Welcome to the North American Subaru Impreza Owners Club Sunday October 13, 2024
Old 07-03-2024, 10:30 AM   #1
Dmman
Member#: 491035
Default Bad sway bar bushing?
This look like a bad sway bar bushing?
https://imgur.com/a/DSvdPM7
Seems split in parts. The opposite side doesn't have this.
Suddenly getting a lot of noise metal on metal scraping) on low speed turning and going over speed bumps on the side with this bushing
Dmman is offline   Reply With Quote
Old 07-03-2024, 03:35 PM   #2
cboggess
Member#: 30804
87 Yugo
Red
That's not terrible, but not great. Replace them and check your endlinks as well.
cboggess is offline   Reply With Quote
Old 07-04-2024, 07:49 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Agreed, that is due to be replaced.
I highly doubt it would make a metal on metal sound though. Worn out endlinks are more likely.
Unless accident damage, I replace suspension parts in pairs. If 1 endlink is bad, do both now. The cost is not much and the car is up and tools are out.
Old 07-04-2024, 03:21 PM   #4
NickVu
Member#: 27525
03 wrx wagon
yellow
Doubt the bushing is making the scraping noises though, they do make a creaky squeal noise when they're worn. As a test, you could unbolt one endlink and see if the noise is still there. Unbolt from the knuckle and ziptie the dangling bit to the bar; if the noise goes away, there's your answer.
NickVu is offline   Reply With Quote
Old 07-04-2024, 04:02 PM   #5
Dmman
Member#: 491035
No accident damage. I've had coilovers on the car for nearly two years, slight drop of 1cm and a non-aggressive alignment. Perhaps not upgrading the endlinks from stock was a mistake when getting the coilovers installed. Can't see anything obviously wrong with the endlinks on either side, only this worn bushing on the side where the noise comes from. I'll get it to my mechanic and see what they say. Thanks for the input all.
Old 07-09-2024, 08:58 AM   #6
REX_WGN
Member#: 107618
06 GG WRX / 09 FXT
@florencedestinedfxt
This would help.
I would spend some time underneath and inspect everywhere for wear marks. metal clanking would leave a mark somewhere.
REX_WGN is offline   Reply With Quote
Old 07-14-2024, 01:00 PM   #7
Cab0oze
Member#: 443914
2021 WRX
The split is normal (assuming that's why you circled it), that's how you install the bushings on the swaybar. Funny thing, I just came here to post about my own swaybar bushing issue haha
Cab0oze is offline   Reply With Quote
Old 08-07-2024, 02:54 AM   #8
ncoatfletchin
Member#: 538747
Originally Posted by Dmman View Post
No accident damage. I've had coilovers on the car for nearly two years, slight drop of 1cm and a non-aggressive alignment. Perhaps not upgrading the endlinks from stock was a mistake when getting the coilovers installed. Can't see anything obviously wrong with the endlinks on either side, only this worn bushing on the side where the noise comes from. I'll get it to my mechanic and see what they say. Thanks for the input all. geometry dash wave
Have you taken it to a mechanic? Is the problem caused by a damaged stabilizer bar bushing? My dad's car has the same squeaking noise but he didn't take it in for inspection. Maybe I should help him take it in for repair just to be safe.
ncoatfletchin is offline   Reply With Quote
Old 08-15-2024, 03:55 PM   #9
GoFrogs
Member#: 507317
2019 WRX
Pure Red
agree with CabOoze. The split is how the sway bar bushing slides onto the bar.
The bushing might need some silicone grease, but other than that, it looks okay.
sure, after a while, those bushings will develop slop in them and new bushings will help keep the bar motionless.
Are there poly swaybar bushings from SuperPro for the WRX? The poly will be more firm than the OE rubber, and will be more difficult to compress when installing. Also, the poly swaybar bushing will require silicone grease to reduce squeaking.
good luck in finding the clunk sound.
GoFrogs is offline   Reply With Quote
