Welcome to the North American Subaru Impreza Owners Club Monday June 23, 2025
Old 04-08-2005, 01:41 PM   #1
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
Default are there any low profile all terrain/mud tires?
anyone know?
maybe not necessarily low profile but something that would fit under our cars with a 1.5" drop
spankaveli is offline   Reply With Quote
Old 04-08-2005, 02:10 PM   #2
fliz
Member#: 30342
mud tire on a car w/ 1.5" drop?
I was looking for a cheap tire to stud the other day, and found a couple truck tires in 195/65/16.
It's got a 26.1" diameter, as opposed to stock 24.9, so I'm not sure what fitment would be like.
If you want a real off-road tire, your best bet is to find some 15" rims and get rally tires.
fliz is offline   Reply With Quote
Old 04-08-2005, 03:42 PM   #3
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
thats basically what im looking for
any links?
Old 04-08-2005, 03:56 PM   #4
fliz
Member#: 30342
any links?
www.specialstage.com has links to vendors for rally supplies.
One I found in a quick scan was: http://www.revousa.com/revolution_rally.htm
Old 04-08-2005, 04:21 PM   #5
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
i just want to go play in the mud some more and these kumhos dont grip for crap.
Old 04-08-2005, 05:38 PM   #6
fliz
Member#: 30342
If you're not afraid of a little work, you could get a cheap set of snows or all season tires and cut out half the tread blocks.
www.discounttiredirect.com has $50 Coopers that you could modify to make a good mud tire.
All you really want is a tire with large gaps between the tread blocks, so it doesn't clog w/ mud.
Old 04-08-2005, 10:10 PM   #7
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
that's a thought...
Old 04-09-2005, 12:40 AM   #8
ashumo
Member#: 51318
89 SVX Syncro
im running boggers on my beadlock rota's, 215/40/18.
ashumo is offline   Reply With Quote
Old 04-09-2005, 05:45 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
I've thought about this too. I've done a good amouont of looking for both tire that can handle gravel well and deep snow in winter.
Winter tires may prove to be a good setup. Most are usually nice and soft with a good, aggresive tread block. They'd do well in loose gravel and mud, but you might not like them so much on packed where the surface can get near asphalt-like and the tread may not be as sticky.
There just aren't truck tires available in such a low profile.
An option other than winter tires is just very aggressive passanger car tires. There are a few out there that do offer an aggressive tread pattern. The ContiExtremeContacts offer a good tread pattern yet strong on-road traction as well. Then you have BFGoodrich Traction T/As that seem to do well on most everything. Stepping down to performance tires you've got Firestone's Indy 500 tire, again a good all-around tire that works well on everything(personally had these, loved them). I'm sure there are others that can do well on rougher surfaces. I personally haven't looked at much lower class tires.
If you're looking at pure mud, deep stuff, a "normal" tire still may not provide enough. You might be better off with a dedicated rally tire if you really need a very good off-road tire. You just can't find much available other than 15" rims though.
Are there any 5 spoke all black wheels with no chrome lip? GetUpKid Tire & Wheel 21 12-22-2006 11:14 PM
are there any websites other than the tire rack attitude Off-Topic 2 10-12-2004 07:16 PM
Are there any Mini Cooper Forums that are any good? mrtrex Off-Topic 8 06-06-2004 12:54 AM
are there any stand alone engine management which keeps your air and all functions. STEALTH-WRX Engine Management & Tuning 1 11-01-2002 08:34 PM
Are there any snow tires for 17" rims? codemunky Brakes, Steering & Suspension 3 12-03-2001 02:22 PM
