Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 03-30-2021, 02:29 PM   #26
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
Originally Posted by 1ofeach View Post
It was a full-out recall. Below is the text from the NHTSA website. I do not believe that recalls have a time limit. But clearly this one depends on what state the vehicle is registered, which is too bad because CA, OR, WA, UT all have areas that regularly get into the teens in the mornings. For my car, anything around 15 degrees in the morning and it would leak.
Summary
SUBARU IS RECALLING CERTAIN MODEL YEAR 2002 AND 2003 IMPREZA WRX VEHICLES ORIGINALLY SOLD IN OR CURRENTLY REGISTERED IN THE STATES OF SOUTH DAKOTA, NEBRASKA, NORTH DAKOTA, MINNESOTA, IDAHO, IOWA, MONTANA, COLORADO, WISCONSIN, NEW YORK, WYOMING, MICHIGAN, ALASKA, NEW HAMPSHIRE, VERMONT, AND MAINE. DURING COLD STARTS, TYPICALLY UNDER EXTREMELY COLD TEMPERATURES, FUEL LEAKS IN THE FUEL DELIVERY LINE COULD OCCUR WHERE THE LINE CONNECTS WITH A RUBBER HOSE.
Remedy
DEALERS WILL REPLACE THE FUEL LINE FREE OF CHARGE. THE RECALL BEGAN ON DECEMBER 31, 2009. OWNERS MAY CONTACT SUBARU AT 1-800-782-2783.
Ah, interesting.
K3rm1tth3fr0g is online now   Reply With Quote
Old 03-30-2021, 03:42 PM   #27
1ofeach
Member#: 8641
2002 WRX DayGlo Blue
2001 S2000, 2017 FoRS
Default fuel smell
FWIW, and looking at some of the replies in the thread, the OP is going to be tempted just to tighten the clamps or add new clamps to the existing fuel line connections.
I remember back in ~2004/5/6 when this came up, TONS of us tried that, only to have the problem come back in one or 2 winters. So if you in fact have this same old problem, if you are going to take the effort of removing the intake manifold to get to the fuel lines, I would recommend doing the full Subaru fix. TSB shown below. One new metal line and one new rubber line required.
https://forums.nasioc.com/forums/sho...9&page=3&pp=25
1ofeach is offline   Reply With Quote
