 | |
Member#: 413709
![]() Quote:
Would this work? http://www.amazon.com/gp/aw/d/B00AQ5T8RA/ref=mp_s_a_1_2?qid=1424491892&sr=8-2&keywords=Glass+xm+antenna&pi=AC_SX200_QL40&dpPl=1&dpID=41iEaLJbh8L&ref=plSrch |
#154 | |
Member#: 410714
![]() Quote:
I used the XM branded mini antenna. http://www.ebay.com/itm/XM-Satellite...item54078828ac Both my round and square Sirius branded antennas worked, but gave the check antenna warning. http://www.amazon.com/Sirius-Radio-Dot-Micro-Antenna/dp/B001Q5DQOU/ref=sr_1_1?ie=UTF8&qid=1424493387&sr=8-1&keywords=Sirius+antennaand http://www.amazon.com/Sirius-Magnetic-Mount-Antenna-Audio/dp/B006ZEW1AW/ref=sr_1_4?ie=UTF8&qid=1424493387&sr=8-4&keywords=Sirius+antenna |
#155 | |
Member#: 413709
![]() Quote:
http://m.ebay.com/itm/371259428025 |
#156 | |
Member#: 410714
![]() Quote:
#157 |
Member#: 413709
![]() Just got an email that my harness is shipping tonight!! Took less than a week from first email to being shipped out.
#158 | |
Member#: 120377
Vehicle:2011 sti-s white pearl |
![]() Quote:
I am French, and here in EU, it is impossible, nothing exists ! it's for that http://ae64.com/NaviTransplantharness.htm |
#159 | |
Member#: 413709
![]() Quote:
Most parts to assemble your own are originally made in China, so you should be able to source the parts online. |
#160 | |
Member#: 410714
![]() Quote:
www.autoharnesshouse.com |
#161 |
Member#: 410714
![]() Here is the finished harness.
![]() This post has the list of parts This is the pinout information ![]() All connected ![]() |
#162 |
Member#: 329459
![]() ^ this is the post i followed to get my harness done. and all works 100%
#163 |
Member#: 407839
Vehicle:2001 RS black |
![]() might need to get this
#164 |
Member#: 413709
![]() Last edited by mauldin; 02-27-2015 at 05:26 PM. |
#165 |
Member#: 329459
![]() Yeah you ll see how much cleaner your audio will sound
#166 |
Member#: 413709
![]() Harness just arrived from autoharnesshouse.com and fits perfect.
#167 |
Member#: 413709
![]() Install went perfect!!
#168 |
Member#: 329459
![]() Im glad everything went 100%
#169 |
Member#: 413709
![]() In my opinion this HU sound night and day better. Just waiting on the XM antena adapter and USB adapter that goes into the Fujitsu side to make it truly 100%. I'm confident the USB will connect right up and the XM will work. Crazy how easy the install went. I didn't have to add any wires or solder/crimp/cut into anything.
Via Bluetooth my iPhone 6 synced up and downloaded my phone book into the HU. OEM microphone, SWC, etc all worked. |
#170 |
Member#: 413709
![]() Might be a good deal if the bids don't get to high. BRZ Nav HU with all parts needed to install. Not mine. Just browsing ebay and saw it.
http://m.ebay.com/itm/121581822403 |
#171 |
Member#: 120377
![]() thank you, I'll try to contact autoharnesshouse.com
#172 |
Member#: 413709
![]() Used to Navigation on the way to work while streaming Bluetooth audio. Worked perfect. Not sure where all the complaints about the OEM Nav (around the web) is coming from.
#173 |
Member#: 329459
![]() Yeah this navi unit work flawlessly ...its just awsome
#174 |
Member#: 413709
![]() I was just told that my pictures haven't been showing. So here are a couple.
![]() ![]() ![]() Last edited by mauldin; 03-05-2015 at 10:22 PM. |
#175 |
Member#: 329459
![]() Looks awsome
