Welcome to the North American Subaru Impreza Owners Club Tuesday June 17, 2025
Old 05-06-2004, 11:48 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Cobb Accessport and other brand TBE's
I've got an 04 WRX wagon and I ordered my Cobb Accessport the first day I got it. Hopefully, I'll have my Accessport in the next 4 weeks or so but in the meantime I'm doing some suspension modifications. Additionally, I'm considering starting my turbo back exhaust by purchasing a catback. I really like the Borla Hush for it's stealth-ness and price (under $500) but I'm worried about compatibility with my accessport. Do the Cobb stage 2 maps apply to any turbo back exhaust? or are they really optimized for Cobb's system? Basically, how versatile is my accessport?
whtlegacy is offline   Reply With Quote
Old 05-06-2004, 11:54 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Any will work... infact there was a thread last week about this same topic. Depending on the quality of the system you may or may not hit target boost.
Exhaust reading....
http://www.cobbtuning.com/tech/exhaustdesign/index.html
http://www.vishnutuning.com/exhaust101.htm
Old 05-07-2004, 12:09 AM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I read over those documents and it sounds like the Borla is a great solution. I believe it is 3" piping which is what Cobb recommends but I'm now reading that some people have had problems fitting the Borla to certain downpipes. Anything I should know about this catback before I pull the trigger? I'll probably buy it early next week after doing a little more research.
Old 05-07-2004, 06:57 AM   #4
whittleman
Member#: 14873
2002 WRX Wagon
Rich at Daddy's sells Borla and is always a great help. I suggest you ask him.
whittleman is offline   Reply With Quote
Old 05-07-2004, 09:27 AM   #5
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
that's actually who i'm talking to about this. thanks though.
Old 05-07-2004, 02:50 PM   #6
RayO
Member#: 42329
2002 WRX sedan
I think that you need a downpipe and not just a catback to fully utilize the Stage 2 map on the Accessport.
I'm guessing that Stage 1 with anybody's catback would be fine. I'm planning to add a Cobb catted downpipe after I get my Accessport. My plan is to use Stage 1 until the downpipe is installed, and then move to Stage 2. I've already got a Prodrive axleback.
RayO is offline   Reply With Quote
Old 05-07-2004, 03:13 PM   #7
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I understand that you also need the DP for stage 2. I'm going to be running stage 1 until I complete my TBE.
Old 05-07-2004, 06:42 PM   #8
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
You can always get the cat-back exhaust and use the AccessPort to program a stage 1 increase, and once you get the dp, you can change it to stage 2. That is the best part of the AccessPort. You can switch pretty easily... but you don't want to switch too many times between stage 1 and 2, as that WILL lower the life of the ECU. Changing the maps with the Accessport however will not.
Happy hunting!
paintbing is offline   Reply With Quote
Old 05-07-2004, 06:53 PM   #9
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
how does switching change the lifespan of the ECU? i know Cobb had to overcome some ECU limit on reflashes but what's the story with this?
Old 05-07-2004, 07:13 PM   #10
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
You can switch real-time maps as many times as you want, there is no limit.
However, people say that you can only reflash the base map up to 100 times, but I'm not sure if anyone has actually reached that limit. Fortunately, you rarely need to change base maps with the AccessPort.
drees is offline   Reply With Quote
Old 05-07-2004, 07:38 PM   #11
DtownIan
Member#: 31447
'82 Volvo 245
turbo/intercooled/4-spd
1. Cobb's AccessPort will work with any catback. It's not Cobb specific because a pipe is a pipe.
2. The Borla Hush has had problems mounting to the stock downpipe because the stock dp uses a doughnut flange (for flex). It's not really a big deal because you can probably get it to fit pretty well. Also, once you replace the downpipe with an aftermarket piece, the Borla will mate up fine.
3. Getting a new dp isn't Cobb specific either.
DtownIan is offline   Reply With Quote
Old 05-07-2004, 08:34 PM   #12
Trevor723
Member#: 57989
2016 .:R
LGM
This is backwards if I remember correct, the Hush uses the doughnut flange and mates poorly with the aftermarket flat flanges.
Trevor723 is offline   Reply With Quote
Old 05-08-2004, 01:41 AM   #13
Daddy's SCP
Member#: 36596
2009 135i
Alpine White
Any downpipe that was designed to use the factory style 2.5" donut gasket is the ideal mate for the Borla Hush, that includes the factory 3rd cat pipe as well. Most of the people that have had some issue with the Hush are people using DPs that use thin crush gaskets rather than the donut gasket, with most posts that I've seen referencing the "Helix/Invidia" but the story will be true of any DP that does not use the donut gasket. The picture below tells the story. You can see how the flang that mates to the donut gasket is on part of a slip joint pipe section that flares like a trumpet at the end to allow it to fit securely over a donut gasket, not a thin crush gasket. Some people have been able to use it with "non" donut gasket downpipes but results will vary and it wouldn't be my recommendation unless you planned on taking it to a local shop to have a different flange welded on.
- Rich
Daddy's SCP is offline   Reply With Quote
Old 05-08-2004, 10:56 AM   #14
blarg
Member#: 17811
blue
borla hush = cat-back....you still need a downpipe and high flow cat/cat delete to run stage 2 maps.
blarg is offline   Reply With Quote
Old 05-08-2004, 10:59 AM   #15
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Cobb AccessPort V2...Practically Brand New LTBlackBird Engine/Power/Exhaust 7 09-18-2009 01:48 AM
FS: Cobb Accessport and other items from 2002 WRX! ezatnova Engine/Power/Exhaust 3 04-19-2007 11:50 PM
WANTED!! STi Cobb Accessport or other EM Enchantor SCIC Private Classifieds 5 04-06-2007 01:06 AM
COBB AccessPORTs and other great products in stock IA Performance SWIC Vendor Classifieds 3 02-07-2007 05:47 PM
FS: Cobb turboback, ssac tmic, cobb accessport, and cobb springs wrx/zzr Engine/Power/Exhaust 15 09-13-2006 02:33 PM
