05-20-2013, 09:49 PM | #2051 |
Member#: 118486
Vehicle:2003 WRX PSM |
05-20-2013, 11:07 PM | #2052 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
Is it legal to have a set of whiteline rear lateral-links along with camber plates?
I know you're only allowed one set of camber adjustment per corner, but if I didn't replace both fore and aft lateral links, it should only adjust toe? *edit* These are what I'm talking about. *edit* Last edited by BeBop86; 05-21-2013 at 11:02 AM. |
05-24-2013, 01:15 PM | #2053 |
Member#: 305948
NESIC
Vehicle:2015 818R Black and Yellow |
Good question. I found this:
On strut suspensions using a non-standard lower control arm (as defined by Section 15.8.H.2), an alternate upper spring perch/seat and/ or mounting block (bearing mount) as described in Section 15.5.C may be used provided it offers no camber/caster adjustment beyond standard. And: 2. On arm-and-strut (MacPherson/Chapman) suspensions, the lower arms may be modified/replaced OR other methods of camber adjustment as allowed by Sections 15.8.C, F, or G may be used, but not both. So OR not both according to the rules. Now if you do this for the sole reason to get more toe I think you're still going to have a bad time with both camber plates and the adjustable arm if someone protests. Also, why... are you looking to get some insane about of toe? |
05-24-2013, 01:51 PM | #2054 |
Member#: 147776
NWIC
It's not wanting more toe... I keep it at zero. it's mainly wanting:
-Easier adjust-ability of toe (I do my own alignments, and the eccentric bolts aren't as easy to adjust as the front toe adjusters) -Stiffer bushings -Beefier arm |
05-24-2013, 04:25 PM | #2055 | |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
Besides toe. In stx I used them to increase track. (and adjust toe) In esp I use them to decrease. (and adjust toe) |
05-25-2013, 02:20 AM | #2056 |
Member#: 66033
SCIC
Vehicle:05 STi |
Greg,
Were you able to measure your track width changes at home or did you do it on a rack? I always wanted to play with that but never developed a way to measure it using strings in ones garage. |
05-25-2013, 09:42 AM | #2057 | |
Member#: 60566
SCIC
Seems easier and more consistent. Most annoying was getting parallel off of the rocker seam welds. |
05-28-2013, 11:39 AM | #2058 |
Member#: 60566
SCIC
got bored and weighed the car this weekend.
2880 with half a tank. (longacre scales) Which is what it weighed in stx on the heartland park scales back in 07-08 lol Still think there's 50lbs or so in cubic$ Seats and wheels. |
05-28-2013, 05:37 PM | #2059 |
Member#: 118486
That is light! I need to get on the scales...Id think I am pushing 2900+/-
Nice driving this weekend, Drew! |
05-28-2013, 06:46 PM | #2060 |
Member#: 172179
Vehicle:2006 WRX |
Count me a jelly too. I was just under 3K last time on the scales. Lots of things have changed since then but I would guess that is still pretty close.
The "Lincoln" springs are in. First event on them went well. Car is a bit looser but not homicidal on high speed transitions. Going to leave it that way for now. Catch cans are in after finding the missing quart of oil in the intercooler. We will see what tells me. New brakes are on the front. Feel much better. Not great, but very much improved. Going to up the friction coefficient of the pads and see if we can get it better. But never sure with new brakes. Is the improvement from them or just the bleeding? Time will tell... A few other little things, fixed sway bar links, little more camber up from, fixed left side rear camber, etc. Few more little things planed when I can find the motivation. |
05-28-2013, 09:31 PM | #2061 | ||
Member#: 175837
Vehicle:#61 9.5% FP |
So after snapping a lateral link on my wagon this weekend, I began contemplating what I'll do to fix it, what rules allow, and the effects on my track width. 1st question, rules. I'm a little confused, does 15.8.H.2 or 15.8.H.3 apply to the rear suspension?
If I can, what's the general thought on track width front versus rear? Or am I over thinking things? My options (have the TR control arms in my garage): Stock: Front = 57.7 Rear = 57.3 100.7% F/R Front: TR Alum control arms w/ sedan axles = 58.5 Rear: 57.3 102.6% Front: TR Alum control arms w/ sedan axles = 58.5 Rear: '04 STi Alum links w/ sedan axles = 58.5 Dead even Front: TR Alum control arms w/ sedan axles = 58.5 Rear: '05 STi Alum links w/ sedan axles = 58.9 99.3% Thoughts? |
05-29-2013, 10:39 AM | #2062 |
Member#: 60566
SCIC
The TR control arms are pretty much identical weight of the stamped steel but offer more rigidity. I would use them.
You can use any rear lateral link you want as long as they're not metal bushings (unless that's changed) Since the STi version would give you no additional adjustment you could do camber plates in the rear as well if you wanted. In regards to track I try to keep the rear of the car as narrow as possible, without binding anything, and then use spacers in the front to keep it 10-20mm wider than the rear. So I'd probably do the 04 STi rears. Another kinda cheap mod, that makes the older ones fun to drive, is the 06-07 steering rack. Not sure of your year. |
05-29-2013, 10:51 AM | #2063 |
Member#: 175837
Thanks for the input. TR fronts and 04 sti rears seems to be the way to go then.
The wagon is an '04, so updating the rack would be an upgrade in my case, which I didn't realize. I have access to them, so it looks like that'll go on my list of things to do whenever things stop breaking. |
05-29-2013, 12:19 PM | #2064 |
Member#: 60566
SCIC
eh. In my experience it doesn't stop. *SP kinda means everything the expensive, fragile, way. Especially in a subaru
I haven't really driven my car in 2 years and the right front wheel bearing was toast after I let my roommate take it to, http://www.lonepinetimetrials.com/ It was obviously going bad but still.... I'm on my 4th set of fronts with ~ 80K on the chassis |
05-29-2013, 12:37 PM | #2065 |
Member#: 172179
Vehicle:2006 WRX |
People always say this and I don't understand. I look at the prepared and mod cars where everyone always says "you can fix the things in those classes that break in SP." And yet they seem to have even worse reliability than the SP cars. We all know guys there on their 3rd motor in 2 years. I'll take a few sets of wheel bearings over that any day...
05-29-2013, 01:03 PM | #2066 | |
Member#: 60566
SCIC
I look at the work, $, and general preventative maintenance that goes in to the sprite and it boggles my mind. |
05-29-2013, 01:36 PM | #2067 | |
Member#: 147776
NWIC
05-29-2013, 02:57 PM | #2068 |
Member#: 97301
Vehicle:2005 WRX Wag-Tow Rig 125 FM - QRE Invader |
I would suggest keeping the wagon rear track. Will help with rotation and also getting bigger tires under the wagon fenders. I would also suggest getting a pair (each rear corner) of OEM aluminum lateral links. These were available on the '05-07(I think) wagons. Pair them with some GroupN or poly bushings and a relocation kit for the sway bar. That should put you in business.
05-29-2013, 03:13 PM | #2069 | ||
Member#: 120152
05-29-2013, 03:34 PM | #2070 | |
Member#: 147776
NWIC
It looks like the '05-'07 WRX wagons use only front aluminum lateral links and steel rear. Found this picture on google images, looks like someone figured out you can use two sets of front lateral links, just that piece to attach the sway bar: Last edited by BeBop86; 05-29-2013 at 03:49 PM. |
05-29-2013, 03:44 PM | #2071 | ||
Member#: 175837
05-29-2013, 03:48 PM | #2072 | |
Member#: 175837
The only thing (I think) is not allowed sedan <-> wagon, is that I can't swap to sedan front fenders, since it wasn't offered on the wagon. |
05-29-2013, 03:49 PM | #2073 |
Member#: 147776
NWIC
Does anyone know if the Update/Backdate rule applies between wagon and sedan as well? Maybe I can use wagon rear lateral links (because they are a "standard" part) instead of sedan ones to decrease my rear track width, but still use my camber plates?
05-29-2013, 03:59 PM | #2074 | ||
Member#: 175837
05-29-2013, 04:42 PM | #2075 |
Member#: 97301
Hey! That's my car!
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
