02-12-2017, 07:51 PM | #28651 | |
Member#: 445904
Is your highway driving cruising, or stop-start at rush hour? By the way I have a manual 2016 Impreza Sport Premium 5-door, so if you have a 5-door with 17 inch wheels we should be comparing apples to apples. Oh I should mention, my highway cruise speed is 125 km/hour (78 mph). If you are going lots faster you would see reduced economy, although your numbers still seem low to me. If you are going lots slower like drpoop at < 70 mph (< 113 km/hr) then your economy will be better as he reported.
02-12-2017, 10:07 PM | #28652 | |
Member#: 428450
Thisis very helpful. I think I can get 7-8 ish if I try but I never bother. I have 17" wheel as well but I do have Mudflap which is aerodynamically punishing. |
02-12-2017, 10:57 PM | #28653 | |
Member#: 435599
Vehicle:2016 Impreza Sport White |
I gun it everywhere city and highway with the CVT. |
02-12-2017, 10:59 PM | #28654 |
Member#: 421858
Vehicle:2012 Impreza |
All I know is next time I get a car I'll ask for an extended test drive and see what the actual MPG is like. I've read some dealers will give you a day or two to give a car a real test drive instead of just that 15 minute BS most people get
02-12-2017, 11:12 PM | #28655 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
With my dealership they let me take the car home overnight. That was kinda cool.
02-12-2017, 11:17 PM | #28656 |
Member#: 421858
Yeah but you're Canadian, I'm guessing they also insisted you don't owe them anything and the last person who accidentally cut you off stopped, got out, and apologized profusely.
02-13-2017, 01:00 AM | #28657 | |
Member#: 445904
It's turned out fine though. There are some things I don't like but overall I'm very happy and I really don't think there's another car in the price range, or even for $5,000 more, that I would have liked better. |
02-13-2017, 03:16 AM | #28658 | |
Member#: 313093
VIC
02-13-2017, 03:22 AM | #28659 |
Member#: 313093
VIC
Haha it doesn't really work like that. Tons of douchy people and crappy ass drivers that have no business being on the roads.
02-13-2017, 07:52 AM | #28660 |
Member#: 425248
Vehicle:2015 Impreza Prem 4d Dark Grey Metallic |
I ended up buying the one I test drove. Did the typical around the block on my own. Had the exact configuration I was looking for. Though I kind of wish I got one straight from the truck, since I'm sure mine saw some wind outs of the engine, including during my test drive...
I did test out a base model a few months prior to driving mine, and that route got me out on the freeway, climbing some steep hills, variable turns, etc. Was a good route. So I already knew the car I wanted after that. But an extended test drive sounds amazing, too good to be true. I don't think anyone would've let me do that straight out of college for a first car though ***128518; Last edited by supertoast; 02-13-2017 at 08:03 AM. |
02-13-2017, 08:31 AM | #28661 | |
Member#: 438589
South East
Vehicle:2012 Impreza Sport Camellia Red Pearl |
02-13-2017, 09:42 AM | #28662 | |
Member#: 428450
So I drove for about 1.5 hours on highway this morning and really closely looked at my fuel economy. I do get 7.8 l/100km at around 120-125 km/h. But only on a very flat stretch of straight line. My drive was more of a wavy, so it constantly went between 7.0 to 11.0 l/100km (downhill and uphill). But for the most part, 7.8 is in the lower range for me. I run on blizzak ws-70s (their winter tires from costco) on 16" right now. It snowed a lot last night so highway was semi-wet + salt covered. I'm also on TH rev3 tune so this probably had big impact. I wonder what makes your car slightly more fuel efficient than mine. I also talked to a local 2012 impreza driver and he gets around 6-7 on highway. Btw, today I learned our car is rev-limited at 7k. I thought I broke the engine. LoL scary |
02-13-2017, 10:13 AM | #28663 | |
Member#: 310435
Vehicle:'12 Sport Limited Black - 255,685 miles |
When and if I need to buy rotors, I'm buying blanks. I have no need for holes and sluts. |
02-13-2017, 11:17 AM | #28664 | |
Member#: 421858
I'd honestly get whatever the cheapest brand name rotors you can find are. It's not a track car, and even if you're using it on the track, the stock brakes do fine and don't need an upgrade. |
02-13-2017, 11:52 AM | #28665 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
I haven't noticed a significant difference between my snow and all seasons for mpg.
It will clearly be worse when it's slushy or snowy but pretty similar if it's dry. Here are my numbers with the stock all seasons and CVT 75-80 mph- 32 65mph - 37 City- really depends on driving habits. If I'm in a hurry then it's in the mid to low 20s. If I drive efficiently I can get close to 30 |
02-13-2017, 12:18 PM | #28666 | |
Member#: 438589
South East
But thanks for the advice on drilled holes. Would 276.8mm x 24mm fit Or 292mm x 24mm |
02-13-2017, 01:21 PM | #28667 |
Member#: 421858
When I said drilled and slotted I meant either or. You do not want that liability in your car. Both are awful.
I'm not sure what the rotor size is. Find a rotor you know would fit on another website and see what the measurement is. |
02-13-2017, 01:33 PM | #28668 |
Member#: 445904
02-13-2017, 01:53 PM | #28669 | |
Member#: 310435
As far as the type of rotors, drilled / slotted don't offer any advantage over a blank rotor in normal driving. If this were a high performance sport car and you drive it hard or track it, go for it. On an N/A Impreza that takes ~10 seconds to get to 60mph, why bother, unless you have custom wheels to show it off. |
02-13-2017, 02:08 PM | #28670 |
Member#: 421858
I'm not going to say it again. Slotted rotors shred pads and are dangerous. Drilled rotors are also extremely dangerous unless you're paying about $500 per rotor for an extremely high quality one.
You buy them anyway, and the rotors blow up on the highway some day, you'll wonder why you didn't listen to me and buy the cheaper rotors that do the EXACT SAME THING. |
02-13-2017, 03:28 PM | #28671 | |
Member#: 313575
Vehicle:2012 Impreza 2.0i HB |
yet, the other thing that drives city numbers down is that our cars take a long time to warm up to full temp (oil) so while it's warming up, it is eating up tons of gas. i can definitely see 27-30mpg in town (suburbia) if i'm driving around a lot and the car is warmed up. but for my barely warmed up 4-5 mile stretches, it's probably about 21mpg since the car is really inefficient when it's warming up. as for highway, the car definitely is in the 35-40mpg range if i keep it under 70. over 70, the mileage drops much more precipitously than my prior cars. (best tank has been right around 40mpg) |
02-13-2017, 03:37 PM | #28672 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
I think the city is BS. I think they expect you to live in butt **** nowhere and have 1 stop sign every mile or something. Or drive like a damn grandma and piss off every one off.
02-13-2017, 03:41 PM | #28673 | ||
Member#: 301179
BAIC
Slotted rotors do shred pads, but why is it dangerous? I've rocked slotted rotors without issues..... |
02-13-2017, 04:42 PM | #28674 |
Member#: 421858
It's just well known that unless you're paying a ****load of money, you're getting cheaply made rotors, and drilled and slotted both cause extreme stress points around the holes, which = high failure rate.
02-13-2017, 05:47 PM | #28675 | |
Member#: 301179
BAIC
Slotted rotors are completely fine, other than them wearing down the pad more aggressively. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
