10-05-2000, 01:46 PM | #1 |
Member#: 574
Vehicle:99 Impreza RS Black |
Best Clutch + pressure plate setup
I am just curious.
what do you guys think the best setup is for an clutch an pressure plate.. on a turbo EJ25? thats the only thing i have not bought yet... not sure whats best
10-05-2000, 02:13 PM | #2 |
Member#: 526
Vehicle:1995 Supra Turbo Red |
Dunno...what do you consider "best"? Many people have had success with the ACT street setup. Run higher boost, and you'll need the race setup. I am running the Clutchmasters Stage III kevlar clutch and absolutely love it. Feels just like stock, cept that it actually holds boost Sean |
10-05-2000, 02:45 PM | #3 |
Member#: 592
TXIC
Vehicle:'11 X5 xDrive35i '09 135i 6MT/'15 GTI 6MT |
I'll agree with Sean.
10-05-2000, 02:53 PM | #4 |
Member#: 526
Definite thanks to Geoff (SabreLion) for recommending the Clutchmasters clutch. I love it. Sean |
10-05-2000, 02:55 PM | #5 |
Member#: 1454
Vehicle:2000 2.5 RS-T Blue |
Where did you guys purchase the clutchmasters stage III from ?
10-05-2000, 02:59 PM | #6 |
Member#: 216
I really like the ACT setup, that's what I use. It has a heavier pedal than stock, I like it gives more feel.
I heard that iSR came out with a clutch/pressure plate street setup, TMR Impreza (I think) was saying that he has that now and likes it much more than ACT. You might want to find out about that before choosing. |
10-05-2000, 03:36 PM | #7 |
Member#: 574
i just don't want anything thats going to buck the transmission every single time i ease into gear.
so everyone says the clutchmaster is pretty nice then huh? i heard TMR say the ACT setup is a pretty stiff and "*bam*" between gears.. that doesn't sound too nice. i don't drag race i do allot of autocrossing and road racing(tracks of course) . the car should be...(i hope) around 350-400hp its a fully built motor so you can understand i have concerns for the transmission.. [This message has been edited by doripreza (edited October 05, 2000).] |
10-05-2000, 03:39 PM | #8 |
Dynamic Uno
Member#: 1
BAIC
Vehicle:2011 Impreza WRX STi Black |
Tell us more about your car. What motor, turbo, ect.
10-05-2000, 03:41 PM | #9 |
Member#: 28
Vehicle:1997 M3 Sedan Blue |
with that much HP (wow, that is a LOT) the consensus is that the stock tranny wont hold , perhaps even an STI tranny wont hold. as for a clutch I really doubt a full disk street clutch is going to hang on.
get ready for some 4 puck bucking and possibly dog gears to hold that kind of power. doesnt sound too streetable for me. BTW, how you making that much power? was it the Unorthodox Pulley? |
10-05-2000, 03:46 PM | #10 |
Member#: 574
well its a MY99 rebuilt bottem end new rods+pistons lightened crank i'm match porting the head and i'm just getting ready to send the cams out to get a regrind done. new valve springs i'm using an T3/T04E turbo with an front mount intercooler setup. i just got the custom exhaust manifold finished and i'm supposted to be getting an Wolf3d EMS computer in a month or so. and thats about it for the motor.
I'm using GAB rev stroke II suspension , cusco sway bars and tie bars. ohh yeah RX-7 fuel pump...(i hope it holds out..) i just ordered some new 440cc injectors. and i also ordered my TODA flywheel from japan(10lbs) that about does it. [This message has been edited by doripreza (edited October 05, 2000).] |
10-05-2000, 04:04 PM | #11 |
Dynamic Uno
Member#: 1
BAIC
So it is being built as we speak, right?
10-05-2000, 04:06 PM | #12 |
Member#: 574
yeah i'm taking everything apart this weekend and sending out the block for honing..
so i guess a clutchmaster won't hold then? [This message has been edited by doripreza (edited October 05, 2000).] |
10-05-2000, 04:33 PM | #13 |
Member#: 216
I have to disagree with this statement:
"ACT setup is a pretty stiff and "*bam*" between gears" I don't think the ACT setup is stiff at all. It is very easy to engage very smoothly and softly, even slipping it a little if you choose. Sure, if I shift into gear and just drop the clutch (I mean really just let it go), it does go *bam*, but that's what it should do if you drop the clutch. [This message has been edited by Tim Prudence (edited October 05, 2000).] |
10-05-2000, 05:31 PM | #14 |
Member#: 1503
South East
Vehicle:2012 2012 WRX Sedan Silver |
What clutch would you guys recommend for a strong Natural motor, that will see the 1320 about 40 times a year? I launch at 6000RPM with as little throttle as possible and ride the clutch very quickly on first, with powershifting until 4th. Only at the strip, of course. Do you think a N/A setup will damage the tranny. I don't mind damaging the clutch, I don't think I can afford to fix tranny more than once a year. I prefer to not have to fix anything, though. I get 2 second 60 foot times and thats with only a cat-back and intake, on 87 octane.
Zee |
10-05-2000, 05:32 PM | #15 |
Member#: 500
Vehicle:00/+ RS/OBS white |
The clutch/flywheel setup that "Rally Knight"
uses is a two stage 14.6 lb combo that has been great with their 400+HP motor...Its just that the tranny then becomes the weak link in your chain. |
10-05-2000, 08:52 PM | #16 |
Member#: 438
W. Canada
Vehicle:2004 STi White on Gold |
Sorry to be the doubting Thomas here, but I don't think you'll be getting 350-400hp from only 440cc injectors.
IIRC, in last months SCC mag there is a formula to calculate the possible hp based on injector size. Shiv's VishnuPerformance set-up is using 550cc injectors and they were guessing around 350hp from those injectors. With 440cc you should be getting around 280ish HP (still a lot of HP). At that level of power, I would still be concerned about the tranny though. Cheers, MB |
10-05-2000, 09:14 PM | #17 |
Member#: 168
SCIC
Vehicle:2011 M3 and 328i white and black |
So far so good but the ISR clutch and stock pressure plate are holding up just fine.
10-05-2000, 09:30 PM | #18 |
Member#: 574
thanks for the injector input. this is kinda the first run so all my hp figures are wishful thinking.. i still would need to dyno the car and map the computer before any real claims...
anyway back to clutchs.. sorry i didn't want to go off thread here.(not that its up to me) everyone seems to enjoy the ISR setup and the clutchmaster III's.. but mixed about the ACT.. for sure its allot stiffer.. well looks like everyone enjoys there own setups.. is there a clutchmaster IV? or 5 (sprung hub please! hehe) |
10-05-2000, 10:27 PM | #19 |
Member#: 438
W. Canada
Hi Guys,
It was buggin the krap out of me that I couldn't find the SCC article where Shiv calculated the potential HP based on injector size. SO...I found it on RC Engineering's webpage. All the info to calculate is there but to summarize, 440cc injectors will net you approximately 225HP. To get 400HP you would need approximately 790cc injectors and the 550cc injectors with the VishnuPerformance set-up should net you 280HP. Keep in mind these are all rules of thumb because I think Shiv's car is actually higher than 280HP based on what is being said on this board. Anyways, food for thought. Here's the link... http://www.rceng.com/technical.htm Cheers, MB |
10-05-2000, 10:29 PM | #20 |
Dynamic Uno
Member#: 1
BAIC
Marcus, those numbers will vary with different fuel pressures.
10-05-2000, 10:41 PM | #21 |
Member#: 438
W. Canada
Imprezer,
What is the stock fuel pressure for the Impreza? 38/40lbs? Ya, I knew something was missing there because when Shiv did the calc in SCC I believe he ended up somewhere between 320-350HP for the 550cc injectors. |
10-06-2000, 03:29 AM | #22 |
Member#: 6
Vehicle:2013 BMW M3 Coupe Interlagos Blue |
I've been very happy with Primitive Enterprises' 4-puck copper button clutch. (Fair warning, driving in stop-and-go traffic sucks.)
10-06-2000, 07:31 AM | #23 |
Member#: 1447
Vehicle:2000 Impreza 2001 Dodge 2500 |
I have the Act clutch and I like it. It engages smoothly.
10-06-2000, 10:04 AM | #24 |
Member#: 20
I used the ACT for awhile, but it wouldn't hold the boost I wanted run. I then switched to the ACT race disk (4 puck), and within 1 days, nblew up the tranny (it is WAY to harsh for road use, totally on/off with lots of chatter since there are no springs. It did hold the power great, but was obnoxious to drive, and the tranny is not nearly strong enough to hold it. I then switched to a 1996 spec STi-RA tranny (since it uses the same interna;l ratio as the RS box...4.11), coupled with an STi V5 clutch and STi lightweight (14 lb) flywheel. It holds every ounce of boost I have thrown at it, launches great (no slip), and is literally like a stock clutch to drive. great part is that if/when I ever decide I need more, there are endless clutch options for the WRX tranny, whereas the RS one is very limited in selection. Given the scope of work you have on your car to date, I would recommend this route. But then again, you could always go clutchmasters/act till you find you need more (i found 15 psi to be the limit on the ACT), then swap to a WRX box.
10-06-2000, 01:08 PM | #25 |
Member#: 526
FYI: Clutchmasters told me that the Stage III clutch will hold 370bhp on the MY00 Subaru Impreza 2.5RS. They also said that if it didn't hold the power, I could return it for a full refund. I'm running far less power than that right now, but it's good to know I have some headroom. Sean |
Similar Threads | ||||
RA 2.0 block. Flywheel, Clutch, pressure plate, and Upipe | AZScoobie | Private 'For Sale' Classifieds | 17 | 07-23-2004 05:08 PM |
Clutch pressure plate going bad in the Legacy GT | Timmay24 | Transmission (AT/MT) & Driveline | 3 | 11-04-2003 05:02 PM |
Which clutch/pressure plate? | MZM | Subaru Conversions | 4 | 09-07-2003 07:23 PM |
Honda question... need clutch/pressure plate/flywheel recommendations | RallyWagon | Bay Area Impreza Club Forum -- BAIC | 2 | 11-20-2002 02:15 AM |
('93-'01) Balancing flywheel/clutch/pressure plate.... | tomas | Impreza Forum | 2 | 04-26-2001 12:59 AM |
