#101 | |
Member#: 96276
Vehicle:2002 WRX Silver |
![]() Quote:
![]() you call call it a "Muffler" -Jesse James
#102 | ||
Member#: 89165
Vehicle:Poop Stuck Survivor -=C=- & subari87 FOREVER! |
![]() Quote:
#103 |
Member#: 89165
![]() Thermoforming the cover for the hole I created on the top of the muzzler. Material used is 5/16" flame rated Kydex T.
Kayak/cargo straps to help in shaping... ![]() ![]() Done ![]() Indent in top helps with proper placement/alignment insuring tight fit. ![]() ![]() |
#104 | |
Member#: 66558
NESIC
![]() Quote:
#105 |
Member#: 84912
SCIC
Vehicle:2003 2.5L bugeye now with 6 spd 20g! |
![]() ^ I've wanted to try that. I did cut all the piping and weld a 3" catback pipe to the stock sti muffler. The annoying noise at the shift got even worst. I had to ditch the catback. It had some rumble to it, but it just didnt sound right when you revved it.
Im just going to leave it as is. I have a 3" electrical cut out to help me get those exhaust gasses out now. ![]() |
#106 |
Member#: 20872
Vehicle:t3h rubber-neckers must die! |
![]() easy.
#107 | |
Member#: 89165
![]() Quote:
![]() ![]() ...Will work on it more tonight... |
#108 |
Member#: 20872
![]() damn. what are you cutting with?
#109 |
Member#: 84188
Vehicle:05 legacy caravan full of kids now |
![]() when your done i wanna hear it im in souteast wisconsin
#110 | ||
Member#: 89165
![]() Quote:
#111 |
Member#: 89165
![]() Not to cross-post... Well ok, I did post an update on my thread in another forum. But I haven't seen anyone here on the other thread, so I will update my progress here, too.
OEM Muffler Hack Stage 0.1 will be installed when i am done writing this. Some progress: ![]() And then I lost two pics. I basically made the rectangular hole in the left tailpipe larger, I smoothed out some of the inside edges with a grinder, cleaned everything out the best I could, and temporarily sealed it up for the stage 0.1 test run. Sealed up temporarily: ![]() I have two rows of 1/4" closed-cell weatherstrip sealing the cover. It looks and sounds like it won't work, but the cover is on tight, so we'll see how it goes. Again, inlet pipe is gone, upper velocity stack thingie is gone, tailpipe sections are opened up but otherwise intact, and the two interior walls are intact. I don't expect this configuration to sound too good. We shall see... |
#112 |
Member#: 20872
![]() can't wait. are you going to upload a sound file??
is it too much to expect stock, stage 0.1, stage 0.2, etc?? |
#113 |
Member#: 89165
![]() I am back from test drive 0.1.1 . No exhaust leaks from the temporary, so that's good. However, after a hard, high rpm 7-8 minute drive, the top of the cover over the opening was starting to soften ever so slightly. I have thought about this possibility, and will install a counter measure when I go to Stage 0.2
General impressions: Yep, it doesn't sound so stock anymore. The beat of the boxer 4 is definitely more clearly defined at idle. To my surprise, there was more of the lower frequencies present. The volume was slightly louder than stock, but no where near obnoxious - at all. Driving. omgbuttdynosays20+hp!!1!! No, not really. If anything, throttle response seems ever so slightly faster, but this may just be a psyche effect. Inside the car, one can definitely tell that something is different. I have the intake silencer removed, and the airbox lower drilled. This intake configuration, when coupled with the stock WRX axleback or STi axleback gives me more engine sound in the cockpit than exhaust sound. With the Stage 0.1 muffler hack, the sound difference between engine noise and exhaust noise was more balanced. At lower rpm, I still had more engine noise, but when the pedal went to the boards, sound levels evened out between front and rear. Still, nothing was loud or obnoxious - at least in the car it wasn't. Bottom line on Stage 0.1 hack from inside the car = a little lmore noticeable sound than the OEM and STi axleback, but not loud. Lower frequencies are more obvious. You sort of have to be paying attention to notice the difference. Outside the car - Now, I was by myself, so I was a little limited as to what I could do. I noted above what I noticed at idle. I backed up to our closed garage door, leaving about 3-4 feet between the car and the door, left the driver's door open, and worked the throttle. A different sound, yes. Loud, no. It was a more raw, defined sound, but not raspy or crisp. BUT, and this is a big but, as noted by others who have done this sort of mod before, the CHIRP surfaced. This is a slight squeak sound, only prevalent when rpms are falling, and it only occurs somewhere between 2K-1K rpm. It's not loud, and it can only be heard outside the car. When inside the car with the windows up, you can't hear it. It isn't consistently the same amount of chirping, but when it happens, it is the same pitch. This only happens when I back off the gas completely, and let the Rs fall. If one does a controlled decent of Rs down to idle, the chirp does not happen. So, there you go. I am going to take it to work like this tomorrow. I believe I am going to proceed to Stage 0.2, maybe this weekend, which will entail opening up the front inner wall a bit. Regarding sound clips: I have a Recording Engineering degree (Bachelors), a 16-track digital recorder, and a bunch of mics. However, I do not have any mics that I want to expose to the elements at this time, and I am not going to set up my recording apparatus in the garage. I tried to use an old cassette recorder, and was going transfer that into the digital domain, but I could not get satisfactory results from the cheesy little tape recorder. I will put some futher thought into the recording situation over the next few days before going on to the next hack stage. If anyone locally has suitable recording gear and would be willing to meet somewhere, I'd be happy to do so. |
#114 |
Member#: 86849
RMIC
Vehicle:2005 GMC Savana white |
![]() good idea!
#115 |
Member#: 108380
NESIC
Vehicle:2002 SVT Focus CD Silver |
![]() Wouldn't it be cheaper to just replace it?
#116 |
Member#: 85592
BAIC
Vehicle:05 OBP |
![]() yea but what's the fun in that
#117 |
Member#: 51488
RMIC
![]() ^^^ yea, what he said.
That's why when people get in trouble with the cops they run-- to make things fun. J/p |
#118 | |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
![]() Quote:
#119 |
Member#: 89165
![]() Update - commute to work.
Well, things seem to have settled in very nicely... Or something... What I am experiencing today is quite different than what I had last night. Maybe it just needed a little heat to settle things down. Last night's test drive was short and hard. This morning's commute was easier on the gas and longer. I drove about 3/4 of the time without the radio on. Once the car warmed up, I noticed a lower frequency rumble from the rear end. not obnoxious in the car, but more noticeable than what I heard last night. At one intersection I opened my door at the light, but I really couldn't get the full effect. On the way to work, I don't think I got above 5500 Rs. When I arrived at work, I parked, left the car running, opened my door, and gave the throttle a few pokes. Hmmm... NO CHIRP! And there are more lower tones present than were there last night. I got out and listened to things at idle. Yea.. That sounds alright! I went into the building and snagged a co-worker. I asked Aaron if he sould sit in my car and stab the gas a few times while I stood outside and listened. Wow... WOW! Da-yam! Once you get on the gas, it really sounds decent. No chirp, plenty of low-end sound, no air-rushing sound, no leaks from the temporary cover - just sweet boxer sound delivered in a calm, controlled manner. It is still not loud, but it is more noticeable than before. On the gas, the volume does not increase much at all. I switched spots with Aaron, and let him have a listen. As soon as I revved it up, a big grin appeared on his face. Another co-worker on his way into the building said, "Hey, what are you doing hopping up a station wagon?" Yea, I'm happy with this. Quite happy. This configuration does not offer much as far as the cool burbling or after-firing sound, but I think I can live without that. It sounds decent, and I'm going to close it up permenantly when I get some time. I wanted to see if I could get a better sound out of the stock unit, and I definitely believe I did. It's not loud or obnoxious, but it is different, and I maintain the stock look of the vehicle. The project was fun. All cutting - no welding. Woot! |
#120 |
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
![]() I would like the see this done to a stock STI muffler.
ANybody else feel the same way ???????????????????????????? Myles |
#121 |
Member#: 89165
![]() I also have an STi axleback, but I am a little hesitant at this time to cut it open. Once I have my OEM unit all sealed up and running well for a few months, I'll consider the STi hack.
Actually, I've already considered the STi hack. What made the WRX hack so easy was that someone already opened it up and posted the pic. with that pic, I knew exactly what I was getting into. The Sti is a different shape, but I can't imagine the internals to be much different than the 02-03 WRX can configuration. Actually, I wouldn't mind starting with a single-tip 04-05 unit. I imagine those are very similar to the STi internal layout, but with larger diameter piping. Cutting things up and is fun! Putting things back together and seeing them work afterwards is fun and rewarding! |
#122 |
Member#: 70418
NESIC
Vehicle:1968 Ford Bronco 2000 2.5RS Sedan |
![]() ok, it's official, i'm hunting down an OE GT muffler and hacking it apart. i'll weld it back at school if i can.
#123 |
Member#: 59085
NESIC
Vehicle:2002 WRX World Rally Blue Pearl |
![]() an answer that we all wanted
#124 |
Member#: 66152
SCIC
Vehicle:04 wrx sti blue |
![]() Updates!!!
#125 |
Member#: 66152
SCIC
![]() Oh come on update this!!
Does the inside of your windshield freeze? | iyzmi | General Community | 18 | 01-03-2009 10:48 PM |
Here is a bad ass little video of the inside of an engine while it's running. | WRXXXual | Off-Topic | 35 | 10-03-2007 06:42 PM |
Ever wonder what the weight of a subaru in aluminum looks like? | tom@kartboy | Off-Topic | 73 | 07-02-2007 07:21 PM |
So what does the front of your car look like after you removed your FMIC? | disque71 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 10-25-2006 09:43 AM |
What does 104whp, 5k in suspension and big brakes look like ? | RaceComp Engineering | Brakes, Steering & Suspension | 36 | 08-25-2006 11:41 PM |
