Welcome to the North American Subaru Impreza Owners Club Wednesday October 9, 2024
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-18-2013, 11:32 AM   #2126
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Originally Posted by subydude View Post
Yes, lets put the GC (93-01), GD (02-07), and GR (08-now) on the same line please
Can you say early 90's GC with a full GR swap in ASP? I'd wager a good solid 2,600 lbs or even less in SP trim with Evo numbers for power and a drivetrain that should be pretty solid.
In reality, putting the GD WRX in ASP means it should go on the same line as the GD/GR STi which basically means the best of breed 02 WRX with dual AVCS/right turbo/good trans & rear end.
I guess I was breaking at the 99 model in that scenario.
And nope. If I'm writing appendix A the STi's can stay on a different line
What's dual AVCS really worth?
mccanixx is offline   Reply With Quote
Old 09-18-2013, 11:42 AM   #2127
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
So what about the WRX to BSP and all on the same line then? Leave ASP to the STi and Evo? Doesn't seem fair to the WRX to go play with the STi and not get access to all the hardware.
The dual AVCS seems to give 300-400 rpm quicker spool and hold power better up top as well. The low RPM stuff wouldn't matter much since it's already a smallish turbo, but the higher end stuff would be a benefit IMO.
subydude is online now   Reply With Quote
Old 09-18-2013, 11:47 AM   #2128
sureshot007
Member#: 142405
#716 Group5 S10
I think it's because of the perception that since an 09+ WRX has the same turbo, the power levels are on par with the STI already. No reason to split them into different classes at that point.
sureshot007 is offline   Reply With Quote
Old 09-18-2013, 11:50 AM   #2129
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I don't think you'd see AWD going back into BSP. They fought hard to get them out. Don't look at the BSP/ASP numbers from nats haha.
Mainly because I have zero interest in what the STi has available, in SP. They are pretty different cars, drivetrain wise.
I'll take a little more power with a more fragile drivetrain. They can have a bit more power with the weight penalty and gearing penalty of the 6sp. Different avenues. I also think it would maintain a perception that you don't have to go to far from what you originally purchased.
Old 09-18-2013, 05:30 PM   #2130
griceiv
Member#: 162781
...so is it obvious i'm not a subie guy? GD-GR is what I meant.
Are the long blocks between the GD and GR similar enough (per solo rules) that you could swap turbos without having to do a full motor swap? or are we talking about doing full motor swaps to get the bigger turbo?
On the face of it the chassis seem different enough that the existing precedent in SP would be to keep them on separate lines. *edit* though now that I think about it the franken boxster/cayman combine different generations on the same line in asp, so who knows.
I think a best of breed GD would be interesting in ASP but would anyone build one?
griceiv is offline   Reply With Quote
Old 09-18-2013, 06:15 PM   #2131
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I am confident that I am a turbo swap away from have an 09 wrx assembly in my car. Heads and block are identical. I did all the research in 08 as I was going to use the turbo prior to it being fastracked out to BSP in feb 09.
I really wouldn't mind if the STi's and WRX were same line. It's just my little personal preference that they would remain separate. STi and WRX engines would need to be almost a complete swap if they were same line. Heads, pistons, are different. Everything else is identical for most model years.
If I had the money I would do an 09 for ASP till then I'll push my agenda...haha
Back to ESP I'm doing anti-lag for next year. I want to see how many 5spds I can bust at a pro-solo start!
Old 09-18-2013, 06:26 PM   #2132
Storm
Member#: 5218
96L Most Over-
Developed Beater
Lets see, 12 runs in a typical pro, -2 that really need to count and you gotta do at least 2 events to make the finale...... My guess is 10....
Get rid of that solid disc clutch and I might drop that estimate to 4-5 for the year.
Jay
Old 09-18-2013, 06:47 PM   #2133
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Solid disc + light weight flywheel = no bueno. Factory flywheel going back in. I will get to consistent 1.6's
Old 09-18-2013, 07:35 PM   #2134
griceiv
Member#: 162781
looks like all ej255 motors are the same (or will be soon through the part number obsolescence). so yeah, easy turbo swap if they were on the same line.
I tried the antilag stuff in the evo and it just spun the crap out of the tires. if i could get more consistent clutch control (tough to hold my leg still at over 1.2g forward accel haha) a low rpm/high boost launch would be awesome.
Old 09-18-2013, 07:38 PM   #2135
griceiv
Member#: 162781
the real question is would more that one person build a franken-subie for ASP? we need more people and it seems like it would be a damn fun and competitive car.
Old 09-18-2013, 08:08 PM   #2136
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE,
'23 WRX & '19 XV
Why do you say that?
CamaroFS34 is offline   Reply With Quote
Old 09-18-2013, 08:40 PM   #2137
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Rotational mass is inadequate to throw it off the line. Launched like a turd at the pro.
Old 09-18-2013, 08:44 PM   #2138
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Unknown? there were quite a few in ESP this year though. I think they are both, wrx and sti, getting long in the tooth. So the modded versions show up more. It will end up being a good place for the dot-r crowd as the street proposal goes through.
I also think it makes since to have them all (awd) dsm, etc in one *SP class. I think it would grow it.
I'm on board
Old 09-18-2013, 09:14 PM   #2139
sureshot007
Member#: 142405
#716 Group5 S10
You just need to stop being a puss and rev it higher
Old 09-18-2013, 09:51 PM   #2140
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I was at 6700 by sunday...
Old 09-19-2013, 08:11 AM   #2141
sureshot007
Member#: 142405
#716 Group5 S10
Don't worry, the antilag will fix all of that!
I'm jealous, because I wanted to be the first one to run antilag at a pro.
Old 09-19-2013, 06:51 PM   #2142
CamaroFS34
Member#: 6850
'23 WRX & '19 XV
Hrm. I've never not had a lightened flywheel in mine.
Old 09-19-2013, 07:02 PM   #2143
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
You lose mass in the disc as well. Put it in, drove to lincoln, realized the change Saturday morning first launch.
It was fine (better) the way it was. I did like the engagement more.
So I'll just put a factory flywheel back in and see how that feels.
Old 09-19-2013, 09:06 PM   #2144
subydude
Member#: 80649
Sparkly
I actually like how mine launches with the ACT streetlite version. I'm still running an Exedy sprung disc though. The 2-step is set at 6,200 on average for me.
Old 09-20-2013, 03:16 AM   #2145
griceiv
Member#: 162781
light weight flywheels? the 34lb exedy twin is where its at....
haha
Old 09-20-2013, 03:41 PM   #2146
zozza8
Member#: 118486
2003 WRX
Greg, how are you planning on setting up the anti-lag?
zozza8 is offline   Reply With Quote
Old 09-20-2013, 04:06 PM   #2147
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Clark Turner has a kit I'm going to experiment with. Uses the 32bit ecu/accessport. Don't know if it will be beneficial or not. But I'm interested in checking it out.
https://www.facebook.com/photo.php?f...type=1&theater
should be an open page
Old 09-20-2013, 04:32 PM   #2148
bradowen
Member#: 172179
2006 WRX
I know those guys You coming out to lovely Scottsdale?
bradowen is offline   Reply With Quote
Old 09-20-2013, 05:25 PM   #2149
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Oh yeah.
I was thinking about early next year. I can fiddle with the anti-lag on my own though. I think that's plug and play.
Old 09-21-2013, 01:33 PM   #2150
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
i want video with this on...
wrx wagone is offline   Reply With Quote
ESP-The 2002 WRX Project Butt Dyno NASIOC Project Cars 803 05-08-2022 07:15 PM
The Competition (strictly by the numbers) R Diamond STi Forum Archive 9 05-22-2003 04:16 PM
The Competition is Worried..G Stock is worried Scooby South Motorsports 10 02-23-2001 04:41 PM
Weapon R Intakes vs. the competition Matthew Nelson General Forum Archive 3 08-31-2000 12:19 AM
0-50 vs the competition bryanw General Forum Archive 11 08-11-2000 08:15 PM
