08-26-2007, 12:46 PM | #1 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
Ion Implanter power wire=Speaker wire ???
ok so there is this Bin @ my work that they throw sliced or cut up computer parts and wires and such...
I work @ a semiconductor company, we build ion implanters. SO I'm assuming all of the wires we use on the machines are going to be rather high quality wire I got ahold of some(45ft) decent what looks like 16 gauge bi-wire that is used as power wire for something or other... I'm assuming this would work great for speaker wire (assuming its OFC??) whata u guys think ???
08-26-2007, 03:12 PM | #2 |
Member#: 78952
Vehicle:2005 WRX CGM |
should be perfectly fine. OFC is really the only thing you need to worry about especially with speaker wire.
08-26-2007, 05:03 PM | #3 |
Member#: 36333
NESIC
08-27-2007, 10:24 AM | #4 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
If I had no clue at all about what kind of wire it is, I would at least hook it up to a meter and see what kind of resistance it has. My guess is it would be fine though.
offset |
08-27-2007, 12:32 PM | #5 | |
Member#: 36333
NESIC
so I'm guessing its got a pretty low resistance But I will throw the ol multimeter on there just for 5hits and giggles. |
08-27-2007, 02:41 PM | #6 | |
Member#: 99289
Just make sure it's listed as AWG. In the end, this is kind of a moot point, as most stuff is OFC because the costs differences are so small. |
08-27-2007, 04:41 PM | #7 | |
Member#: 78952
08-27-2007, 05:45 PM | #8 |
Member#: 99289
This is the first thing I cold find:
http://forums.audioholics.com/forums...ead.php?t=8852 But I know it has been covered elsewhere. Specifically the speaker wire snake oil series. |
08-27-2007, 06:40 PM | #9 |
Member#: 78952
good find.
08-27-2007, 09:35 PM | #10 |
Member#: 99289
Anything to pass along a good tidbit.
08-27-2007, 11:49 PM | #11 |
Member#: 36333
NESIC
sweet....so iether way it doesn't really matter
08-28-2007, 12:18 AM | #12 |
Member#: 22825
NWIC
I've never paid attention to the OFC or not debate... But at the very bare minimum when looking at wire, as long as it had hundrends of strands, I'd know it would fit my application (providing it was the appropriate gauge)
Power flows on the exterior of a strand of wire. And hundreds of copper wires in a 12 gauge wire offer more surface area, thus can offer lower resistance and increased power capacity vs a smaller strand count of wires in a similar "cheap," strand of 12 guage wire. Eitherway, you will be fine. |
08-28-2007, 01:59 AM | #13 |
Member#: 157734
lol
nah im not interested
08-28-2007, 10:12 AM | #14 | |
Member#: 36333
NESIC
08-28-2007, 11:11 AM | #15 |
Member#: 99289
There is a LOT of misinformation about this stuff on the internet, and most of it is bull****. I tried to find something comprehensive, but I couldn't. So here is the quick and dirty.
At the frequencies we are talking about, I don't worry about skin affect, as it's ~3***37;. And even if it weren't, stranding doesn't actually increase the surface area nearly as drastically as people would think. Sure, the outside surface area of the cable is increased, but only marginally. Internally it makes little difference. Each strand does not exhibit skin effect individually, you will not get each conductor with current flowing evenly across the surface. Because each of the conductors are touching, the field strength is uniform through out the cable, with variations for regional wire to wire impedances,variations, air gaps, etc. Because of this, stranding in no way battles skin affect. In fact, at higher frequencies stranding attenuates the signal faster, because of the impedances it creates(more internal capacitance between the strands). This is why high frequency systems get better performance out solid wire, such as RF application, and in wall networking cables(patch cords are usually stranded for flexibility only). However, stranding does introduce gaps in wires, where they can't touch, so the the total effective electrical cross section for the same diameter of stranded wire is decreased. This gap between the individual wires is accounted for in fill factor. When round strands form a triangular pattern, it's usually assumed to produce a wire with ~90% less copper than a solid wire. IIRC, AWG takes this all into affect, and #10 Solid and #10 Stranded have the same effective current carrying capacity. CN: Buy wire that is cheap, and easy to install. That's often the most flexible. |
08-28-2007, 11:22 AM | #16 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
I saw the title and just had to come see.
So Last Resort has the same basic idea that I wanted to convey, which is that at audio frequencies, skin effect won't really make any difference between stranded and non-stranded wire. I'm also a strong believer in the fact that for every imaginary problem that people come up with, somebody is ready to introduce a solution that's expensive. So, skin effect is the depth into the wire that current at a frequency will actually use. The higher the frequency, the less it gets into the wire. At super high currents, it will matter even at low frequency. This is why high tension wire for power transmission is actually hollow tubes. Stranded wire that is not insulated between the strands will be very little different from solid wire from a surface area perspective. Litz wire will offer significantly higher surface area because each strand is insulated from each other. I design switching power supplies for a living and do calculate skin depth for even frequencies of 100kHz. In the MHz regions, especially with resonant mode supplies, it's very important. At audio.....20kHz, it's a don't care. Use the wire, man. Good find. CN: What LastResort said, with some embelishment. jack |
08-28-2007, 11:24 AM | #17 |
Member#: 99289
Thanks for the confirmation. I've done a bit with it, but not near what you have done.
08-28-2007, 04:33 PM | #18 |
Member#: 78952
The only advantage stranded wire has over solid wire is the huge amount of flexibility. I got to play with some Kicker 0/1 gauge which was easily twice as flexible as my knukonceptz 0/1 gauge. Strand count is obviously less though on the Kicker, but for the small drop in total copper to the increased flexibility it's worth the trade off. I'm starting to believe more and more that we should base speaker wire off of average power handling not max, as you just reach an overkill level.
I remember installing a hot tub and I had to haul a dual 0/1 solid core wire through a house...I rather cut off my nuts again than try and make that stuff bend. A sledge became a good friend of mine that day |
08-28-2007, 05:22 PM | #19 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
I know of at least one car install using high end solid core home audio wire... as....
I don't know if i added to, or subtracted from, this post..... loud noises.... !! |
08-28-2007, 05:29 PM | #20 |
Member#: 99289
There has been a move to aluminum wire for really large runs (400A +), but despite the size being much larger(aluminum being less conductive than copper and all), it's hella flexible. I can wrap 1/0 aluminum around a coke can by hand.
08-28-2007, 07:50 PM | #21 |
Member#: 78952
I am wondering if that's what the Kicker power wire is made up of and not tinned copper. I can bend that 0/1 gauge wire around my thumb...and hold it there with my pinky finger
08-28-2007, 09:31 PM | #22 |
Member#: 99289
I can find NO documentation stating what the material is. So I'm guessing you are on to something. Which means it has a reduced current carrying capacity. If that is in fact the case, it's dirty pool to not tell people.
08-29-2007, 10:52 AM | #23 |
Member#: 1026
It's HIGHLY doubtfull if that Kicker wire is aluminum, it's just to brittle to be used in the automotive enviroment.
It's most likely tinned copper with a coating to allow the strands to slide well aginst one another... Higher strand count = better flexibility as well... The insulation helps a ton to.... Try wrapping your thumb or a coke can with standard jumper cable wire.... |
08-29-2007, 11:58 AM | #24 |
Member#: 36333
NESIC
sweet, awesome news... This is my basic understanding anyway.... 90***37; of the car audio wiring market is gimicky CRAP that in no way is any better than the rest of the stuff on the market.
as far as the tinned copper goes... I understand that stuff is alot cheaper than OFC? are there many drawbacks to it ? |
08-29-2007, 12:00 PM | #25 |
Member#: 99289
More like 99***37; is gimmicky crap. And it ain't just limited to the car audio arena.
Wiring - RCAs, power and speaker wire | Chewy-WRX | Car Audio, Video & Security | 3 | 05-07-2004 10:40 AM |
Wiring... shielding speaker wire from power wire | badkid | Car Audio, Video & Security | 3 | 11-14-2003 06:53 PM |
speaker wire crossing the power wire | ants wrx | Car Audio, Video & Security | 4 | 07-11-2003 11:37 PM |
wiring question- keep the amp power, speaker wires away from input wire? | garie | Car Audio, Video & Security | 5 | 06-20-2003 06:25 PM |
Where to route RCAs, power cables, and speaker wire? | Patrick Olsen | Car Audio, Video & Security | 12 | 09-09-2001 01:40 PM |
