Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 11-21-2017, 05:59 PM   #51
cramerox
Member#: 447443
SILVER
The holding tank size would depend on how fast you would use the water up and how fast your RO filter can make you more water. The system is pointless if its too small and you dont have enough water.
I would filter RO water and run it through DI filter then into the holding tank. From the holding tank I would attached the sprayer pump.
A system can be as simple or complicated you want it to be. Shoot you can even make drinking water while you are at it. Dual purpose.
Ive linked some things to give you an idea.
http://a.co/i7SVEYk
cramerox is offline   Reply With Quote
Old 11-28-2017, 06:16 PM   #52
PrimoSub
Member#: 478409
'10 ImpOutbackSport
Blue/Silver
Default DI Systems
This information great! I had no clue this was available to DIYers.
PrimoSub is offline   Reply With Quote
Old 01-19-2018, 05:34 PM   #53
pyrokidd89
Member#: 424316
2016 WRX Limited
Pure Red
so how do you figure out how much flow you can get out of the 10" or 20" filters? I have a pressure washer that flow just about 2 GPM and want to make sure the filter system I make can handle it.
pyrokidd89 is offline   Reply With Quote
Old 04-30-2018, 01:40 PM   #54
whiplash willy
Member#: 424843
2016 WRX Limited 6MT
ISM
I had my first real issue with the DI system this weekend. My makeshift stand's cheap wood had rotted to the point, where it collapsed and broke the right hand side pvc output piece.
I ended up rebuilding the part, however, when I went to start using it again, I noticed my output TDS was high (50 TDS), and what was really weird is that it is higher then my input TDS, which reads around 30 TDS.
I am not sure why my output would be higher then my input, but my best guess is that either:
1. MY TDS Probe is damaged
2. My DI Media is exhausted (but why would that cause the water to be dirtier on the output)
3. I didn't let the PVC glue dry long enough before use (I let it dry about 18 hours)
As I started troubleshooting this, and thinking about it more, I started wondering how well my probe setup is working to accurately detect the water quality. I may have been using my system with depleted resin because the probe isn't reaching the water stream. The probe doesn't even stick out of the John Guest fitting, let aloe into the reducer bushing, and then into the T, where the water flows.
I think I am going to try a different setup for the probes, like what ColdSoda posted about earlier in this thread, which seems like a much better and simpiler design!
https://forums.nasioc.com/forums/sho...1&postcount=15
Here are some of his pics, in case anyone can't see them because of photobucket:
I still don't think that the probe will stick directly into the stream, but it will be much closer then the setup I have now. And maybe not having any PVC Glue will help.
I may also get a handheld TDS Meter so I can compare the readings between my inline probe, and the handheld meter.
Finally, I think I will also order new resin. I am sure it is time for a refill, and I don't think I have been packing my resin properly. So hopefully, after all of this, things will be good again! I will post my findings, along with pics of my new setup. I ended up rebuilding my stand with cedar and reinforcing it in certain areas I was having issues with, and now that is solid. I am glad I re-read through this thread and found ColdSoda's post about the fittings, it was a great post!
On a side note...my electric pressure washer also decided to take a dump over the weekend, so I ended up having to wash the car with un-pressurized city water! Hopefully that will be a quick fix as well!
whiplash willy is online now   Reply With Quote
Old 05-01-2018, 07:56 AM   #55
Notch 8
Member#: 355254
Coldsoda needs to post some pictures of his new setup.
Notch 8 is offline   Reply With Quote
Old 05-01-2018, 12:10 PM   #56
ColdSoda
Member#: 200545
2008 SPEC B
Thanks for the kind words Willy (and for the picture help...lol)
Here's a picture of the whole setup with the two 20" resin tanks:
I was running through resin like crazy with my input TDS of 650-710. The two 20" tanks only hold 0.33 cubic ft of resin combined and I was replacing it every 2 months. With CR Spotless changing their power user exchange program, I search for an alternative.
What I found was a monster 14" diameter mixed bed resin tank that holds 3.6 cubic ft of resin (and weighs 303 lbs). If I were to continue using about 40 gallons a month, instead of replacing every 2 months I could predict replacing after 20 months! Now with that said I have increased my usage of water because of this massive tank, so I'll probably replace the resin once a year or so (we'll see).
I don't have a picture exactly as the one above, but this will give you an idea:
ColdSoda is offline   Reply With Quote
Old 05-01-2018, 01:37 PM   #57
whiplash willy
Member#: 424843
ISM
ColdSoda, No problem! Your posts have been very helpful!
I would love to hear more details on that monster 14" tank! What kind of resin are you using, and how much does it cost to fill up that thing? It has gotta be crazy!
Also, what are your thoughts on the TDS Meter Probe positioning and accuracy. The TDS Meter probes typically come with a 1/4" Quick Connect Tee, that will actually put the probe tongs into the water stream. With our setup though, it seems like the 1/4" Quick Connect Probe isn't long enough to stick out further then the fitting to be placed in the water stream, which makes me wounder how accurate it is.
Old 05-10-2018, 03:40 PM   #58
TheDonCT87
Member#: 137177
2006 LegacyGT Stg2.5
Awesome thread! Looking to build similar but have a few questions.
I called up the county water and asked about sediment and they said there is none. Lake water
Also looking at my Chlorine it is 1.44 at the highest.
Is it overkill to create a system with more filters such as a Sediment-> Carbon->DI
My TDS reading at my house is only 45-50
Any thoughts would be appreciated!
TheDonCT87 is offline   Reply With Quote
Old 05-11-2018, 01:48 PM   #59
whiplash willy
Member#: 424843
ISM
I finally had some time to work on my filter setup, and address my issues. I ended up re-doing the output end, using some of the parts that ColdSoda used.
I was able to reduce some pieces, but still used the same fittings to connect to the filter cap, and for my hose connection. I used a John Guest 1/4 to 1/2 NPT like ColdSoda, for the probe, but the Tee I used had a 1/2 NPT threaded connection, so I could screw the John Guest fitting right into the Tee. I like the John Guest Fitting with the 1/2 end, because it creates a bigger opening for the water to come into, and hopefully will give a more accurate reading. I also positioned the probes sideways, which will hopefully give me a better reading.
Here are links to the parts, and some pics:
https://www.homedepot.com/p/John-Gue...3309/300753463
https://www.homedepot.com/p/DURA-3-4...-101/100344993
I did some testing by just running water through my system without the DI filter cartridges in there, to see what readings I was getting, to try and figure otu why I was getting 30TDS water in, and 50TDS out before. Without the Filter Cartridges, I was getting about 25TDS in, and 29TDS out, probably because the filter housings were dirty. I cleaned the housings out, and refilled my resin, and packed it well.
This time around I used CR Spotless's Refill Resin, because it was actually cheaper at $43, then what I was using before. Plus they use the MAG-MB resin, which is specifically for spotless rinsing. The bag was also for 7lbs of resin, instead of 5lbs. I was able to completely refill both Filter Cartridges and had a little left over!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When I was refilling the Filter Cartridges, I noticed the old resin had been completely exhausted (It is color changing). I think that was most likely the cause of the higher Output TDS water I was having. With the new DI media in place, I am getting 0 TDS output water again!
Also, I was able to fix my Pressure Washer as well, all it needed was a $15 new GFCI plug, and it was good to go!
Old 05-11-2018, 04:42 PM   #60
whiplash willy
Member#: 424843
ISM
Anything you can do to reduce the TDS of the water going into the DI Filters will help extend the life of your DI Resin, which is somewhat expensive. The question is how much will a Sediment and Carbon filterer reduce your water's TDS. If you have the space, and don't mind spending a little more money up front, I don't see any reason not to add pre-filters.
CS Spotless's site has a cool page that will help you estimate how many gallons of 0TDS water you will use:
https://crspotless.com/how-many-washes/
If you are going to use two 10" x 4.5" filter housings like me, you will want to select DIC-10.
On a side note, I wouldn't think lake water would be sediment free. I wounder why/how that would be the case.
Old 05-11-2018, 06:49 PM   #61
TheDonCT87
Member#: 137177
I am getting diw 20 and 2 10x2.5 filters one for 1micron sediment and the other a carbon filter. I searched online and couldn't find anything about sediment in my area, but I agree with you, how can there not be any. The carbon from what Ive read should help eliminate other things to protect the DI resin. Also my county chlorine report is 1.44 which is low.
Old 05-16-2018, 09:17 PM   #62
cramerox
Member#: 447443
SILVER
A sediment filter is so cheap there's no reason to not run one.
Carbon will remove chlorine and or chloramine, which will make your DI resin last longer- which is the most expensive to replace.
Old 05-22-2018, 03:43 PM   #63
TheDonCT87
Member#: 137177
So I have my system set up
1micron Sediment>5micron Carbon> DI system
I ran 5 gal through the pre filters( first 2) got a ppm reading on 90 then went to 60ish. Ran to store, came back after an hour and wanted to check it again and ran another 5 gals through. The first gal was reading 360ppm then went down to 60ppm by the second-third gal. By the fifth it was around 57ppm.
I thought this was very strange, esp the first gallon of the second time running it. 10ppm higher isnt much but 300ppm higher will def have a negative effect on the system(longevity wise of DI resin)
Should I even bother keeping the prefilters? Do they just have to be flushed more?
Hose- 49ppm
pre filters- 60ppm
Old 10-27-2018, 01:22 AM   #64
Frickard
Member#: 493258
Default Still reading 8ppm TDS output
Good evening,
I've just finished rebuilding my DI filter system as the previous build was still putting out TDS. After completing the new setup, my meter showed 0ppm TDS output with an input of 370ppm. After about 30 minutes of total use (maybe 40 gallons), the meter was again showing 8ppm TDS output with an input of 170ppm. Here is my current setup:
(2) 20" big blue filter housings
(2) 20" x 4.5" refillable filter cartridges
10 lb of Resintech MBD-30 Nuclear Grade Mixed Bed DI Resin
HM Digital DM-1 In-Line Dual TDS Monitor
I'm wondering at this point if I need to get something like a big fiberglass tank that I can rent by the month due to high TDS water. I thought the 20" filters would be overkill. Renting a tank would be cheaper than having to refill 10lbs of resin every month at $8/lb.
I noticed while transferring the resin to the larger filter canisters that it had changed from blue and orange to all orange. I don't believe I purchased color changing resin, but would this be an indicator that the resin is spent?
I just washed my vehicle this evening and I'll see if I have water spots in the morning. Maybe my meter is reading incorrectly. Any input or suggestions are much appreciated!
Frickard is offline   Reply With Quote
Old 11-02-2018, 10:29 PM   #65
cramerox
Member#: 447443
SILVER
Default DIY Spotless Water Filtration
You are burning through the resin! If the resin has changed color then itís done.
Resin is expensive and water is cheaper. Itís best to invest in an RO filter, store the water in a small tank then run it through DI resin.
Most of these sized filters have a recommended flow rate of 1.5GPM or less! If you are blasting water through much faster, there is not enough contact time with the resin to produce zero ppm TDS water.
Originally Posted by Frickard View Post
Good evening,
Old 11-12-2018, 11:36 PM   #66
subarutrissi
Member#: 493969
2002 Impreza WRX
Default cool setup dude
very cool setup
subarutrissi is offline   Reply With Quote
Old 01-11-2019, 10:52 AM   #67
talkglock
Member#: 496325
Quick question,
In post #54 (and other posts) there is a picture that shows a bunch of parts, one of them is what I'll call a quick connect that allows the TDS prob to fit into the water stream. I purchased both that part and the same probe. But the prob will not fit far enough into the adapter (it will fit into the quick connect section but not past the hole inside the adapter.
Did you folks have to drill/enlarge that opening to get the probe to fit?
Thank you.
talkglock is offline   Reply With Quote
Old 01-16-2019, 12:12 AM   #68
ColdSoda
Member#: 200545
2008 SPEC B
Originally Posted by talkglock View Post
Quick question,
Thank you.
I think Willy's post #59 is as good as a probe as we're going to get with this DIY setup. If you place the probe sideways at least you should get a decent enough reading for acceptable accuracy for us DIY guys. Sure its not ideal, but it is just an indicator, not a CPU factory pure water system...
Here's my setup as it sits right now. This does include another indicator that was supplied to me that is green when tds output is 0 and turns red when it goes over ~2.5TDS (resistivity is above 200k ohm). It has been consistent with my meter readings using the probes, fwiw.
