#2076 | |
Member#: 172179
Vehicle:2006 WRX |
![]() Quote:
#2077 | ||
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
![]() Quote:
![]() -Can't use standard parts in different locations (e.g. lateral links). But I should be able to use the regular ones anyways. -Can't use sedan fenders as I think that's considered the unibody? But then again, flares are allowed and cutting the fenders are allowed. (Besides, I think those bubble type flairs look awesome on wagons, even more so than on sedans anyways ![]() ![]() |
#2078 |
Member#: 97301
Vehicle:2005 WRX Wag-Tow Rig 125 FM - QRE Invader |
![]() At least in ST*, you can replace lateral links, but you must have only one method of camber adjustment. These arms do not provide camber adjustment, so plates or bolts should work just fine.
#2079 | |
Member#: 175837
Vehicle:#61 9.5% FP |
![]() Quote:
![]() One would think it would be relatively the same. What did you use to mount the sway bar to the aluminum links? |
#2080 |
Member#: 120152
![]() Poltec makes some that bolt directly to an adapter on the knuckle.
http://www.poltec.us/products/subaru...s/1a-df016.htm |
#2081 | |
Member#: 97301
![]() Quote:
#2082 |
Member#: 147776
NWIC
![]() Ugh... I'm now poor
![]() Just sent my order in for my first set of Hoosier A6 tires (285/30/18) and wheels to fit them (Mach V Wicked Awesome 18x9.5 +42). Thought about buying cheap/affordable wheels, but figured I should get something nice if I'm trying to be competitive. Any tips for first timers on the purple crack? I was told I don't need to get them balanced. My first national level event is coming up on Aug 9... The main bullet points of my current setup is: -2002 WRX -2005 transmission -2007 engine/electricals -Oem front bar, 22mm whiteline rear -H&R Clubsport coilovers, 10k front springs, 11k rear springs. -neg 3* front camber, neg 0.5* rear camber, zero toe all around. -OBX front helical diff, Cusco 1.5way rear diff. |
#2083 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
![]() No balance needed. Overdrive the **** out of them as you'll find out you're still under driving what they're capable of after the 1st run. Keep them generally cool. IIRC the optimum temp is about 120 degrees for the A6 and they get there pretty quick, especially with a codriver.
#2084 |
Member#: 147776
NWIC
![]() Should I bring a pyrometer and garden sprayer with water?
What about tire pressures? |
#2085 | |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
![]() Quote:
Bring a sprayer. I use 30 fr 28 rr as a starting point and adjust the rears up or down depending on rotation. I run lower than most people I've encountered but they still say hoosier on the sidewall at the ened so...not too low for my set up. Just check the rollover if you're concerend start up from that by a couple pounds. P.S. why aren't you doing the pro? |
#2086 |
Member#: 147776
NWIC
![]() I don't think I'll get my wheels/tires in the mail by then
![]() I'll try out next year... hopefully tires will still be good after only using for Canadian nationals... or do you think they're only competitive for one "event"? |
#2087 |
Member#: 60566
SCIC
![]() They can be competitive for a whole season, +. I would put their total between 80-120 runs. Especially for your area. Just take care of them as far as storage. Bag them and don't put them somewhere the temperature swings radically. Basement, etc.
#2088 | |||
Member#: 6850
Vehicle:1996 Camaro Z28 1LE, '23 WRX & '19 XV |
![]() Quote:
![]() Quote:
#2089 |
Member#: 147776
NWIC
![]() Oh, I thought you guys were talking about the tour.
Yeah, I've never done a pro-solo. Do I need an SCCA membership, or is the $110 the only fee for the weekend? |
#2090 |
Member#: 60566
SCIC
#2091 |
Member#: 80649
South East
![]() If you haven't read this, it's pretty much the best resource for A6's considering it's written by Hoosier
![]() http://www.hoosiertire.com/pdfs/tctR6_A6.pdf Notice what it says about the tire feeling like it's skipping over the pavement when it comes to tire pressures. |
#2092 | |
Member#: 175837
![]() Quote:
Also, I would consider adding a bit more negative rear camber to avoid excessive should wear. It's not to hard to wind up with a few tires that have plenty of sticky meat in the center of the tread, but are ruined because the shoulders are near corded. |
#2093 |
Member#: 147776
NWIC
![]() Should -1° to -1.5° be okay?
#2094 |
Member#: 147776
NWIC
![]() Just saw Karen's pics, nice color choice
![]() Bummed I didn't finally get to meet you guys, will have to next year! |
#2095 |
Member#: 147776
NWIC
![]() Does anyone here have a trunk spoiler setup like the CSP Miatas typically do on their Impreza?
#2096 | |
Member#: 6850
![]() Quote:
I still have the stock WRX wing and I know Greg is wingless. One of the local ESP Mustang drivers here in the DC area actually wind tunnel tested his car, and came up with a tiny spoiler (about an inch high) as the best application for his car. I'm not convinced its necessary for our cars at autocross speeds. |
#2097 |
Member#: 147776
NWIC
![]() Interesting...
Brad, if you're on here, do you have a pic of your car? I only ask, because a friend has a slightly bent trunk I can have, and I was going to have fun with it and weld or bolt on a spoiler to play with. ![]() ![]() |
#2098 |
Member#: 172179
Vehicle:2006 WRX |
![]() I don't have any super awesome pictures of my spoiler. This is the best I can come up with on short notice.
![]() There are a bunch more if you are willing to dig around on our photo site. http://owenphotos.smugmug.com/Autocross Even some of those far away shots are actually useful if you download the original sized version under details. Fun fact, my spoiler is made from the other half of the sheet of aluminum left over from building the spoiler on Doug's car that you posted a picture. And I enjoy the irony that instead of posting a picture of Doug driving his car you posted one of Brian driving it. Well played sir! ![]() It is also a great example of just how narrow the BMWs are. I had to add the dropping end plates to get it to cover the whole back of the car. |
#2099 |
Member#: 147776
NWIC
![]() That was a fun weekend! Had a noobie trial by fire on both dry and pouring wet for the Hoosiers
![]() Participated in the 2013 ASN Canadian Autoslalom Championship up in Pitt Meadows, B.C. and came home with 1st place in ESP! My co-driver, who has only driven my car 1 or 2 times before the event, ended up in 3rd by only a cone. There were 9 drivers in ESP and 130 drivers total. ![]() |
#2100 |
Member#: 242402
![]() Well Done, Sir!
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
