#2226 | |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
![]() Quote:
#2227 |
Member#: 6850
Vehicle:1996 Camaro Z28 1LE, '23 WRX & '19 XV |
#2228 |
Member#: 80649
South East
![]() The GD must have a different seam on the rear if the fenderwell than the GC. On mine there was a .5 inch seam that stuck out and would contact the tire (once the car was lowered) if I were turning more than about 50-60 degrees. Then the upper, inner fender well shape itself got in the way (the curve you can see in the engine bay in front of the strut towers) and I moved it a little with a hammer as well.
I wasn't saying you couldn't do it, I was just saying that if the GD is anything like the GC you'll have rubbing issues unless you run it at pretty high ride heights ![]() |
#2229 |
Member#: 172179
Vehicle:2006 WRX |
![]() There is a seam in the rear of the front fender well but with the right setup, bushings, camber, offset, etc. it is not an issue. It is extremely close and when you spin the car and tires, bushings, etc. start to bend and stretch in unusual ways the tire can get into it a little bit.
I'm low but not super low. You can find some pictures from when I first put on the 315's and it was ridiculously tall. It took a while to get down to where the inner fender well is what is limiting going any lower. And no I haven't hit it with a hammer. It wouldn't really matter anyway since the engine wiring harness is just a hairs width above that. That wiring harness is why I keep those crappy fender liners marginally attached. I think I can come up with a way to move the harness if I wanted to using 15.10.C.1. But it would be iffy and I don't see the point since I would just have to add offset to get it to clear more of the fender well anyway. The car does not need to be any wider that this point! When I put on the 285s I can only lower it the .3 of an inch you would expect from the OD difference of the tires. The car does get a few inches narrower though which is nice. |
#2230 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
![]() Hey Brad, are you looking at an older rule book, I'm not seeing what 15.10.C.1 is referring to.
I'm a little confused with the rules, what exactly is and isn't allowed to be modified for tire clearance... fenders only? Just received my flares in the mail the other day and taped them on to check new clearances... should have them mounted by the end of the month. I also had my 285's taken off the 18x9.5 +30's and put on the 18x11 +20's (so I can put them up for sale). Looks like they fit fine without any tweaking to current setup, but I will definitely need to add some positive camber at the knuckle with 315s... maybe even remove caster to clear that pinch weld: ![]() |
#2231 | |
Member#: 172179
Vehicle:2006 WRX |
![]() Looks good!
![]() 15.2.A is the rule what you want to look at for modification of fenders/bumpers. |
#2232 | |
Member#: 193756
NWIC
Vehicle:2005 LGT Wagon Silver |
![]() 15.10.C.1 says nothing about wiring harnesses though.
#2233 |
Member#: 147776
NWIC
![]() Ran the 285's on the new 18x11 +20's this last weekend! They're 4lbs heavier per wheel vs. the Mach V wicked awesome's, but it wasn't nearly as bad as I thought (having torque doesn't hurt either
![]() So far not much rubbing (minus at full lock, near pinch weld). Waiting to hear from John Berget Tires on some 315's (buying used for local events/test fit purpose), get my offset caster and other bushings in the mail, install those, and find some time to attach the fender flares ![]() I'm hoping (besides possible fender cutting) the offset caster bushings are enough to move the tire away from the pinch weld. It's melted the plastic a little bit probably while at full lock in paddock, but not too much. If it's not.. I'm toying with the idea of swapping the camber plates forward... opposite of what most people do to gain caster... then essentially that should move the tire forward even more. I definitely will need more clearance with 315s... ![]() ![]() |
#2234 |
Member#: 193756
NWIC
![]() Meant to ask you, but you took off pretty quickly from the event. Why's the front bumper black?
#2235 |
Member#: 147776
NWIC
![]() Left early because had nail in street tire and didn't want to race on them with temp patch. Racing on the hoosiers would have been pointless at that point in the day.
I traded my prodrive molded bumper for a stock bumper plus cash. I want to possibly get a V1 lip, and I couldn't remove the prodrive lip because it was molded on. |
#2236 |
Member#: 147776
NWIC
![]() Question for those who run competitively/nationally: Do you run with Hoosier Wet's in the rain?
If you don't, what do you use when it's TOO wet to use A6's (standing water)? I thought about running whatever the street touring guys are running (Dunlop Z2's, Advan AD08rs, etc.), but maybe one step down in "performance rating" would be a better option... like Goodyear Eagle F1 Asymmetric 2's, or Continental DW's? It would be giving up dry traction... but that's not what I'd use them for. Thoughts? Tire Rack Tests: 2012: http://www.tirerack.com/tires/tests/...t.jsp?ttid=162 (Wet 1st: Goodyear Eagle F1, 2nd: Bridgestone S-04 PP, 3rd: Michelin Pilot SS) 2011: http://www.tirerack.com/tires/tests/...t.jsp?ttid=148 (Wet 1st: Michelin Pilot SS, 2nd: Bridgestone S-04 PP, 3rd: Pirelli P Zero, 4th: Continental DW) 2010: http://www.tirerack.com/tires/tests/...t.jsp?ttid=140 (Wet 1st: Continental DW, 2nd: Goodyear Eagle F1, 3rd: Michelin PS2) Last edited by BeBop86; 04-17-2014 at 11:31 PM. |
#2237 |
Member#: 80649
South East
![]() In heavy rain the Conti DW would be my pick.
#2238 |
Member#: 147776
NWIC
![]() Yeah, that was my initial first pick. I spoke with Luke@TireRack and he recommended MP tires over UHP for the rain.
I'm still doing research... I'm not sure if I can compare the charts and data from Ultra-high performance summer tires with Max performance summer tires on Tire Rack's site... It looks like the Advan AD08r is the best of the UHP tires in the wet... but that doesn't mean it's better in the wet than a MP tire, which has more grooving for water displacement. |
#2239 |
Member#: 80649
South East
![]() I think you're over thinking this
![]() Better yet, don't buy the DW's and save the money until next year for a real set of wets. If it rains, big deal. Just drive more sideways. |
#2240 |
Member#: 147776
NWIC
![]() Probably... I do that a lot
![]() No, there are a set of Hoosier wets for sale locally that I'm contemplating buying to take with me to nationals... but I don't want to waste them for local events. I also happen to need some street tires ![]() |
#2241 |
Member#: 6850
![]() When I ran in DS, I had a set of Hoosier wets on "stand by" in case I ever needed them (they were Eric Kriemelmeyer's from when he ran his Sentra SpecV in GS). I ended up needing them at the 2008 ProSolo Finale. I last used them at the 2009 Toledo ProSolo (running ESP), which was really a waste since unlike the Finale and like most Pros, it only rained one session.
Anyway, the Hoosier wets are great if it is a torrential downpour and you know you will get zero dry runs. If you get even one dry run, it's not worth it. After my experience three weeks ago, I'll just stick with my Cooper Zeon RS-3A all season "ultra high performance" tires. Are they the best? Probably not, but I'm not going to have a lot of fun changing tires in the pouring down rain and then driving, so screw it. |
#2242 |
Member#: 97301
Vehicle:2005 WRX Wag-Tow Rig 125 FM - QRE Invader |
![]() ^^^ I have also used my wets once in about 4 years.
If I could get street tires for wets on my FM car, I would do it too. I hear they are the coolest thing since sliced bread these days... |
#2243 | |||
Member#: 147776
NWIC
![]() Does anyone know if the SPT aluminum control arms are the exact time item as 06 WRX aluminum front control arms?
If they aren't the same part number, but geometrically are the same (weight, specs, etc.) they should be ESP legal... shouldn't they? I just bent my steel front control arm while trying to press out the front bushing ![]() Edit, never mind, they are the same: Quote:
#2244 |
Member#: 147776
NWIC
![]() Just a helpful tip, if anyone is looking to upgrade to Aluminum lower control arms:
The SPT kit has the EXACT arms that the 06 WRX uses, but also comes with new (I've heard Group N?) front bushings, rear bushings, and ball joints... I picked the whole kit up from the dealer for $330! That's cheaper than I could find used, and cheaper than buying them individually. Did a bunch of digging and learned that Subaru only made two versions of the GD chassis aluminum control arms. The SPT kit contains the V7 JDM (non spec-C) arms, which are the same as USDM 06 WRX and 07 STI: http://forums.nasioc.com/forums/show...6#post41949786 |
#2245 |
Member#: 147776
NWIC
![]() I'll post pictures here shortly, but just received the arms and they are indeed the same arms as the 2006 WRX, they also came with Group N bushings all around! Score!
Here's a question... Free caster mod. The factory service manual DOESN'T actually say or show which orientation the pin is to be installed on the arm. If that's the case, could this be legal? |
#2246 |
Member#: 147776
NWIC
![]() *crickets*
Hello? Anyone still here? |
#2247 |
Member#: 147776
NWIC
![]() Anybody going to crow's landing event, June 14th/15th?
#2248 |
Member#: 142405
Vehicle:#716 Group5 S10 |
![]() Nope. We're moving to ASP apparently.
#2249 |
Member#: 147776
NWIC
![]() Isn't it just a proposal for now?
#2250 |
Member#: 142405
![]() Considering that the revision just posted only clarifies the move more suggests to me that it's pretty much a done deal. I could be totally wrong, but I have the same feeling about this that I had with Street.
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 07:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 04:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 04:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 12:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 08:15 PM |
