Welcome to the North American Subaru Impreza Owners Club Wednesday January 29, 2020
Old 08-23-2019, 04:49 PM   #2151
*Ulimited*
Member#: 139249
Originally Posted by smoky View Post
The front bushing really went bad fast (small one), lots of play in it, wheel was moving quite a lot on both side. That one is not sealed.
The rear one did a bit better, it's also a lot bigger, it's just starting to be lose and not smooth. It's sealed and has grease in it already.
It's hard to tell in the product pictures but can you just press your own bearing into the housing? The EMS one are just held in with a circlip.
*Ulimited* is offline   Reply With Quote
Old 09-09-2019, 08:58 PM   #2152
smoky
Member#: 221439
2004 STI
I have an opportunity to get a used RCE Tarmac 2 for my GD for cheap and would like to know feedback if someone tried it on a SM car. If you have tried one, what was the spring rate with it?
Currently have a set of fortune auto 510, 13kg/mm + 3k helper spring (with lot of preload) in front and 10kg/mm + 4k helper spring (almost no preload) in the rear.
smoky is offline   Reply With Quote
Old 09-10-2019, 01:57 AM   #2153
Thorium06
Member#: 254372
Currently have a set of fortune auto 510, 13k + 3k helper spring (with lot of preload) in front and 10k + 4k helper spring (almost no preload) in the rear.
The RCE is both a step up and down in different ways. The RCE/KWs have nearly unparalleled travel and are amazing at keeping the inside rear tire planted compared to the Fortunes that you’re currently running. Overall just based on this, you’d find time on course.
However, the RCE is limited by the rear valving and the inability to control a spring rate that is needed in even STU let alone SM. The rear shocks begin losing control around the 550lb mark, 650 is really pushing it. I ran around 800-900 out back in STU and threw in some 1000lb springs the night before Nationals this year in SM.
Either way, the KW/RCE shock package is excellent, especially if you stay within the rates they were designed to handle, and is still a large step up over the Fortune setup and other shocks that use a generic shock and adjustable lower mount to fit the same shock on multiple platforms.
Thorium06 is offline   Reply With Quote
Old 09-10-2019, 05:24 PM   #2154
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Is that with or without a rear bar for reference? I'm lifting inside rears on 255 re71s with T2s with their standard rates, but I'm using 25f 22r adjustable bars. But I'm using a Kaaz rear lsd and haven't noticed any ill effects from it yet.
Switching to RCEs over the generic asian coilovers I had before (stance supersport) has been a big improvement for me, but I was only running 8k/6k on street tires.
You may have to raise the car a dab because of the fixed mounting bracket with the RCE depending how low you have it now
I got mine 2nd hand for cheap too, and couldn't be happier with them
T-37 is online now   Reply With Quote
Old 09-10-2019, 06:33 PM   #2155
Thorium06
Member#: 254372
I was only referring to the shocks as being the only variable. Obviously there are other parts that contribute such as the bar, endlink, bushings, total roll, aero ect. But the travel, as you mentioned too, of the KW is far superior to that of the generic asian offerings.
Old 10-14-2019, 04:29 PM   #2156
tsrapophis
Member#: 434904
2002 Impreza WRX
I've recently got my fresh G25-660 build to the track and the dyno and I'm very pleased with the results. 400 whp/350 ftlbs on pump gas with >300 ft/lbs of torque from 4200-7000 rpm. Throttle response is fantastic, from datalogs I can see that I go from full engine vacuum (30kpa absolute) to full boost (20psi gauge or 240kpa absolute) in about 0.8 seconds. If anyone is thinking about it I do recommend it.
build details.
https://forums.nasioc.com/forums/sho....php?t=2910464
tsrapophis is offline   Reply With Quote
Old 12-08-2019, 10:30 PM   #2157
tsrapophis
Member#: 434904
2002 Impreza WRX
I'm thinking about tires for next season and looking at the Yokes A052. The reviews I can scrounge say that it performs but will die extremely quickly with camber challenged vehicles. Has anyone heard anything or used this tire on a Subaru with 2.5-3.5 degrees negative camber?
Old 12-09-2019, 10:50 AM   #2158
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
You'd get more results in the STU thread most likely. The majority of SM people run Hoosiers.
That being said, what I've seen on other cars is low initial camber plus a bad camber curve does end them in 50-60 runs tops. I saw a DS Focus RS cord in 38 runs at Nationals and they'd already been flipped once. Higher initial camber should help, but without roll correction to keep the camber happy I'd guess (and it's just a guess) but you'd likely get 70-80 runs if you flipped and monitored. On something not heavy with good camber AND a good camber curve like a Miata I'd bet 120-140.
Old 12-09-2019, 06:06 PM   #2159
tsrapophis
Member#: 434904
2002 Impreza WRX
Thanks for weighing in, I'll check over on the STU thread. Our local club does an SM street tire class which is why I was considering.
Old 01-27-2020, 11:26 AM   #2160
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Default Headlights
Random question. Is it legal to remove headlights in SM?
Suba_Roo is offline   Reply With Quote
Old 01-27-2020, 12:06 PM   #2161
subydude
Member#: 80649
Dusty
No, they are part of the DOT safety equipment, so headlights, taillights, and turn signals all have to be present and generally working.
Old 01-27-2020, 05:47 PM   #2162
tracknerd
Member#: 53793
02 WRX Wagon
I just noticed in the 2020 draft rule book that is says:
"Diffusers that come as a standard OE part are allowed but may not be modified. They may be removed in their entirety to facilitate other allowed modifications. Aftermarket diffusers or other items acting as diffusers are not allowed."
Not that they probably do too much, but I guess that means 06-07 USDM STi diffusers are open to other years now?
tracknerd is offline   Reply With Quote
Old 01-27-2020, 08:30 PM   #2163
subydude
Member#: 80649
Dusty
Only on the years that came with technically. But I think you can add them to other GD's without modification through update backdate, and if so they'd be legal on those years.
I helped write that rule and the intent was to curb diffusers in general.
Also, those do almost nothing, so unless you want it for the looks I'd save the weight/money.
Old 01-27-2020, 09:56 PM   #2164
tracknerd
Member#: 53793
02 WRX Wagon
Yeah, it's a pretty wimpy example of a diffuser. I'm not a fan of the wings on wagons look but wishing that I had more rear end grip at speed, so can't help but be a little tempted by "almost nothing".
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 06:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 04:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 08:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 11:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 03:33 PM
