Brakes & Suspension Forum sponsored by The Tire Rack |
07-03-2024, 10:30 AM | #1 |
Member#: 491035
Bad sway bar bushing?
This look like a bad sway bar bushing?
https://imgur.com/a/DSvdPM7 Seems split in parts. The opposite side doesn't have this. Suddenly getting a lot of noise metal on metal scraping) on low speed turning and going over speed bumps on the side with this bushing |
07-03-2024, 03:35 PM | #2 |
Member#: 30804
SWIC
Vehicle:87 Yugo Red |
That's not terrible, but not great. Replace them and check your endlinks as well.
07-04-2024, 07:49 AM | #3 | |
Member#: 30669
Tri-State
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
I highly doubt it would make a metal on metal sound though. Worn out endlinks are more likely. Unless accident damage, I replace suspension parts in pairs. If 1 endlink is bad, do both now. The cost is not much and the car is up and tools are out. |
07-04-2024, 03:21 PM | #4 |
Member#: 27525
SCIC
Vehicle:03 wrx wagon yellow |
Doubt the bushing is making the scraping noises though, they do make a creaky squeal noise when they're worn. As a test, you could unbolt one endlink and see if the noise is still there. Unbolt from the knuckle and ziptie the dangling bit to the bar; if the noise goes away, there's your answer.
07-09-2024, 08:58 AM | #5 | |
Member#: 107618
Tri-State
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
I would spend some time underneath and inspect everywhere for wear marks. metal clanking would leave a mark somewhere. |
07-04-2024, 04:02 PM | #6 |
Member#: 491035
No accident damage. I've had coilovers on the car for nearly two years, slight drop of 1cm and a non-aggressive alignment. Perhaps not upgrading the endlinks from stock was a mistake when getting the coilovers installed. Can't see anything obviously wrong with the endlinks on either side, only this worn bushing on the side where the noise comes from. I'll get it to my mechanic and see what they say. Thanks for the input all.
08-07-2024, 02:54 AM | #7 | |
Member#: 538747
07-14-2024, 01:00 PM | #8 |
Member#: 443914
Vehicle:2021 WRX WRB |
The split is normal (assuming that's why you circled it), that's how you install the bushings on the swaybar. Funny thing, I just came here to post about my own swaybar bushing issue haha
08-15-2024, 03:55 PM | #9 | |
Member#: 507317
MAIC
Vehicle:2019 WRX Pure Red |
The bushing might need some silicone grease, but other than that, it looks okay. sure, after a while, those bushings will develop slop in them and new bushings will help keep the bar motionless. Are there poly swaybar bushings from SuperPro for the WRX? The poly will be more firm than the OE rubber, and will be more difficult to compress when installing. Also, the poly swaybar bushing will require silicone grease to reduce squeaking. good luck in finding the clunk sound. |
