Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 07-10-2018, 09:30 AM   #1
sergey2007
Member#: 304910
2004 LGT ej207 7163
Default Legacy GT, ej207, Borg-Warner EFR7163 stock location
For now, just a collection of un-sorted photos. I'm sorry that there is no well-formatted description.
Completely homemade set for installing a EFR 7163 (IRL) in a stock location.
EWG Tial 38mm.
sergey2007 is offline   Reply With Quote
Old 07-10-2018, 09:42 AM   #2
sergey2007
Member#: 304910
2004 LGT ej207 7163
Exhaust 3"
Old 07-10-2018, 09:51 AM   #3
sergey2007
Member#: 304910
2004 LGT ej207 7163
Uppipe. Сeramic coated. For pairing with a twinscroll exhaust manifold from JDM STI GRB.
Old 07-10-2018, 10:07 AM   #4
sergey2007
Member#: 304910
2004 LGT ej207 7163
Preparing the air inlet 3" and oil drain in stock location.
Old 07-10-2018, 10:13 AM   #5
sergey2007
Member#: 304910
2004 LGT ej207 7163
turbo position
Old 07-10-2018, 10:27 AM   #6
sergey2007
Member#: 304910
2004 LGT ej207 7163
oil and water supply
Old 07-10-2018, 10:31 AM   #7
sergey2007
Member#: 304910
2004 LGT ej207 7163
connection with a 3" J-pipe
Old 07-10-2018, 05:02 PM   #8
PDXREALTOR
Member#: 468393
2017 STI
Where did you get that 3" inlet adapter? I want one!
PDXREALTOR is offline   Reply With Quote
Old 07-10-2018, 05:23 PM   #9
TDagen
Member#: 163648
V9 6mt R180 Brembos
Excellent quality work there, good job!
TDagen is offline   Reply With Quote
Old 07-11-2018, 05:00 AM   #10
sergey2007
Member#: 304910
2004 LGT ej207 7163
This adapter was made individually. The compressor casing was installed in a lathe, the factory flange was removed. And after that, cut the adapter by 3 inches. After installation on the compressor case inside, they made a cone expansion from the impeller
Old 07-11-2018, 10:55 AM   #11
PDXREALTOR
Member#: 468393
2017 STI
That's really neat! Was that done for spool only?
I gained a 1/2 lb spool using a velocity stack 2.4-3" inlet like yours but mine was just a composite slip on ring that, I think, leaked at high psi.
Again man.... That thing is awesome. As is all your other setup. Def watching this one.
Also, do you plan to run your air intake filter further down into the fender to lower iat, or do you plan to leave it where it terminates now?
Old 07-11-2018, 12:37 PM   #12
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
dat long runner tho
Zmanwrx23 is offline   Reply With Quote
Old 07-12-2018, 08:29 AM   #13
Lance123
Member#: 301663
2004 JDM WRX Wagon
Mind sharing where you got the v band flanges for the IRL exhaust housing?
Lance123 is offline   Reply With Quote
Old 07-12-2018, 09:18 AM   #14
sergey2007
Member#: 304910
2004 LGT ej207 7163
I have an aluminum box that completely separates the filter from the engine space and provides air intake from the bumper. So do not need to lower the filter.
Old 07-12-2018, 09:24 AM   #15
sergey2007
Member#: 304910
2004 LGT ej207 7163
These flanges and clamps are not factory. Сompletely self-made.
Perhaps there is this seller.
https://www.ebay.com/usr/acceleratedtube
But I do not know if it's suitable for IRL v band
Old 07-12-2018, 10:41 AM   #16
PDXREALTOR
Member#: 468393
2017 STI
Nice. Do you think going deeper in the fender (longer intake) would hurt spool or performance?
I have some kydex to make a block off, but have not put it to high on the importance list because my gigantic filter goes all the way down onto the undercowlimg surnace. Also, I would have to get a smaller diameter filter at the base for it to fit higher up.
Also, how did you rig up fresh air? I have a nice spot in a blank. Cover on the lower bumper but, rain is scaring me.
Old 07-17-2018, 03:23 AM   #17
sergey2007
Member#: 304910
2004 LGT ej207 7163
I saw no reason to lower the filter down, there and an excellent influx of air from the bumper. And the extra length of the pipe at the inlet is also not needed.
Old 07-17-2018, 02:53 PM   #18
PDXREALTOR
Member#: 468393
2017 STI
Nice work. My bumper has some blanks in that area, but they are solid. I was thinking of cutting them out and doing a mesh cover like yours. Looks good. 👍
Old 10-17-2020, 09:00 PM   #19
MARKSTI2019
Member#: 501950
Do you still have this down pipe set up for the 7163 turbo for sale ?
MARKSTI2019 is offline   Reply With Quote
