02-06-2014, 07:15 PM | #2201 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
I'm curious... would anyone protest a JDM hood scoop on an 02 WRX?
I know the rules say body pieces must remain stock as a whole... and the 06/07 won't fit the bugeye... but the opening dimentions are basically the same size.
02-06-2014, 09:26 PM | #2202 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
Locally? No, probably not unless you were winning. Nationally? Maybe, but especially if you were winning.
02-07-2014, 01:32 AM | #2203 |
Member#: 193756
NWIC
Vehicle:2005 LGT Wagon Silver |
Yeah, I wouldn't risk it for any national tour races, or the national championships
02-07-2014, 10:47 AM | #2204 |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
I would like to have one, I think they look great on a bugeye. But, I don't. Stuff like this, however benign, is just bad ju ju for any class. IMO at a local it sends a bad message, at a national event it sends a bad message and you're just bait.
02-17-2014, 04:50 PM | #2205 | ||
Member#: 248856
VIC
Vehicle:04 WRX wagon Java Black Pearl |
My understanding of the rules is that you shouldnt be allowed to run it On another note, Porting question for ESP, Quote:
Also in ESP the throttle Body cannot be touched at all from my understanding? No porting of that? For a Lower brace, Am I allowed to run the Type 1 Cusco bar that only attaches in 2 places? I know the H Brace is not Legal at all http://www.jscspeed.com/catalog/Susp...TI-1706-1.html Are aluminum control arms a legal swap? I would like to be able to run larger sway bars on my 04 WRX wagon but they only make them so big for the wagon. If theres a way to legally swap to Sedan sways i would like to do that. Thanks guys! Last edited by kblackman; 02-17-2014 at 05:16 PM. |
02-18-2014, 07:53 AM | #2206 |
Member#: 175837
Vehicle:#61 9.5% FP |
In regard to front sways on a wagon, certain manufacturers will fit both sedan and wagon. I have a perrin 25mm on mine, fits with no issues.
Aluminum control arms off the 06-07 wrx TR are legal, since they are on the same line. The aluminum control arms off an STi are not legal. |
02-18-2014, 08:05 AM | #2207 |
Member#: 142405
Vehicle:#716 Group5 S10 |
I had Whiteline 29mm adjustable bars on my wagon. The endlinks are different between wagon and sedan. I don't remember if the bars are the same, but they sent me sedan endlinks by accident, and they were never going to fit.
02-18-2014, 02:23 PM | #2208 |
Member#: 305948
NESIC
Vehicle:2015 818R Black and Yellow |
From the current rules for SP:
Carburetors, fuel injection, and intake manifolds are unrestricted subject to Section 15.10.D. 15.10.D states: Traction and/or stability control systems, as defined in Section 12.12, must be standard parts at standard settings or electronically disabled. 12.12 states: A system that adjusts engine power, braking force, or torque distribution when wheelspin, understeer, or oversteer is detected or predicted. Conventional limited slip differentials (e.g., viscous, passive clutch, helical/ worm gear, locker) are explicitly excluded, but "active" differentials and their controllers are included. So you can PnP anything above the engine so long as it doesn't affect your traction control or differentials. 0_o |
02-19-2014, 01:15 PM | #2209 | |
Member#: 147776
NWIC
02-19-2014, 07:28 PM | #2210 |
Member#: 154767
Anyone here going to Dixie? Could use the company. My husband and I are currently the lone WRX entries in a sea of Mustangs.
02-20-2014, 12:34 AM | #2211 | |||
Member#: 248856
VIC
Also new question... 3mm Phenolic Spacers Intake -> Manifold.. Legal or not? http://www.grimmspeed.com/phenolic-t...i-lgt-fxt-3mm/ Last edited by kblackman; 02-20-2014 at 01:59 AM. |
02-20-2014, 10:31 AM | #2212 | |
Member#: 60566
SCIC
From the turbo charge outlet to the head you are free to do whatever you want. (make your own intake, make your own throttle body, hell go to individual throttle bodies, make your own intercooler.) About the only rule in there is maintaining a BypassCompressorValve that functions as stock. The spacers are legal. But, just buy plastic tgv's instead. Having had both they don't raise the intake and are more effective. I'm pretty sure you're right on cross bracing. Can only connect to two points. On the heads. Everything you want to port for more flow is below the 1" rule. You are basically just port matching the tgv's at that point. Which isn't necessarily bad. Just not ZOMGWTFBBQ I just found 12HP!!!!!! edit: Your guy is right and wrong. He is correct in the porting of the interface of the intake and heads is legal. Wrong on everything else, because everything else (regarding the intake) is open. Last edited by mccanixx; 02-20-2014 at 10:47 AM. |
02-20-2014, 11:22 AM | #2213 | ||
Member#: 193756
NWIC
Strut brace rules:
02-20-2014, 01:30 PM | #2214 | |
Member#: 248856
VIC
Thank you, I finally got an email back from CACC autoslalom director as well and was basically told this. Gaskets and phenolic spacers are ordered, Now I just need to find some Larger 06 WRX injectors and let the modding begin! |
02-20-2014, 06:15 PM | #2215 |
Member#: 305948
NESIC
Yeah he's wrong on the intake manifold porting. The 1" rule is going into the heads and honestly there's no point. I'm making 230/265 on a untouched 2.0.
When I went to the Farmington Prolo I had to remove my H brace and my STI rear lower diffuser. Everything else was legit. Greg and I went over each others cars pretty heavily since we were the ONLY Subaru guys there. |
03-04-2014, 08:36 PM | #2216 |
Member#: 147776
NWIC
Tire question!
I've got Hoosier A6's for my dry / semi dry tires... and can't afford a set of Hoosier wets. What's a good daily driver / wet tire? I'm leaning more towards Continental DW vs the Dunlop Z2's, as I heard the DWs are better than the Z2s in the wet (which would be their primary use). Thoughts? |
03-05-2014, 09:03 AM | #2217 | |
Member#: 60566
SCIC
03-07-2014, 06:15 PM | #2218 |
Member#: 147776
NWIC
That's true, and kinda what I was thinking. I've heard nothing but praise from those running Conti's during the BC slush series.
Alrighty... ABW flares ordered (picture), and 18x11's ordered. So excited, hopefully the flares are somewhat wide enough (only adding about 30mm extra width, but on the plus side when compairing to Karltons, less flare = less weight ). Might need to do some widening on the front fender well opening. Question: I'm looking at bumping up to 315's this year, but was curious if anyone had any input on Hoosier A6 vs the BFGoodrich R1 S? Only info I can find is that they run wider than Hoosiers. Anything noteworthy? |
03-07-2014, 07:24 PM | #2219 |
Member#: 175837
03-07-2014, 08:11 PM | #2220 |
Member#: 147776
NWIC
XXR 531 18x11 +20 5x100/5x114.3
5 lbs heavier than my a Wicked Awesomes (24 lbs vs 19 lbs) but I'll be putting at least an inch wider tread down... Hopefully that will be okay. All others that size were $$$$ this way I can buy two sets. |
03-07-2014, 08:13 PM | #2221 |
Member#: 80649
South East
I weighed my set of 531 18x11 +20's at 26.5 lbs. Maybe my scale is different, but the combo of tire/wheel was almost 55 lbs.
Also, you guys are going to have problems with body seams and inbound clearance with 315's. |
03-07-2014, 08:16 PM | #2222 |
Member#: 147776
NWIC
Hammer time?
03-07-2014, 08:29 PM | #2223 |
Member#: 80649
South East
I think that's a one way ticket to SM since there isn't provision in SP for "massaging" inbound bits for clearance.
I can say without hammering on my car I wouldn't have been able to go lock to lock OR able to lower it much at all from full ride height. And you have to cut a LOT of front fender to get it to work. The rear is also an issue, but that's another story |
03-07-2014, 08:30 PM | #2224 |
Member#: 193756
NWIC
*looks at Nationals results from last year* I think you want the purple crack.
03-07-2014, 08:34 PM | #2225 |
Member#: 147776
NWIC
I don't think so... I've been chatting with someone else on here that has this same tire and wheel setup and the only issues they had was front fender well openings.
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
