Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 08-11-2018, 01:49 PM   #1
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
Default 2004 wrx headlights
So they are 15 years old. I have done the outside many times. They are clear but the yellowing is actually coming from the inside so they donít look good compared to my 16 BRZ.
So I am thinking options.
1. Buy new ones for about 3-400.
2. Buy cheap aftermarket like DNA or halo on eBay. Not sure I like look.
3. Buy used like STIs but likely have similar issue with looking old because they are old.
4. Just leave it.
Any ideas.
Ernest is offline   Reply With Quote
Old 08-20-2018, 09:49 PM   #2
AugyIA
Member#: 487493
I may be in the same position...interested in any replies, as well.
AugyIA is offline   Reply With Quote
Old 08-23-2018, 11:24 AM   #3
kos
Member#: 118334
2006 Carmine Red WRX
2005 Aspen White RS
4. Just leave it.
Any ideas.
You can only wetsand / buff them so many times, before the hazing / yellowing comes back even quicker. Removing just a little bit of material with the wetsand, combined with UV just destroys these lenses.
I've thought about buying new housings from the dealer, and have also thought about going the DEPO, etc alternative route as well.
A buddy of mine did the DEPO route, and just swapped lenses and resealed with butyl tape, and it has held up well for the last 3-4 years, so that may be worth looking into.
kos is offline   Reply With Quote
Old 08-23-2018, 01:29 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
My experience over the last few years.......
Any "quick fix" lasts a couple months.
My method (short version), wetsand down to good plastic, work up through grades with wet paper (start maybe at 600) to 1500. Respray with a UV curable clear, final sand then polish and wax. I use a spray from SEM.
Should last 5 or more years.
Toothpaste, compound, wipe on, you will be redoing a lot.
Old 08-24-2018, 09:52 PM   #5
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
I have done that and the lenses are clear. I think the yellow is from the inside. I will likely buy another set. Just hate paying 3-400 for a stock light.
Old 01-10-2019, 06:53 PM   #6
TreyP
Member#: 322489
04 WRX
Hey so what did you decide to do? I need to replace my headlights as well. I haven't been able to find a good aftermarket set after searching Google & Amazon. I've seen too many bad reviews on Spec-D. I may buy a new OEM set if I can't find a good quality aftermarket set.
TreyP is offline   Reply With Quote
