11-03-2006, 08:21 PM | #1 |
Member#: 50596
SCIC
Vehicle:04 wrx |
wat would your dream impreza look like??
If there was anything that you can do to your subie....what would it be...money is not a problem...I am looking for a complete mod list (interior, exterior, engine mods, etc)...something that is realistic and exists....
I was just daydreaming and i thought about it...if money was not a problem i would do my 04 wrx all over again the RIGHT way! exterior
interior
motor
Idk..that's all i could think about at the moment....anyone else?! Doing this makes me feel like a little kid all over again!
11-03-2006, 08:24 PM | #2 |
Member#: 26833
SWIC
Vehicle:'07 Bugatti Veyron '03 Chevy Silverado |
'05 White on Gold
Zzyzx coilovers Prodrive Mudflaps Tint Debaged SUBARU Spec-C Front lip Ipod-satellite radio dock Scooby Sport catted exhaust AP II |
11-03-2006, 08:38 PM | #3 |
Member#: 78421
Vehicle:2013 Toyota Avalon Nautical Blue |
11-03-2006, 08:40 PM | #4 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
22B is all i need
11-03-2006, 08:40 PM | #5 |
RIP
Member#: 59328
SCIC
Vehicle:1967 M35A2 duh, winning |
11-03-2006, 08:42 PM | #6 |
FartBoobies
Member#: 99138
or |
11-03-2006, 08:45 PM | #7 |
Member#: 50596
SCIC
Vehicle:04 wrx |
idk about the second one^^
but wow..the 22b gets a lot of votes! |
11-03-2006, 08:47 PM | #8 |
Member#: 107027
NWIC
Vehicle:2007 SWP WRX STi w/MPS-built 2.34l |
22b, or genuine S204.
We don't get any cool **** in America. |
11-03-2006, 08:54 PM | #9 |
Member#: 26833
SWIC
11-03-2006, 08:58 PM | #10 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
Body
WRC steel arches WRC front and rear bumpers WRC carbon rear spoiler FIA T45 multi point welded in roll cage STi alloy bonnet with RCMS heat extraction vents and gas struts Heated front screen WRC non heated lightweight rear screen Engine 2.0Litre closed deck subaru block RCMS extreme arrow rods RCMS 75mm steel crankshaft RCMS omega flat top pistons (coated) compression ratio 9.5:1 V4 STi cylinder heads with WRC/RCMS O-ring head gaskets and gas rings One piece Nimonic exhaust valves One piece stainless inlet valves RCMS uprated valve springs Plasma nitrided titanium spring caps WRC main and big end bearings WRC R-Profile high wrap cam belt system RCMS modified oil pump to suit R-Profile belt WRC S10 inlet manifold RCMS eight injector kit RCMS 72mm throttle body RCMS 5.5 litre alloy sump WRC short runner exhaust manifold Garret GT 35-40 turbo with speed sensor K&N air filter with RCMS 100mm inlet trumpet RCMS high flow intercooler with twin tube core 70mm stainless steel intercooler pipe work Electronics M800 Motec ECU with traction control,nitrous control,anti-lag paddle shift control,and full engine management control and data login Motec dash with data login Defi gauges for turbo,oil,fuel pressure Interior FIA carbon kevlar Recaro seats FIA Sabelt 6-point harness Transmission R180 STi rear axle 3.9:1 cwp and plated Modena LSD differential GKN rally drive shafts front and rear Torque line carbon fibre propshaft Six speed subaru gearbox casing modified for sequential housing Six speed Modena gear kit Subaru 3.9:1 front cwp RCMS sequential system RCMS paddle shift system Plated centre diff with 1:1 uprated output Modena gears Plated front Modena differential Fuel System FIA spec 26 litre rubber/kevlar bag tank in aluminium cover Twin Bosch fuel pumps (200 litre per pump) -8 Goodrich fuel feed pipe -6 Goodrich fuel return pipe -6 fuel cooler with cooling fan on return RCMS 8 injector distribution block 2x SX fuel regulators running at 4 bar static pressure Suspension WRC spec EXE-TC fully adjustable dampers High and low speed bump + rebound adjustment STi Rose jointed rear lateral links STi Rose jointed rear trailing links EXE-TC bottom rose jointed upright bushes STi alloy front arms (polished) STi quick-steer steering rack Other WRC roller bearing single piece steering column Momo suede steering wheel Nitrous NX full wet system 121bs carbon bottle with heater jacket High flow shark nozzle Motec auto control or driver manual system Adjustable from +35bhp to +400bhp Clutch RCMS spec triple plate alloy cover OS Giken clutch and flywheel RCMS hydraulic light pressure system Quick release dry brake fluid connection Brakes AP 355mm six pot front (track and road use) AP 290mm four pot rear with floating discs RCMS hydraulic carbon handbrake -3 stainless steel goodrich pipe work and fittings aka the gobstopper |
11-03-2006, 09:00 PM | #11 |
Member#: 94524
^ did you just copy that from their thread?
white bugeye exterior custom made lip using center OEM piece. 05+ rear spats molded in on 05+ rear bumper APR rear diffuser 06 tails painted molded Mine's rear lip spoiler. 06 STI roof vane. Kaminari reverse cowl[?] hood STi grille EDM projectors tint 02-05 WRX side sills custom fender flares Volk LN28s 255/35/18s interior Red Recaros covered in alcantara, matching door panels, rear seats, headliner and black alcantara on pillars. 05+ STi steering wheel. flat black dash with the silver HVAC rings and red hazard switch [is that S204?] Cusco bolt in cage. Defi gauges STi gauge cluster nice ICE. motor APS fmic Built Cosworth motor forged pistons, con rods, crank, etc. P and P intake and heads headers, unequal rotated GT35r good EM. 3.5 custom TBE with Blitz Nur Spec R axleback. built 6 speed STi tranny. anti lag system suspension Brembo BBK all around, SS lines, Motul fluid. all the best Cusco stuff and whatnot. |
11-03-2006, 09:05 PM | #12 |
Member#: 78421
11-03-2006, 09:07 PM | #13 |
Member#: 85592
BAIC
Vehicle:05 OBP |
it would look something like this. but black and the mods to back it up |
11-03-2006, 09:09 PM | #14 |
Member#: 78421
11-03-2006, 09:12 PM | #15 |
Member#: 26833
SWIC
I knew it wouldnt take long before the ricers invaded this thread.
Oh wait, that was the 1st post. |
11-03-2006, 09:13 PM | #16 |
Member#: 91476
South East
Vehicle:2005 9-2x Aero Black |
My dream impreza would look like ...... a Saab 9-2x
11-03-2006, 09:19 PM | #17 |
Member#: 50596
SCIC
Vehicle:04 wrx |
rice would be something that is non functional...everything i want is functional
11-03-2006, 09:21 PM | #18 |
Member#: 50596
SCIC
Vehicle:04 wrx |
11-03-2006, 09:27 PM | #19 |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
11-03-2006, 09:43 PM | #20 |
Member#: 60035
PRSIC
Absolutely a 22B with the other fans.
11-03-2006, 09:45 PM | #21 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
all i need now is an ej20 swap and i'm there |
11-03-2006, 09:47 PM | #22 |
Member#: 60035
PRSIC
Why don't you get Perrin and teh PDX guys to throw an H6 in there...
11-03-2006, 09:47 PM | #23 |
Member#: 81549
SCIC
I'll take a Prodrive P2, thank you sir.
11-03-2006, 09:48 PM | #24 |
GC84Ever
NWIC
11-03-2006, 09:49 PM | #25 |
Member#: 60035
PRSIC
what would the middle east look like today if it never had oil? | lotusdrift | Off-Topic | 108 | 03-12-2008 04:24 PM |
IT guys of OT - what would Nabisco Consulting, Inc. look like? | -=C=- | Off-Topic | 66 | 07-26-2007 10:39 AM |
What would a Subaru Fast look like? | OneCrackedEgg | Tri-State Area Forum | 23 | 03-08-2006 06:35 AM |
Chris, your car could look like this! | Arnie | Bay Area Impreza Club Forum -- BAIC | 5 | 08-06-2002 06:41 AM |
What would gold '98 wheels look like on a yellow WRX? | 2.5 RRRRS | Interior & Exterior Modification | 9 | 08-27-2001 11:03 AM |
